The best way is to use the software that came with the scanner, or purchase an excellent aftermarket program made by
Butel. It's actually much easier to load-up your scanner using a direct connection to your computer than doing it by hand these days. Likewise, if you are make a financial donation to this Web site, you can download many free software files that are programmed for a lot of areas, including Metro Detroit. However, you will need Butel before you can download the files directly into your scanner.
73's
Ron
