Go Back   The RadioReference.com Forums > U.S. Regional Radio Discussion Forums > Michigan Radio Discussion Forum
Michigan Radio Discussion Forum Forum for discussing Radio Information in the State of Michigan.
Old 02-01-2013, 4:32 PM
Default pro 96 help again
to program frequencies into the radio the manual says to change receive mode to mo before entering frequencies, mine dosen't change to mo only am,fm,ct,dc is this why iam getting poor reception mostly no reception...
Old 02-01-2013, 4:43 PM
Sounds like you aren't setting up a trunked system.
Old 02-02-2013, 6:20 AM
drdispatch's Avatar
Your mode list should include MO for Motorola & ED for EDACS. While in the "Program" mode, press the "Trunk" button; Then use the "Mode" button to switch to MOT; You can then enter the talkgroups or go back to "Program" & enter the frequencies first. When you enter one of the MPSCS frequencies at that point, it should automatically switch to "MO".
(You have to be wary though, that if you enter a non-trunked 800 Mhz or UHF frequency, it will switch to "MO", & you will have to use the "Mode" key to switch it to FM.)
Scanner geek since 1974
PRO-2004/PRO-92/PRO-96/HTX-202/Motorola MCC-5500
"My Daddy sends smoke signals to Indians who arrest trolls & squirt water on dragons. What does your Daddy do?"
Old 02-02-2013, 7:50 AM
Default pro 96 help
thank you for that info , i have another question ienter the 25 frequencies from the belle tower into bank 0 now do i need to enter the 25 freq. from the iris tower into bank 1, when i try it comes up duplicate should i enter anyhow.
Old 02-02-2013, 8:18 AM
freqs's Avatar
You only need to progarm in 868.7250 that is the control freq for all Detroit Control towers.No need to put in all the freqs.Just 868.7250.But the Pro 96 does not decode Detroit all that well even within the city of Detroit the pro 106 does far better iam in Warren at 12 mile Schoenher and its still choppy at times
Old 02-03-2013, 10:41 AM
drdispatch's Avatar
Just look at the MPSCS page in the DB, enter the red & blue frequencies (control channel & alternate control channels) for the Detroit Simulcast site. Depending on where you are, you may also be able to receive the Southfield, Romeo, Northville, Flat Rock, &/or Western Wayne sites.
The other thing you need to do with the PRO-96 is if you enter more than one site, you will need to separate each site with at least one non-trunked frequency, otherwise the -96 locks on the first control channel it sees & ignores the others.
Example: Det Siml freqs / VHF freq / Southfield freqs / VHF freq / Northville freqs / VHF freq -- and so on. (I used VHF as an example but it can be any non-trunked frequency-VHF, UHF, 800.)
Feel free to PM me if you need further guidance.
Old 02-03-2013, 11:44 AM
i have enter the three freq. from the db the scanner is working but it is very choppy, is there some type of antenna that can be pruchase for better reception.. and i do thank you guys for the info
Old 02-03-2013, 11:56 AM
freqs's Avatar
It will be at best choppy with the pro 96.If your trying to get Detroit Towers
Are you within the City or out side Detroit and how far ?
Old 02-03-2013, 12:17 PM
iam located in redford , i just enter sothfield freq.it is very clear...
Old 02-03-2013, 1:24 PM
feta92's Avatar
You are getting Detroit off the Southfield tower?
Jason
Pro-106, Pro-197, Pro-2096
Old 02-04-2013, 1:10 PM
Send a message via AIM to kd8ati Send a message via Yahoo to kd8ati
You will NOT get DPD / DFD off of the Southfield tower. Only the Det Simulcast carries DPD.
Visit my West Wayne feed at http://www.radioreference.com/apps/audio/?feedId=12508
Old 02-05-2013, 7:28 AM
drdispatch's Avatar
Default My Bad....
Not being from over there I didn't realize that. I figured that there was some "overlap", but I guess it makes sense that there would't be. Didn't mean to steer you wrong, dman.
Posted wirelessly using a teeny tiny keyboard, so please excuse any typos.
Old 02-05-2013, 1:08 PM
Normally, as you know, there would be overlap, as that is how MPSCS was developed. Detroit is an exception to the rule. Due to just the sheer number of users on the Detroit Simulcast, the MPSCS has blocked the DPD / DFD radios from using other towers (Like Southfield & Flat Rock) as that would quickly clog them up, as they don't have the number of voice channels that would be needed.
Old 02-06-2013, 7:09 AM
drdispatch's Avatar
Lightbulb
....Due to just the sheer number of users on the Detroit Simulcast, the MPSCS has blocked the DPD / DFD radios from using other towers (Like Southfield & Flat Rock) as that would quickly clog them up, as they don't have the number of voice channels that would be needed.
And that makes perfect sense.
