Go Back   The RadioReference.com Forums > Regional Radio Discussion Forums > Michigan Radio Discussion Forum
Michigan Radio Discussion Forum Forum for discussing Radio Information in the State of Michigan.
Old 05-03-2007, 01:11 AM
i5adam8's Avatar
Default Problems monitoring EDACS on Rs.scanners
Just wondering if anyone else is having problems monitoring the Ingham co. EDACS system on the pro-96 or,2096.I can track the system with them,but I miss parts of the transmission,it's like it cuts off the first couple seconds and,somtimes competely misses them.I monitor the system on my old Rs. 2052.and it works fine....any suggestions?
Old 05-03-2007, 08:03 AM
Location: Nashville, MI-Barry County(Near G.R. & Ionia)
Send a message via ICQ to Skud
I have been listening on my pro 96 and pro 97 and can't say I have any problems. How about it you try to monitor the EDAC of Consumers energy and see if they are ok. If you haven't as well you could try the firmware upgrade to see if that helps. Of course I have never had any problem listen to EDAC on my pro 96 since I got it about a year ago
PSR-500 | Pro-96 | BCD996T | PSR-600
Webmaster http://westmichiganscan.com
ID Tracker Website
Old 05-03-2007, 09:14 AM
fmon's Avatar
Do you have the first frequency in channel 0 of the bank? If so, move all frequencies down one position starting with channel 1.
EDACS systems don't recognize channel 0 in LCN assignments. Your 2052 doesn't have channel 0.
Frank
RR Wiki Programming Shortcuts
Old 05-03-2007, 11:50 AM
if you do have the channels starting at 1 and 0 if empty let me know if it is any better today as they again switched there control channel again. It is back to LN7 and I get better reception when they have it on 7 and not 3
ID Tracker Website
Old 05-04-2007, 08:30 AM
Maybe someone can clear as to why the Control Channel on the Ingham County EDAC system changes so much. In the last two weeks the control has gone from CHns 7 to 3 to 7 to 3 and then to 5 as of last nite.
I wasn't sure if maybe just mainteance or another issue.
ID Tracker Website
Old 05-04-2007, 09:59 AM
Seems like it's always been changing now and then...
Old 05-04-2007, 10:55 AM
Out of all the EDAC systems I monitor that was the first one. I get better reception when the Control is at LN7. No wonder my reception has been going good then bad and back and forth.
ID Tracker Website
Old 12-20-2007, 04:16 PM
i5adam8's Avatar
I have Freqencies in there properly(starting at 1) I think it is the radio system itself,somtimes when I'm at the Ambulance base one of the portables will be on in the charger,and it may miss a few seconds of what the base radio picks up,and vice versa.
Old 12-21-2007, 03:48 AM
That'd be a reception issue, try a different antenna. I've not noticed that in Lansing.
Old 12-21-2007, 06:01 PM
N8DRC's Avatar
Send a message via AIM to N8DRC
Haven't had any issues here with it here on my 2096 or 96..I am using a Scantenna on the 2096 and a RS800 duckie on the 96..
73
Dan
Old 12-22-2007, 01:04 AM
i5adam8's Avatar
This actually happens with the MA COM Radios themselves I've noticed.
Old 12-23-2007, 08:19 AM
It's probably a reception issue, try a different location...
Similar Threads
San Antonio EDACS system and the press blantonl Texas Radio Discussion Forum 8 05-03-2009 12:53 PM
Aurora EDACs programming Pro-96 NW0U Colorado Radio Discussion Forum 16 01-17-2007 11:35 PM
Pro 95 Audio problems tx2654 Radio Shack Scanners 17 12-30-2006 02:18 PM
Need EDACS tracking software W4UVV Trunking Forum 4 12-22-2005 10:19 PM
PRO-2051 EDACS Programing Help Please TrunkerNewbie Radio Shack Scanners 2 10-08-2005 10:35 PM
