hotshotmike1001
spot this group on the Freeway !
Cool shots from the I-15 and Rainbow scale area.
Probably VHF low
Wirelessly posted (Opera/9.80 (BREW; Opera Mini/6.0.3/27.2338; U; en) Presto/2.8.119 320X240 LG VN530)
I recall playing with a PRC-25, or maybe the (-70?, -77?, whichever model superseded the -25) at Luke AFB open houses in the past, and they went from 30-88MHz in 25 kHz steps. So they could be found pretty much anywhere in the VHF-Lowband, the old TV channels 2-4, the VHF-Midband, and TV channels 5 & 6. (As an aside, I wish more scanners covered the 54-88 MHz range in it's entirety. I understand some Uniden radios do cover the 72-76 MHz VHF-Midband.)
Also check the 14 ISR, or Intra-Squad Radio, channels in the 380-400 MHz range. (They're in the DB.) These radios are basically a military version of the FRS.
At one time, Icom manufactured an ISR radio model that was nearly identical to one of their FRS radio models, the only difference being the frequencies it used.
