oldgold31
I have heard nothing from their dispatch and with their pulling of all patrols off the road due to fundind there may not be any traffic.2 state police officers have been assigned to cover about 1000 square mile of the county.
sir i have been listening on radio reference,and my phone app .i will be getting a home patrol this week to see what i am missing
i had heard only 2 officers would be left onwith no road patrol and several state troopers were assigned from flint.Just to clarify, they have not pulled ALL of their patrols, according to the news broadcasts they were going to lose about 1/2 of their officers. Also, Shiawassee County is 541 square miles.
their is a trick to listen to next door counties . the p25 system can be teeeked so fine that scanners can not pick up signals just 2 or 3 miles outside the county unless it is hooked up to a 60 ft tower or higher. but it looks you are in clinton county this trick only works when the next door county operates on the same system, (mpscs). clinton works on the edacs system along with ingham and eaton counties. anyway the trick is as follows:the county that you live in must be the 800mhz mpscs system.(about 2/3 of michigan counties are now working off the 800khz mpscs p25 system) . you program the next door county as you would if you lived there with the major exception..........you program the frequencies that are used in YOUR county along with YOUR counties re-banding info. REMEMBER the next door county MUST be mpscs 800 mhz p25 system as the same county you live in. i live in owosso and can hear livingston, genesee, saginaw, grahm counties everytime, all the time.even useing the supplied antenna when new.
So are you saying if my county has p25 i can listen thru my county to others?I listen to michigan state police here in ingham/eaton county and sometimes can receive Barry county which is just as far as shiawassee in the other direction .I have heard shiawassee county 1 time when their cars were on the western most county line and it was maybe from livingston county tower.
oldgold31 ---
i believe your in eaton county. their primary system is the edac's system. they do have a p25 mpscs system but is not a primary system they have to have some way, in case of a real state wide emergency, to talk to departments outside of their jurisdiction (simocast) , as per the new federal guidelines.and all the problems that were encoutered and discovered during the 911 disaster in new york..the good side is that eaton ,ingham , clinton counties have been useing the edac's system for many years now and their is talk of a new system.but...... then again thats at least 5 years in the making. and that system will most likely be a p25 mpscs phase 2 system .
