Go Back   The RadioReference.com Forums > Regional Radio Discussion Forums > Michigan Radio Discussion Forum
Michigan Radio Discussion Forum Forum for discussing Radio Information in the State of Michigan.
Old 11-27-2006, 05:10 PM
MONROEUSER's Avatar
Question Scanner issue
I just put a permanent mount antenna in my vehicle. Since then my 2096 has a whistle that gets higher as I give more throttle. Will one of the those filter/antennuators from scanner master fix that. Or what do I need to get?
Old 11-27-2006, 05:14 PM
Sounds like you have a bad Ground. yes Try regrounding it or try to run anouther Ground. and try a filter.
Old 11-27-2006, 06:42 PM
Send a message via AIM to scannerman5000 Send a message via Yahoo to scannerman5000
i get it too. dont feel bad. i havent done anything about it, but hey it sounds beautiful (lol).
Merry Christmas
Pete
Old 11-27-2006, 09:44 PM
pinetree's Avatar
Check out this forum same radio same problem
The RadioReference.com Forums > Topic Specific Forums > Install Discussions - Mobile and Base
Alternator whine
Dave
Old 11-28-2006, 03:24 PM
MONROEUSER's Avatar
thank you
Old 11-28-2006, 10:27 PM
Try a few things:
1. Take the antenna off the mount. Does the whistle go away? If so, it's coming thru the antenna. Try making about 5 or so 6" diameter loops in the coax with wire ties near the antenna mount.
If the whistle stays when you take the antenna off, it's probably coming in on the power to the radio. If it's in the power, go buy some clamp on ferrite chokes like you see on the power cord for a computer and put on the power leads near the radio.
2. Is it a GM? If so, run the power straight from the battery, along the LEFT fender. This is the GM recommended way for two way radio power. Fuse both the negative and the positive at the battery, and fuse the hot side again at the radio.
I'm not saying any of this will work, but it just might.
Old 11-29-2006, 01:26 AM
MONROEUSER's Avatar
Default thanks
OK. I will give that a shot. Thank you everyone for the advice. I will let you know what works.
JJ
Similar Threads
Uniden BCD396T Price/taking orders rankin6 Uniden Scanners 3 09-09-2009 08:20 AM
A Good Invention I created today to mount a scanner in a car Cobra_Commander General Scanning Forum 31 03-20-2008 10:57 AM
Another Newbie Help Selecting Scanner jbitzer Radio Shack Scanners 12 01-21-2007 11:59 AM
Scanner Issue!!! scannerman200 General Scanning Forum 18 11-15-2006 04:11 PM
RadioShack Closing 400-700 Stores antfreq Tavern Archives 28 02-25-2006 09:13 PM
