Go Back   The RadioReference.com Forums > Topic Specific Forums > Military Monitoring Forum
Military Monitoring Forum Discussions regarding monitoring military communications
Old 03-01-2009, 02:25 PM
Send a message via ICQ to mparker Send a message via Yahoo to mparker
Default looking for cheep scanner to do mil freqs
i am trying to find a cheep (<$100 under $50 would really make the accountant(wife) happy) that can listen to mil freq out of the box, or a cheepie that can be "tweeked" to listen to mil...
it will strictly be for taking to the airshows...
thanks guys...
Old 03-01-2009, 02:32 PM
Default Cheap Scanner for Military Aircraft
I was going to say pick up a Radio Shack Pro-2052 on Ebay. But that is more for listening at home.
You might try a Uniden BC250D without the digital card. You might get one for around $100.
Old 03-01-2009, 02:34 PM
ok...
it would be nice if i could find a wideband, but i would guess thats going to be a bit more than $100... an Icom R10 would be nice... :-)
Old 03-01-2009, 03:07 PM
Wiki Admin
The older RS handhelds - including the venerable PRO-43 - might be candidates, if they're in good shape. In fact there were a couple of the PRO-4x models that were supposedly excellent milair handhelds, but the 43 is very much a legend - and hard to find. 73 Mike
Old 03-01-2009, 03:16 PM
w8jjr's Avatar
Send a message via AIM to w8jjr
Or the Pro2004-2006 radios.
These were - are excellent milair radio's.
Once again hard to fine but I see them here and on ebay at times.
Jim
W8JJR
Old 03-01-2009, 03:46 PM
DDan's Avatar
I had a pro-2004 that was excellent on mil-air and I'd like to have another. It would not be too hot for carrying to an airshow like the OP intends though.
73 de Dan/w6kru
Yaesu FT-857 FT-90 VX-170 VX-3
BCD396XT BCD396T PRO-90 PRO-2050
Base RS 20-176 / Maxrad MFB8133 & MYA8256
Mobile Maxrad MUF8043
http://dansracephotos.com
Old 03-01-2009, 04:13 PM
would something like the Yaesu VR-120D or ICOM IC-R2 do mil scanning... universal has the yaesu for $139... thats defiantly doable also....
but maybe my money would be better spent on an older bc250 without the digi card... ???
i was just thinking more along the wideband lines...
Old 03-01-2009, 05:00 PM
w8jjr's Avatar
I see there is 2004 in the forsale forum right now
Jim
W8JJR
Old 03-01-2009, 05:17 PM
Wiki Admin
He did say he would want to take this to an airshow; a 2052 or one of the 200x series would be a bit big to be carrying around - unless he was tailgating.....73 Mike
Old 03-02-2009, 02:10 AM
shaft's Avatar
Pick up a used Pro-97, it will do just fine for what you want to listen to. You can get one for 50 -100 bucks used.
Old 03-02-2009, 12:05 PM
eorange's Avatar
I have a Yaesu VR-500, and a FT-60 ham transceiver; both do great on mil air. I had a VX-1R that also did great on mil air. Given the apparently common bloodlines of these radios, I'll bet the VR-120D would work just as well. But I've never used one.
Now here's the slight caveat:
I looked up the VR-120D's specs on Universal's web site, and there's a couple of tiny gaps in coverage there:
339-340, 351-352, 372-373, 384-385, 396-397
UHF Mil Air is 225 - 400 MHz. Yaesu does this to eliminate any possibility of cell phone image reception, which really stinks. But these are pretty small gaps.
You'd also want to confirm that you can switch the receive mode to AM in the 225-400 range; that is crucial. Same goes for VHF Mil Air in the 137-144 MHz range.
KA3FYU
Old 03-02-2009, 12:14 PM
eorange's Avatar
Just found the manual online; it looks like this can be done. Not surprising because the general operation is very similar to all my other Yaesu handhelds.
KA3FYU
Old 03-02-2009, 09:07 PM
man, i am really confused as to what to do...
universal has the Yaesu 120 used for 99 and i an 100% confident to buy from thoes guys...
but there are also pro 97, pro 94, bc250 for under $100 too...
just not sure what would suit me better... the yeasu is really nice, perfect size for mobile scanning, but i am unsure how it works without a keypad. is it just strickly a scanner, or can you scan programmed freq also...
Old 03-03-2009, 08:16 AM
eorange's Avatar
The VR-120D works a lot like my former VX-1R. You can scan preprogrammed ranges, but you can also program specific freqs and scan them. To program the freqs, you have to keep twisting the knob on the top till you get the freq you want, then push a button to store the freq. It's not the most friendly thing.
I don't know how the PRO-97 does on mil air. But it has a keypad, better usability, and definitely better alpha tags. I wouldn't want to use the VR-120D as a primary scanner; it would be nice for a backup scanner. Hope this helps.
KA3FYU
Similar Threads
I see there are freqs gaps in the mil freqs 800 range videorov Military Monitoring Forum 1 08-20-2007 04:10 AM
Mil Freqs... spiritwolfpr Military Monitoring Forum 2 05-25-2007 10:23 PM
Cochise County Scanner Freqs lowerslowerarizona Arizona Radio Discussion Forum 1 07-10-2006 08:59 PM
12 Days of Scanner Christmas b7spectra Tavern Archives 1 12-13-2005 03:58 AM
Scanner Freqs For Hampshire Co, Hardy Co, and Morgan Co. cbvfd_wagon_13 West Virginia Radio Discussion Forum 4 01-05-2005 02:05 PM
