Go Back   The RadioReference.com Forums > U.S. Regional Radio Discussion Forums > Michigan Radio Discussion Forum
Michigan Radio Discussion Forum - Forum for discussing Radio Information in the State of Michigan.
Old 03-20-2017, 1:16 PM
Default Not hearing Livingston county
Hello,
Trying to program Liv. Co into my scanner. Its a pro96 and im using Win96. I programmed the Northville tower and input all the Talkgroups I want to here but im not getting anything. I also have local talkgroups programmed such as Northville township and Plymouth township and can hear them fine. I did here one transmission for Livingston county EMS but that was it. Can anyone think of what I am missing here. Ive confirmed all freqs multiple times.
Old 03-20-2017, 3:07 PM
GeneseeCoMI's Avatar
Originally Posted by B1717 View Post
Hello,
Northville is a little outside of their "safety belt" area. Try to pick up something closer to them, i.e. the Howell or Holly towers, or maybe Washtenaw Co Simulcast, or the Southfield or Romeo towers.
Radios: Pro 106, Pro 96, VX-150, ATS-909X, PL-880, SRF-M37W, XML-8110, GP5/SSB, RS NWR, STR-DH130
Antennas: D130J, RH77CA , DPDP Car Traintenna, WSM-225, RS 200-283, ANT-60, AW 44-US13, AN-100
Old 03-20-2017, 3:41 PM
Yea Ill give it a try. I used to listen to Livingston from the Northville tower for years. Then took a break. I dunno what changed. Ill give some other towers a try. I live in Livonia at Plymouth and Newburgh. If anyone has any ideas please post!
Old 03-20-2017, 3:47 PM
Ditto. I've found that it only comes across both the Southfield and Northville towers only sometimes. You really have to use Holly or Howell for guaranteed reception. Never tried the Washtenaw Simulcast but that's definitely worth a shot if you're living in Livonia. Not for sure on the reception of that particular simulcast though.
Pro-106 | Pro-96 | Pro-82 | BC60XLT
Old 03-20-2017, 4:03 PM
Just programmed washtenaw county simulcast. Does not come in clear enough where im at. :-( thanks for the suggestion on that though.
Old 03-20-2017, 6:13 PM
You might want to try putting up an outdoor antenna. I recommend the Diamond D130J.
Old 03-20-2017, 6:55 PM
Ill look into setting up an outdoor antenna but not sure if I will be able to. Apartment complex might be against it. I guess my question is why was I able to hear it all years ago on the Northville tower and now its next to nothing? Im still considered very new to scanning and MPSCS. Is there something im not understanding?
Old 03-20-2017, 7:57 PM
Well if that's the case just get a little 800 MHz antenna. The stock units are usually junk.
In regards to your other questions I'm not sure since I don't go down to that area very often. Do you have talkgroups you want to hear programmed? Is it in closed mode instead of open mode? Is the squelch turned up too high or the attenuation on? Try going outside and see what happens. Being indoors might be blocking the signals. What floor of the building are you on?
Old 03-21-2017, 12:31 AM
RayAir's Avatar
Try just locking onto the control channel to verify the signal strength. If you can receive it well, you're looking at a programming issue.
You could try a wildcard TG (65535) just to see if you are pulling traffic from the site. It could be Livingston County traffic is limited across that site, as others stated.
Cell towers can wipe the receive on many scanners too. If you have full bars of interference you could try attenuation. I can tell you I can receive the Northville site on a handheld as far north as I-75 and M-15. It starts dropping out near Clarkston. So that site does have good range.
KXKYC JBSOB XBMZE LCVHV WCW
Old 03-21-2017, 7:51 AM
drdispatch's Avatar
Check this thread:
https://forums.radioreference.com/mi...-fire-ems.html
Apparently the Howell site lost power in the wind storm and has just recently been restored.
Scanning since 1974
PRO-2004/MCC-5500/BCD436HP/Icom ID-51A
With the push of a button & the sound of my voice, I can send millions of dollars of fire apparatus screaming through the streets.
Old 03-21-2017, 6:29 PM
Originally Posted by drdispatch View Post
Check this thread:
He's in Livonia using an indoor antenna and the Howell tower is about 27 miles away as the crow flies so it's unlikely he'll pick it up.
Old 03-22-2017, 12:27 AM
RayAir's Avatar
Yep.
The Northville site (near him) and him wanting to rx Livingston county traffic, will yield poor results.
I monitored it for a while today. Lots of 82's, some 50's, but no 47's for UID's.
Old 03-22-2017, 9:30 PM
Originally Posted by RayAir View Post
Yep.
Im still pretty new to the scanner world... I thought as long as I had good reception on the control channel I would get traffic? I've got 95% reception of the Northville tower...
Oddly enough right now as I listen I hear tons of traffic on TG 2146 PD dispatch and some on 2147 fire dispatch but miss everything on LCEMS 2148. 2146 is hit or miss. Got some traffic but missing others.
Sent from my SM-G930P using Tapatalk
Old 03-22-2017, 10:09 PM
Sorry 2147 fire dispatch is hit or miss but I'm getting everything on 2146 pd dispatch.
Old 03-22-2017, 11:12 PM
RayAir's Avatar
The system can be set up to deny registration/affiliations of specified groups.
For example, I occasionally see radios assigned to the Genesys Hospital TG get denied registering to the Holly site.
If the TG's you're wanting to receive are not within the service area of the site there's not really much you can do.
I can't give a clear answer cause I do not know exactly what MPSCS TG's are allowed over x number of towers. Basically the system programmers decide this.
Can you pull in the Southfield site?
Maybe there is more Livingston traffic on there.
Anyway, at least you're getting some of the traffic you're after.
Old 03-22-2017, 11:14 PM
I'll have to try the Southfield tower after work tomorrow. I don't understand why 2 days ago nothing came through and now all the sudden I can here PD.
Old 03-23-2017, 12:30 AM
If the traffic isn't affiliating with the site your scanning you won't hear that talk group. It doesn't mean there isn't any traffic. You shouldn't expect to hear Livingston county on Northville unless a user drifts down that way. It may very well be hit and miss.
Old 03-23-2017, 3:29 AM
Ok I think this is what I was not understanding. So when someone keys up and it actually goes through the tower I'm scanning I'll hear that talkgroup. If not I wont.
Old 03-23-2017, 4:13 AM
krokus's Avatar
You will do better with the Washtenaw towers, as more units will be affiliated with the towers.
Sent via Tapatalk
Old 03-23-2017, 8:36 AM
That is correct. Traffic is only carried on the tower which the radio is affiliated with. Washtenaw should be on your list if you can receive it from your location. Back when the state built this system it was originally designed for the state police and for mobile coverage. That changed once they allowed other agencies to come on and those agencies built simulcast systems. Abesent that the state hasn't put up many new radio sites and probably won't anytime soon. Oakland county is a GREAT example, tons of MPSCS users go there and it's crap coverage to be nice about it. (Yes I know Oakland has there own)
Tags
livingston county, michigan
