Go Back   The RadioReference.com Forums > Regional Radio Discussion Forums > Michigan Radio Discussion Forum
Michigan Radio Discussion Forum Forum for discussing Radio Information in the State of Michigan.
Old 05-03-2006, 04:47 PM
MacombMonitor's Avatar
Exclamation Mt. Clemens Underground Explosion Reported!
Mt. Clemens, downtown, underground explosion reported! Possibly under a building. Numerous 911 calls coming in, numerous cars on fire, calls going out for additional support. They are evacuating the Court House.
MacombMonitor
Old 05-03-2006, 04:48 PM
wjf wjf is offline
I think it's at Macomb Place and Main.
Old 05-03-2006, 04:51 PM
This is confirmed that it is not a drill or a test!
MacombMonitor
Old 05-03-2006, 04:54 PM
My wife works down there! She is OK thank God! She said she sees a lot of smoke, and cops & fire running all over the place. She couldn't talk, as they were evacuating her building as well.
MacombMonitor
Old 05-03-2006, 04:56 PM
wjf wjf is offline
From my deck I hear tons of sirens - and I'm in Clinton Twp.
Old 05-03-2006, 05:08 PM
Hope all of you stay safe up there.
Old 05-03-2006, 05:14 PM
I haven't heard of any injuries, or rescue request...that's a good thing! The wife thinks the explosion occurred where there are some stores, and shops. On her way home she saw several MSP cars still responding at a high rate of speed.
MacombMonitor
Old 05-03-2006, 05:21 PM
Ch7 News is claiming a car crashed into a power pole and a transformer on the pole exploded, causing a chain reaction of power problems, and underground explosions. Numerous Edison trucks are staged on the scene waiting for the OK to proceed. They showed a man hole cover that blew out of the sidewalk, and burned off a decorative awning above it. Smoke was still coming up from that opening. Maybe underground transformers...possibly Methane gas?
MacombMonitor
Old 05-03-2006, 05:29 PM
wjf wjf is offline
Edison is shutting off the power to the area in a few minutes.
Old 05-03-2006, 05:37 PM
Apparently it originated in front of the Emerald Theater, per Fox2News.
MacombMonitor
Old 05-03-2006, 08:27 PM
Question
Anyone know if the County Government buildings will be open tomorrow?
MacombMonitor
Old 05-03-2006, 10:03 PM
wjf wjf is offline
According to Fox2 a moment ago, yes.
Old 05-04-2006, 10:35 AM
Explosions rock Mount Clemens
http://www.macombdaily.com/stories/0...osion001.shtml
MacombMonitor
Old 05-04-2006, 11:29 AM
gregg22's Avatar
Default under ground explosion
this happens 3 or 4 times a year in detroit,I guess they are just used to it.as these lines age in royal oak mt clemens and detroit and a few other places it will happen again
Old 05-05-2006, 08:47 PM
From Someone that was 2 blocks away, it was a serious Charlie Foxtrot!! But all agencies once on scene did QUITE well!!
Last time this happened in The Clem was about 8 yrs ago, by the old Macomb Daily building. That time it took the manhole cover about 12 feet in the air.
Edison denies it was caused by the pole accident on North Ave. they said, and I quote "too many people turned on their air conditioners at once" ( read on fox2 website)
This was a classic "cascade failure" one goes, and it just starts going from there... Like the blackout of 2002.
Glad it was only a couple hours as opposed to a couple days!!
Paul, KC8BDK
EC/RO Macomb County ARPSC
Old 05-05-2006, 11:01 PM
garryd451's Avatar
Location: Pokagon, Michigan, half way between Niles and Dowagiac
Send a message via ICQ to garryd451 Send a message via AIM to garryd451 Send a message via MSN to garryd451 Send a message via Yahoo to garryd451
Yes, it could happen again. AEP(American Electric power) or Indiama Michgian Electric (they switch the name every decade) equipment did this four or five times in a three year period in Downtown South Bend, Indiana. Eventualy AEP put in all new equipment and there hasn't been an explosion since the new equipment was installed!
Garryd451 in
Pokagon
Old 05-06-2006, 12:00 AM
Back in the mid 1980's I worked for General Electric as Technical Support Engineer of Industrial Sales. I had to visit the Renaissance Center in downtown Detroit. Underground they had numerous large power transformers that were overheating, and some had actually exploded, and caught fire! I had to inspect them and determine why this was happening, and come up with a solution. It turned out to be rather simple. In the base of the transformer cabinets, they had large cooling fans that drew in cool air off the floor, and directed it up though the transformers. The problem was that these cooling fan motors were vented on each end, to cool themselves. They were sucking up dust bunnies, and clogging the vents, causing the cooling fan motor itself to over heat, and burn out. This stopped the cooling of the transformer, causing them to overheat, and burn up! The fix was to replace the cooling fan motors with one that was sealed, non-vented, with a higher service factor. Problem solved.
MacombMonitor
Old 05-06-2006, 12:10 AM
You would think their systems would be designed to cope with that. In fact, I'm quite certain they are. It wasn't even hot that day, maybe warm, and I have to believe the demand was no where near what it's been on a normal HOT summer day. Don't they have a system to purge those tunnels of explosive gas build-up? A normal circuit breaker tripping in an explosive atmosphere could have triggered the event.
Maybe Macomb County installed an "Electric Chair" we don't know about, to solve the overcrowding in the County Jail!
MacombMonitor
Old 05-11-2006, 09:26 AM
Default Cause of blasts is still a mystery
DTE says explosions in Mount Clemens may be result of failed gas line, methane buildup.
http://www.detnews.com/apps/pbcs.dll...605050350/1014
MacombMonitor
Similar Threads
Mine Explosion and Rescue jimmnn West Virginia Radio Discussion Forum 16 01-21-2006 09:26 AM
Run coax underground? jrs71 Antennas and Coax Forum 8 08-15-2005 06:44 AM
Explosion & fire in my neighborhood 6/29a.m. N5TWB Oklahoma Radio Discussion Forum 5 06-30-2005 12:53 AM
Calgary, AB: Explosion / 2nd Alarm Jay911 Western Canada Radio Discussion Forum 4 05-24-2005 09:25 PM
Rankin explosion milf Mississippi Radio Discussion Forum 0 12-14-2004 02:51 PM
