Go Back   The RadioReference.com Forums > Regional Radio Discussion Forums > Michigan Radio Discussion Forum
Michigan Radio Discussion Forum Forum for discussing Radio Information in the State of Michigan.
Old 12-17-2006, 12:16 AM
ceranes's Avatar
Default Ingham Co. EDACS Feed
I just finished setting up a server running a feed of the new Ingham County EDACS system. You can access it using the downloadable software from http://www.butel.nl/easy/eazystream_clientsetup.zip. I can only allow 19 users to connect at once. Please try this out and let me know if you have any problems or concerns.
Thanks,
Chris Ranes
ceranes@sbcglobal.net
Old 12-17-2006, 12:27 AM
SEMTTP's Avatar
Send a message via AIM to SEMTTP Send a message via MSN to SEMTTP
Tried to access the site in Mozilla and IE and it goes nowhere.......perhaps a bad link?
Eric-KB8UYC
Dispatcher for FNNM(fnnm.net)
http://flickr.com/photos/erchambers
http://kb8uyc.wordpress.com
Old 12-17-2006, 01:01 AM
fnnm1062's Avatar
i have the same problem, link goes no where
*Member and Dispatcher for the Fire Notification Network of Michigan paging system - www.fnnm.net
Old 12-17-2006, 01:15 AM
emtroberts's Avatar
I went to that site and there is no link for ingham County.
Old 12-17-2006, 08:29 AM
ceranes's Avatar
Okay, after I got up this morning, I found out the server software had shut down at somepoint this morning. I just restarted it. Go to http://www.butelsoftware.com. Look for the link that says "download and install the free ARC-EazyStream client". Check to make sure you have the DNS entered correctly within the client software, scaningham.hopto.org. Also, make sure you have port 8100 entered for audio and port 8101 entered for the data. Oops, I forgot to enter the server DNS and port numbers in my original post. Sorry about that! It was late when I wrote it!
Thanks,
Chris
Old 12-17-2006, 11:59 AM
SEMTTP's Avatar
hmmm....
Followed your instructions and all I get is a green box in the STATUS area, then it turns red and then goes back and forth....no audio
Could anyone else hear anything?
Eric-KB8UYC
Old 12-17-2006, 03:45 PM
Your DNS address of scaningham.hopto.org is pointing towards your local address of 192.168.0.100. You need to open the two ports of 8100 and 8101 on your router and point them to 192.168.0.100 then change the DNS to point to your outside IP address that you receive from your ISP. Most likely you will still be able to use that domain name inside your home network, although I have seen cases where it will not.
Chad Rust
KD8AYM
rustchad@msu.edu
Pro-2049 / Pro-94 / Pro-99 / BC895XLT / BCT-15
Yaesu 7800 / Yaesu 8800 / Yaesu FT-60R
Old 12-17-2006, 06:30 PM
ceranes's Avatar
Try it again. I think I may have fixed the problem, but then again maybe not. I used the website http://www.no-ip.com to obtain a free DNS name. I've included a copy of the port-forwarding table on my router and then what I was advised to do in the help section of the website above. Please look at these two things and let me know if you think they are set up properly.
Thanks,
Chris
Old 12-17-2006, 08:00 PM
ceranes's Avatar
It appears to be working now according to another gentleman in Virginia. Please check it out now and let me know if you think the audio needs adjusting or if it's fine the way it is.
Thanks,
Chris
Old 12-17-2006, 08:43 PM
SEMTTP's Avatar
I followed the other thread too....Chris once I put that IP address in there bam it started working....sounds great! I am in Washtenaw County and I can barely hear the control channel so it is nice that you have done this....sounds good!!
Merry Christmas to you and yours.....
Eric-KB8UYC
Old 12-17-2006, 08:46 PM
Sounds great. Thanks!
Chad Rust
KD8AYM
rustchad@msu.edu
Old 12-17-2006, 08:59 PM
ceranes's Avatar
Great! I'm glad I am able to have this for you guys. Do you know if you can monitor this stream externally with Media Player or Real Player instead of having to load the ARC software? I'm mainly concerned about monitoring it from work where I can't load the xtra software.
Chris
Old 12-18-2006, 02:52 PM
emtroberts's Avatar
Sounds great.
Old 12-18-2006, 03:20 PM
I'm pretty sure there's no way around it, to use something 'normal' (RealAudio) you'd need to use my LFD link at firefeeds.com
Old 12-18-2006, 05:53 PM
Send a message via AIM to hazard78 Send a message via Yahoo to hazard78
Default Ingham
Seems to work, But audio is very low even with it up all the way. any chance of mpscs like this?
nick
Old 12-18-2006, 07:32 PM
Sounds good. Low audio but its good
Old 12-19-2006, 03:27 PM
emtroberts's Avatar
Is it not working today?
Old 12-19-2006, 04:54 PM
Not working for me either!!
Old 12-19-2006, 05:37 PM
ceranes's Avatar
I've taken it offline temporarily. Someone during the night decided it would be funny to connect to my computer and mess around. I'm in the process of making it more secure and will have it up and running shortly! Sorry for the inconvenience.
Chris
Old 12-19-2006, 06:45 PM
ceranes's Avatar
Alright...It should be up and working now. Give it another try! I'm going to try and fine tune the audio too.
Chris
Similar Threads
Ingham County EDACS Control Channel n211cr Michigan Radio Discussion Forum 0 11-12-2006 07:19 PM
Ingham EDACS Help Willington79 Michigan Radio Discussion Forum 7 08-12-2006 11:23 PM
arc 246 software and ingham edacs lsr1428 Michigan Radio Discussion Forum 0 05-23-2006 09:29 AM
Ingham EDACS - BC296D & 396D ceranes Michigan Radio Discussion Forum 2 01-20-2006 05:18 PM
Need help- Pro-95 Washoe EDACS Win95 file. nevadasky Nevada Radio Discussion Forum 1 02-25-2005 03:45 AM
