matt, it's also important to realize that no matter what scanner you are using, getting an antenna like a ScanTenna, discone or the DPD ones is going to significantly increase your chances of hearing activity. Here, a duckie or a little indoor antenna is going to not going to perform very well, unless you're fairly close to an airport, air route or mil base 73 Mike
