Go Back   The RadioReference.com Forums > Topic Specific Forums > Military Monitoring Forum
Military Monitoring Forum Discussions regarding monitoring military communications
Old 07-26-2009, 09:29 PM
JLM7424's Avatar
Default Radio Pirates Hi-Jacking Satcom Freqs !
Hearing Foreign Speech and Even Music On: BCD396T / watson w-901
257.15 Fm
255.55 Fm
Anyone else Getting these ?
****NEVER MIND DID GOOGLE SEARCH ON PIRATES AND SATCOM GUESS IT'S BEEN GOING ON FOR AWHILE *****
My Signal Interceptors.... | Yupiteru MVT-7100 | Psr-600 | Bcd-396T |
Old 07-26-2009, 10:56 PM
Most of the pirates were in Brazil and they had a big raid on them recently. It seems they didn't get them all.
prcguy
Old 07-27-2009, 02:03 PM
255.55 is the busiest channel for the pirates. If you have a good enough antenna and preamp you can hear 6-10 different frequencies active during the day. I don't think the guys who were caught got much punishment because these guys are as busy as ever. Also these satcoms are used very infrequently by the military.
Current radios 2 Xts-5000 vhf ,1 UHF Xts-5000, Xts-3000 uhf , uhf Xtl-5000 ,Motorola Urc-101,prc-113B, MBITR, and various scanners
Old 07-27-2009, 05:20 PM
JLM7424's Avatar
Working on a better setup at home just have a nmo vhf w/base kit cut to 155 on the roof
but thats all we mainly have around home gonna get a base uhf antenna for 225-400
and put it on the roof . Just bought my yupiter mvt-7100 (enroute to me ) maybe it will pick up and be even more sensitive then the 396t.
Their seem's to be quite a few Youtube Vids up of video of scanner and audio of satcom transmissions
Youtube Search ->Satcom.
I Drive a semi truck for a livin so i like seeing where all i pick up the satcom the best, last night
was pretty decent 40 miles East of Providence,RI.
Old 07-27-2009, 05:57 PM
zguy1243's Avatar
Send a message via AIM to zguy1243
You will like the yupi 7100, very hot receiver for 225-400Mhz.
Listening To The Skies:
Watkins Johnson 8617-B
Watkins Johnson 9518BE
Racal RA6790/GM
Racal RA2309B
AN/URC-110
BC895XLT
Pro-2042
Pro-2045x4
BC898T
www.Signal-Intelligence.com
Old 07-30-2009, 08:18 AM
FrankJ's Avatar
Yes, the Yupiteru MVT-7100 is a VERY sensitive radio, but it's probably going to overload when connected to a rooftop base antenna. Your better off sticking with your Watson W-901 or a custom tuned antenna for the UHF SATCOM band.
I got a 260 Mhz custom tuned rubber duck from below. Works great on my Realistic PRO-43 and it only cost me $16.00 plus shipping! I hear those "pirates" all the time!
Smiley Antennas
Old 07-30-2009, 09:16 AM
commscanaus's Avatar
It really amazes me that there are still birds that are analog let alone being able to pirate them!
Any wonder the military don't use them often.
Occasionally I can hear foreign languages in the clear in this band- but I lack a decent antenna and I am in the wrong hemisphere for most of the action.
Commscanaus.
Old 07-30-2009, 09:14 PM
JLM7424's Avatar
I could Use Some Advice from you guys Thinking about buying this antenna and making it in to some sort of portable antenna .
Thoughts ???
AS-1404/PRC-41 UHF Portable Radio Antenna
Frequency range: 225-400 MHz
This antenna covers was originally mounted on the N type female connector on top of the AN/PRC-41 Radio Set. It can be adapted to other applications. The base of this antenna fits a type N panel or bulkhead receptacle. Dimensions: 24 inches long by 1.5 inches in diameter.
****FRANK J. **** Thankyou for the smiley link Just orderd a (( 5/8 Slim Duck | BNC | 250mhz ))
Thanks !!
Old 07-30-2009, 11:51 PM
Its an elevated coaxial dipole and a great little antenna for mil air. I have a few but have never put them to good use. You could mount an N type bulkhead female adapter on an L bracket and make it a portable or permanent mount antenna.
prcguy
Thoughts ???
Thanks !!
Old 08-06-2009, 09:02 AM
FrankJ's Avatar
Sure.......Let us know how the Smiley antenna works on the UHF SATCOM's. I was thinking of getting one custom tuned to 300 Mhz (center of the 225-400 Mhz Band), but not sure if it will work any better than the 260 Mhz custom tuned duck that I have????
Frank
Old 08-06-2009, 09:12 AM
JLM7424's Avatar
Frank
I,am Not sure Frank I called and asked Smiley if they could make me a custom "Broadbanded ant. to cover 225-380 they said they cant and that their antennas are good for about 10 mhz each way so i dunno.
we shall see when i get mine.
I Was using teloscopic bnc yesterday in lansing,mi got a bit of Brazzilian Chatter on
255.550 Fm All on all 3.
258.550
262.200
See what i get to day I,am in harrisburg,Pa
I Drive a truck for living , has it traveling pluses
Old 08-07-2009, 11:20 PM
FrankJ's Avatar
I think Smiley's "custom" antennas are somewhat broadbanded. The 260 Mhz custom duck that I use for UHF SATCOM monitoring works in the 422 to 430 Mhz bands, so I'm sure it will pull in signals in the upper part of the 225-400 Milair band (above 260 Mhz). It's not as good as the Diamond RH77CA in the upper range, but it does pull in signals. That's why I use the Diamond for "wide-band" coverage.
Frank
Old 08-08-2009, 01:07 AM
The Maldol AL-500H works much better than the stock antenna on my PRO-43 for UHF satcom.
Old 08-08-2009, 09:08 AM
FrankJ's Avatar
I don't even know where my PRO-43 stock antenna is anymore! I forgot to mention, even the Diamond RH77CA works well for UHF SATCOM signals......
Frank
Old 08-23-2009, 12:12 AM
i ordered an antenna (slim duck 5/8 cut for 265mhz. would that be ok to pick up satcom on 243mhz as well as the 260mhz? should i have ask for them to cut it for 255mhz. thanks in advance.
oh btw, i just purchased a yupi 7100 and can't wait to see how it handles the satcom reception.
Old 08-23-2009, 12:20 AM
JLM7424's Avatar
Well Smiley told me 5-10 mhz each way so say 7 up 7 down i guess yupi-7100 works NiCE on
255.550 fm 258.550 fm 262.200 fm <---proper <--//I use 262.198 fm Squelch near open or sometimes wide open, It gets Even sweeter with my Jim M75 Amp +7db.
Old 08-23-2009, 10:11 AM
FrankJ's Avatar
Where are you guys finding the Yupiteru MVT-7100, E-bay? I know it was discontinued several years ago. BIGGEST mistake of my radio hobby was selling mine a few years ago! That was one great scanner. I even used it for some decent HF SSB listening. It did a real good job on milair and SATCOM.
I wish I could find another, but the PRO-43 seems to handle the airbands pretty well.....
Frank
Old 08-23-2009, 10:16 AM
FrankJ's Avatar
I'd try the 265 Mhz Smiley antenna on a 220 Mhz ham band signal, if there's one in your area. If it picks up pretty well, then I think it should work well on milair freq's below 265 Mhz.
My 260 Mhz Smiley does well there. I think those "custom" antennas are more "wide-banded" than they advertise!
Frank
Old 08-23-2009, 01:12 PM
Hi Frank, When I ordered my Yupi 7100 there were three of them from different sellers. Now the only one is from a seller from japan. item # 380151764271. The buy it now price is $175 plus $28 for shipping.
From time to time you should check to see if there are more of these since they're rare to find, I grabbed mine before someonelse did. Thanks for your help on the antenna issue, I really appreciate it.
Old 08-25-2009, 08:34 PM
Today I logged some more satcom freqs used by pirates. These are 260.525, 263.825, 255.550, 262.225, 262.200 and 257.175. On two of the freqs I heard spanish being spoken (possibly Mexican).On 262.825 it sounded like two techs working on a huge water tank.and were speaking profressionaly in spanish. Has anyone else picked this up?
The radio Iused is the Yupi-7100 with the telescopic antenna. Some of the signals were booming in like it was right next to me.
Similar Threads
Yaesu good for emergency use? hayesd601 All Other Receivers 11 11-26-2008 07:58 PM
Darwin Cove Convention Centre grant Australia Radio Discussion Forums 8 10-31-2008 05:51 AM
Which Radio Freqs for Southern Wis? Dipole Wisconsin Radio Discussion Forum 19 02-21-2007 08:38 PM
The early days of Fire/Police radio ScanManQSL Maryland Radio Discussion Forum 3 12-21-2006 10:05 AM
***FOR SALE*** 800MHZ GCWE2004 Old Classifieds Archives 1 06-26-2004 10:27 AM
