Nation wide military air frequencies
jbsarandolphmonitor
Air band monitoring JBSA-Randolph
Schertz TX
I am looking for some more nation wide military air frequencies. I have all of the local area frequencies for San Antonio Texas. Listed below are the nation wide frequencies I have found from other lists.
CG A-G Pri 326.150000
CG A-G Sec 379.050000
CG AirOpsPri 345.000000
CG AirOpsSec 237.900000
USAF ANG-F16's 143.600000
USAF EAM Message 323.800000
NORAD 271.000000
NORAD AICC AWACS 364.200000
UHF Common 311.000000
UHF Common 321.000000
Don
KF6DGN
Grid Square: DM13
I'm kind of new to listening to MILAir. USAF ANG-F16's 143.600000 seem odd. Would this be used for talking to troops on the ground? Most MILAir seems to be 200/300. This freq isn't on the above site either.
kg4ojj
Crisp County, GA, USA
Odd or not, milair is active in that portion of the VHF band. I hear a gang of A-10s on 143.150 AM frequently in northern Florida.
Sent from my SCH-I545 using Tapatalk
ecps92
Taxachusetts
Correct, there is plenty of VHF AM, including some frequencies that are shared between FM users and AM users, 143.7000 is one of them.
KF6DGN
Grid Square: DM13
so is there a criteria for when a freq is added to:Common Military Scanner Frequencies and Radio Frequency Reference
jbsarandolphmonitor
Schertz TX
The bases in San Antonio have frequencies in the military VHF band. Planes landing at Randolph AFB fly right over my house. It is nice to hear them.
Don
kg4ojj
The criteria for nationwide mair frequencies are similar to other nationwide groups. That is, they must be common. My frequency example may or may not be common across the country. A-10s flying over San Antonio, TX may or may not use 143.150 AM. However, there are other, common, and frequently used frequencies such as 311.0, 255.4, and 243.0 AM. Plus, it is the collective knowledge of those contributing to the wiki that helps all of us know what frequencies are "nationwide" or "common."
Carteret County NC
the 142/143 Mhz AM freqs are mainly used as squadron air to air freqencies around here in eastern NC.....pilot to pilot comms......navy carrier pilots use one here for air-air chat thats the same freq as a local FM military base freq......I have the same freq entered twice in all scanners...once as FM , once as AM.....
BMT
USAF has about 100 freqs 138-150.8 that have nationwide assignments.
BMT
jbsarandolphmonitor
Schertz TX
I have a few frequencies listed in the 138 to 150.8 Mhz band. Is there a site that lists what they are used for? I have them listed as ACM or air to air.
Don
nyair1
260.900 and 228.900 are pretty much used across the country for Huntress CAP and intercepts
jbsarandolphmonitor
Schertz TX
All of these frequencies were heard in San Antonio. I haven't had time to check them out.
Air to Air 139.300000 AM
Air to Air 139.575000 AM
ACM 139.600000 AM
Air to Air 139.700000 AM
Air to Air 139.825000 AM
Air to Air 140.525000 AM
ACM 141.025000 AM
Air to Air 141.050000 AM
Air to Air 141.150000 AM
ACM 141.425000 AM
ACM 141.500000 AM
Air to Air 141.650000 AM
Air to Air 141.725000 AM
Air to Air 141.750000 AM
Air to Air 141.775000 AM
ACM 141.825000 AM
ACM 141.925000 AM
ACM 141.950000 AM
ACM 142.700000 AM
ACM 143.000000 AM
Air to Air 143.200000 AM
ACM 143.250000 AM
Air to Air 143.750000 AM
ACM 143.875000 AM
ACM 148.575000 AM
ACM 148.750000 AM
Air to Air 148.875000 AM
ACM 149.100000 AM
Air to Air 149.250000 AM
Air to Air 149.625000 AM
ACM 149.675000 AM
ACM 149.875000 AM
Aerial Refueling 150.150000 AM
Aerial Refueling 150.300000 AM
Aerial Refueling 150.500000 AM
Air to Ground 230.500000 AM
Aerial Refueling 233.600000 AM
ACM 234.800000 AM
ACM Air-Air UHF1 235.950000 AM
Air to Air 246.900000 AM
Air to Air 259.575000 AM
Air to Air 268.200000 AM
Air to Air 274.600000 AM
Aerial Refueling 277.200000 AM
Aerial Refueling 277.300000 AM
ACM 281.050000 AM
Air to Air 282.600000 AM
Aerial Refueling 283.900000 AM
USAF Air-2-Air-1 286.000000 AM
DRAGNET 288.200000 AM
USAF AF1 Air2Air 292.800000 AM
ACM DRAGNET 320.400000 AM
USAF ACM Dragnet 329.400000 AM
USAF Air Tankers 352.600000 AM
Don
