Go Back   The RadioReference.com Forums > Topic Specific Forums > Military Monitoring Forum
Military Monitoring Forum Discussions regarding monitoring military communications on the ground, in air and at sea.
Old 02-28-2013, 8:56 PM
darkwolf's Avatar
Send a message via Yahoo to darkwolf
Default Radio Preference For military
What is everyone's preference for military monitoring?
http://groups.yahoo.com/group/oklahomaradioscannermilitaryfederal/
Pro-2052 Pro-96 Bcd396xt Pro-2006 Canon Rebel XS 1000D Sony Dsch50b Sony Dschhx1 Freescan Arc-96 BcTool Gre Super Amp Win96
Old 03-01-2013, 12:17 PM
Short of buying expensive ICOM's or AOR receivers if you can find good cond Uniden 785,789's there some of the last good milcom scanners. The PSR-500 is great for trunking but absolutely terrible at VHF/UHF air, the same applies to the Uniden 996. I have the 500 & dumped the 996. It does depend on what and where you want to monitor. A great antenna and feedline can make or break your setup,
get your antenna as high as possible. The Discone is the old standby, I use the DPD antennas and can recommend them. Your 2006 is actually one of the best scanners for milair, I still use mine with
the Opti 456 board, My ICOM 8500 is great but there tough to buy unless you import or get a used one.
Your radio's listed are all capable so I would look at a dedicated milair antenna to start out.
Old 03-01-2013, 4:45 PM
darkwolf's Avatar
Which dpd antennas do you have ?
Old 03-03-2013, 12:52 PM
The OMNI-X
Old 03-03-2013, 2:13 PM
mancow's Avatar
BC780XLT is my favorite for Military Air. Syntor X9000 is the best I've ever found for low-band.
Old 03-03-2013, 2:29 PM
WAScanMan's Avatar
Send a message via Skype™ to WAScanMan
I use a BCT15X for lowband, VHF/UHF milair and a Pro-106 for the 380MHz digital trunked systems and the 145MHz digital CAP freqs. Both are hooked up to the same antenna (discone) via an amplified splitter.
Pro-97 | Pro-106 | Pro-107 | Pro-508 | BCT15X | BC346XT | Satellit 750 | S450DLX
Old 03-03-2013, 8:02 PM
737mech's Avatar
Question
Can you give me an idea what you can get on those digital cap freqs? How far can you hear them? I don't have any nac cap stuff here in NV.
In Omnia Paratus!!
BCT-15 / BCT-15X / PSR500 / PRO2051/ BC125AT
Old 03-03-2013, 8:04 PM
TedRHayes's Avatar
I use several different radios, but I've found the BC125AT to be a very good low cost scanner for MILAIR VHF/UHF. It has shown excellent sensitivity, and scans pretty fast.
Old 03-03-2013, 9:15 PM
WAScanMan's Avatar
Ours are mixed mode, mostly analog with occational P25. Usually the same radio traffic on both modes. Check ins, location reports, radio tests etc. As for how far; being that the transmissions are coming from the same source, P25 really cuts down the reception range when going from P25 to analog or vice versa. Even the net control sometimes says "Can you repeat? You went digital." Here's a recording I took if you wanna have a listen: https://soundcloud.com/wascanman/wacapp25
Old 03-03-2013, 10:11 PM
darkwolf's Avatar
I would like to thank everyone's posts it's much appreciated
Old 03-04-2013, 5:30 AM
Send a message via Yahoo to trap5858
Over the years I have used many radios or scanners to monitor military assets.
The one that I have used for the longest is the Regency MX 5000.It was the first kind of general coverage scanner to hit the market in the early 80's. Rather limited by todays standards- 20 channels and slow scan rate, no alpha tags but overall a sensitive receiver. It was marketed with a Regency label on it but made by AOR. It is still in service today.
Others I have used have been Yaesu VR 500. ICOM R-20, AOR AR-8200mkIII and of course some of the newer handhelds like the PRO-106, Uniden 396XT
Old 03-04-2013, 8:13 PM
gtaman's Avatar
Use a uniden BCT15 picks up mil air and air really well. Also use a RadioShack mag mount with the middle whip taken off for air reception works great.
Proud owner of a HARRIS FALCON III AN PRC-152 Multiband Radio.
