Hello,
Which scanner are you using. You have to have a digital scanner to monitor WMU PD. If you do have a digital scanner then you have to program the WMU Trunked System in.
Digital here, BC796. The group of freqs I programed are here: http://www.radioreference.com/module...ame=RR&sid=752
I just programed the red control channels in and not the others, which I'm assuming is ok for this system.
Programming the control channels should be alright. I use a PRO-96 and not very knowledgeable with Uniden Scanners. WMU police is usually very quiet except on weekends and during special events.
