Go Back   The RadioReference.com Forums > Service Specific Monitoring > Military Monitoring Forum
Military Monitoring Forum - Discussions regarding monitoring military communications on the ground, in air and at sea. Please keep USCG discussion to this forum also.
  #21 (permalink)
Old 03-29-2014, 9:58 AM
Originally Posted by ksmoscanner View Post
TURBO## = 22nd ARW McConnell AFB KC135R
FAST## = 394th CTS Whiteman AFB T-38(A?)
For those of you in Kansas and Missouri wondering if YOU too could hear Milcom....the answer is YES if you use a decent outdoor antenna. There is a ton to hear around these parts. Best times to listen is 6am-10pm Mon-Thurs and then during the day on Friday. Will not hear nearly as much on Friday night through Sunday.
Gregg in KC
Yep, you're absolutely right Gregg. I must have been smoking crack yesterday . Thanks for the correction. I shouldn't post until I'm under the influence of caffeine.
  #22 (permalink)
Old 03-29-2014, 2:35 PM
The term "Razorback" in this instance may also refer to Razorback Approach/Departure, which is handled by Memphis Center for all incoming/outgoing flights at local NW Arkansas airports (KXNA, KVBT, KROG, etc.). You may hear something like, "Contact Razorback on 126.1."
Monitoring from Northwest Arkansas
Find me on Twitter: @K5KVN
  #23 (permalink)
Old 03-30-2014, 9:50 PM
ksmoscanner's Avatar
I think in this case they are referencing the RAZORBACK VOR which is just north of Springdale Arkansas. Very common to hear pilots call out a radial and distance off that VOR.
Gregg in KC
  #24 (permalink)
Old 03-30-2014, 9:52 PM
frazpo's Avatar
Default Whiteman AFB
Yes. that seem to be the scenario. Didn't know there were that many of you around listening to air in this area. Good to know.
Sent from my iPhone using Tapatalk. There will misspellings!
BCD436 - TRX1 - SDR - 890XLT
  #25 (permalink)
Old 04-03-2014, 2:13 PM
Is there a good list for Forbes Feild or the Topeka, KS area?
  #26 (permalink)
Old 04-03-2014, 6:09 PM
From Airnav.com:
Airport Communications
CTAF: 120.8
UNICOM: 122.95
ATIS: 128.25
FORBES GROUND: 121.7 275.8 [0545-2200]
FORBES TOWER: 120.8 340.2 236.6 [0545-2200]
ANG OPS: 286.5 190th ARW KSANG WYLIE CONTROL
NG OPS: 304.6
ARNG OPS: 41.7 1-108th Av 2 Batt 135th Av
MILLION AIR: 129.85
Not sure if both 304.6 and 41.7 are used by same group. Listed as ARNG and NG.
I have never confirmed a air /air for the 190th ARW Tankers. Anyone else?
FWIW all the B-2's are dashing back home once the cells cleared the base. Reaper 11,21,22,23 flights all trying to get down.
Gregg in KC
  #27 (permalink)
Old 04-05-2014, 5:34 PM
Folks FYI Only
Please see "updated" USAF Air Refueling Tracks (PDF) I just posted the Military Monitoring Forum a few minutes ago, as appears a few "changes" in a couple of AR areas....
Bill
ICOM HF R71A ~ Pro-400 ~ IC R10 ~ Pro 2052 ~ Pro 2055 ~ Pro 92 ~ Kenwood TH F6a - Yeasu FTM-350 - Home Patrol - FunCube - WinRadio ~ PRC 1500 ~ Ventenna ~ J-Poles ~ Alfa Delta HF DD -Milair - SATCOM
  #28 (permalink)
Old 04-06-2014, 1:46 PM
BMT BMT is offline
Guy's you are missing the chance of a life to set up a monitoring group in your area.
Call it the Mid-West Monitoring Group or whatever.
This can best be accomplished if someone would set up a internal e-mail list for those that have posted to this thread.
Once this is done you can traded info within the group with out every Tom, Dick and Harry jumping in from out of your area.
The ARTCC list on RR is probably as good as any list on the internet.
BMT
Why would one believe anything that involved a group of intellectuals throwing bat dung into a candle seeking enlightenment
  #29 (permalink)
Old 04-06-2014, 6:05 PM
mancow's Avatar
I agree. There is a large amount of traffic around here and it's a surprisingly good location for milair monitoring.
The E6 TACAMOs and ACC headquarters are up at Offut, the NAOC E4s are down at Tinker, the B2s are to the East just over the line in Missouri and Smoky hill bombing range is West over near Salina.
The KC area is right in the center of it all.
Right now I'm getting an E6 blazing a WBFM signal on 338.950 as it travels South between Manhattan and Topeka.
  #30 (permalink)
Old 04-06-2014, 6:09 PM
frazpo's Avatar
Default yes
This has also crossed my mind. Mancow I can help administer if you want to start one? PM me.
  #31 (permalink)
Old 04-07-2014, 10:41 PM
frazpo's Avatar
I have started a google group in reference to the idea posted in this thread. Call it "beta". We will see how it goes and see how well it takes off. I'm not sure I am totally sold on google groups. I put this on the web forum display. Please visit and post your findings.
https://groups.google.com/forum/#!fo...tairmonitoring
Tags
whiteman afb
