Go Back   The RadioReference.com Forums > U.S. Regional Radio Discussion Forums > Michigan Radio Discussion Forum
Michigan Radio Discussion Forum - Forum for discussing Radio Information in the State of Michigan.
Old 04-26-2014, 5:46 PM
Default 800 Mhz Filters for MPSCS
Hi:
Does anyone use an 800 Mhz filter to help eliminate low or high frequency noise ? I listen mostly to just the MPSCS (Macomb County) and was wondering if a filter would be of any benefit. I was thinking of one of these:
BPF-800N
OR
BPF-800W
Thanks in advance for any tips. I am using a RS Pro-106 scanner and a RS 800 Mhz antenna already but my reception is a little choppy sometimes.
Old 04-27-2014, 9:44 AM
freqs's Avatar
I have never tried a filter .Not sure if it would help or hurt any .
The 106 is not perfect on MPSCS Simulcast .Ive found unless iam close to one of the towers it is choppy .
Old 04-28-2014, 11:53 AM
Thanks freqs. What do you think the best scanner is for MPSCS Simulcast ? I have considered going to the Uniden HP-1 but not sure if it would beany better or not.
Old 04-28-2014, 6:20 PM
freqs's Avatar
Iam not sure
I am waiting for my 436 to arrive to see how much better it is .Ive herad good things about it
Old 04-30-2014, 10:31 AM
Originally Posted by 248panayiotis View Post
Hi:
BPF-800N
OR
BPF-800W
I am over in Windsor and listen to Macomb County, I have 2 PAR filters hooked to mine but mine are tuned for paging crud. I find it does help a little bit, but not a major difference. I personally use BCD996XT and it works great, especially for being across the river, however I use a outdoor diamond discone. Hope this helps
LPE-200, BC898T, BCD996XT, R71A, MCS2000, Saber2000.
Old 04-30-2014, 10:33 AM
Here is their website, very good place with reasonable prices, and also their filters give no noise on the inside. PAR Electronics | Filters for the commercial 2 way market, MATV, FM broadcast, laboratory, marine industry, amateur radio, scanner and short wave listening enthusiasts
Old 04-30-2014, 11:27 PM
krokus's Avatar
Default Re: 800 Mhz Filters for MPSCS
What sort of reception issues are you having? If you are having the "normal" simulcast problems, then a filter is not likely to help.
Sent via Tapatalk
Copyright ©2000 - 2015, vBulletin Solutions, Inc.
