If you put the scanner in search, and key up on the TG it will show up (I assume you have access to an 800, at least on some of the desired TGs).
I find that the scanner and the radio have to be seperated several feet apart as the output of the radio will overpower the signal the scanner is trying to hear from the tower and the TG number that comes across is garbage.
as heard on MPSCS:
"Dispatch, how do you read this unit?"
"Loud and clear...err...well...as clear as this digital stuff can be, I guess..."
