| Michigan Radio Discussion Forum Forum for discussing Radio Information in the State of Michigan. |
08-07-2006, 02:36 AM
Talk Group 2356
I have been hearing TG 2356 (Monroe City Dispatch) tonight here in Grand Rpaids. I have two banks in my PRO96 on open mode with the V-scanner set up for Michigan from the factory. Last night I was hearing Kalamazoo PD. I am thinking it is a good night for skip. Makes me wish I could have my antenna mounted on the top of my apartment building!
PR0-94
PRO-95
PRO-96
PRO-2055
PRO-2052
Bearcat 996T
Bearcat 101
Bearcat 560
Bearcat Four-Six
Icom IC-PCR100 (2)
Uniden MR8100
08-07-2006, 09:43 AM
I don't think that there is much skip with MPSCS. More than likely a radio on the system in your area was set to monitor monroe, so it would be broadcasting off your local tower.
I've heard an upper Michigan County sheriff TG from here in SE Michigan before loud and clear for the same reason.
08-07-2006, 09:56 AM
Did you verify what tower you were getting? Also the factory Vfolder for the PRO96 has many errors.
08-07-2006, 11:28 PM
You were not getting the Monroe tower from GRR - just had someone from Monroe City PD in your area. Skip is not an issue with MPSCS.
08-08-2006, 12:50 AM
You mean it is not possible for 800MHZ to skip?
PR0-94
PRO-95
PRO-96
PRO-2055
PRO-2052
Bearcat 996T
Bearcat 101
Bearcat 560
Bearcat Four-Six
Icom IC-PCR100 (2)
Uniden MR8100
08-08-2006, 01:28 AM
Skip only affects low band. Tropospheric ducting, however, affects 800 MHz as well as UHF and high band.
08-08-2006, 03:41 PM
Odds of skip or tropo affecting all frequencies of a trunked system at the same time, with enough power to overload the local tower you're already receiveing, are nil.
08-08-2006, 03:55 PM
The last time we got into this discussion it was getting Downriver TG's in the UP, and when the person finally ran PRO96COM, it showed radio's from the Downriver area at the Prison in the UP.
08-08-2006, 04:05 PM
I get that talkgroup on towers 307 and 325, neither of which are in Monroe Co.
08-08-2006, 04:15 PM
That's just showing the system is working. If a radio is out of it's area, it will still get it's home TG or what ever TG it's tuned to, on the nearest tower. That's just an extra bonus for scanners.
08-09-2006, 12:28 AM
Thanks for all the infor and insite!!!!!!
PR0-94
PRO-95
PRO-96
PRO-2055
PRO-2052
Bearcat 996T
Bearcat 101
Bearcat 560
Bearcat Four-Six
Icom IC-PCR100 (2)
Uniden MR8100
