Go Back   The RadioReference.com Forums > Regional Radio Discussion Forums > Michigan Radio Discussion Forum
Michigan Radio Discussion Forum Forum for discussing Radio Information in the State of Michigan.
Old 12-04-2006, 11:33 AM
MichMar's Avatar
Default Seeker 800 MHz antenna
Does anyone have this antenna? Does it work noticeable better than the 800 MHZ antenna from RS? Does this fit the PRO-96 scanner?
Old 12-04-2006, 11:44 AM
wjf wjf is offline
http://www.radioreference.com/forums...ad.php?t=50999
Old 12-04-2006, 12:02 PM
MichMar's Avatar
Hmmmm, so it might not work outstandingly better than the RS 800 MHz, but will bring in more of the VHF frequencies better? Might be worth it...
I can get several conventional frequencies that are further away better on the PRO-2096 with the adjustable antenna than I can on the PRO-96. Makes me jealous of the base unit I got for my mom for Xmas, but I wanted the portable for myself since I can put batteries in it if the power goes out.
Old 12-05-2006, 04:03 PM
I have one which I primarily got because of weak reception of the Saginaw County analog trumk system. The stubby that comes with the radio works fine for the MSP digital system but the analog one was quite noisy. When I switched to the Seeker it helped quite a bit and I can now copy the analog system quite well. It also seems to work fine for VHF stuff as well.
Tom, in Frankenmuth
Old 12-06-2006, 08:53 AM
MichMar's Avatar
Okay - thanks. Just to make sure, the Seeker 800MHz DOES fit on the PRO-96, right?
Old 12-06-2006, 09:02 AM
GreatLakes's Avatar
Yes. Be careful, don't poke your eye out!
Similar Threads
METCAD (Champaign County) NEW 800 MHz ASTRO Trunked System cubn Illinois Radio Discussion Forum 42 10-16-2008 07:14 PM
700 and 800 MHz. in the same site? N9JIG Motorola Forum 7 11-09-2006 07:03 PM
FS/Watson W 889 Watson, Telescopic 25-1900 MHz Scanner Antenna Wilf11 Old Classifieds Archives 5 09-26-2006 01:46 PM
base antenna for 800 mhz.. pinellasfirefighter Antennas and Coax Forum 7 07-31-2006 07:53 PM
FS EF Johnson 800 MHz Mutil Net Radios K9EMA Old Classifieds Archives 0 06-21-2006 04:56 PM
