Go Back   The RadioReference.com Forums > Service Specific Monitoring > Military Monitoring Forum
Military Monitoring Forum - Discussions regarding monitoring military communications on the ground, in air and at sea. Please keep USCG discussion to this forum also.
Old 09-04-2017, 10:16 PM
Default AP-1/B Air Refueling Track RADIO Freq as of AUG 2017
Attached across several attachments are the AP-1/B Air Refueling Tracks and supporting documents outlining each AR Track, along with Radio Contact Frequencies (UHF Primary and Secondary) and the FAA ARTCC Entry/Exit Center Contact Radio Freq's too.
Find your AR's near your location and often you can hear a AR operation from ~ +100 miles with a good antenna capable pf the 225-400 MHZ range. Naturally, the better the COAX, Connectors and Antenna height the better the reception....
Look up NOTAMS via: https://pilotweb.nas.faa.gov/PilotWeb/
to understand Mil-Air Ops in or near your location by the closest ARTCC(s) to you.
Remember some AR Tracks cross several states/areas and ARTCC Sectors as well.
Also, always check the "Remarks" section, as some nuggets sometimes are included.
Enjoy
ICOM HF R71A ~ Pro-400 ~ IC R10 ~ Pro 2052 ~ Pro 2055 ~ Pro 92 ~ Kenwood TH F6a - Yeasu FTM-350 - Home Patrol - FunCube - WinRadio ~ PRC 1500 ~ Ventenna ~ J-Poles ~ Alfa Delta HF DD -Milair - SATCOM
Old 09-04-2017, 10:19 PM
Default AP-1/B Air Refueling Tracks RADIO Freq's (PART 2)
* PART 2
3 Attached Files
File Type: pdf AP1B Air Refuel Routes AR716 to AR727_AUG2017.pdf (47.4 KB, 203 views)
Old 09-04-2017, 11:45 PM
kma371's Avatar
Global DB Admin
I saw no need for two separate thread on this, merged together.
Old 09-14-2017, 12:13 PM
Wiki Admin Emeritus
Let me see about putting these maps into our wiki. The data we have there is way too old to be useful, so this would be a good place to start.
Thanks for posting these....Mike
Old 09-27-2017, 11:20 AM
Thanks alot for posting this. I have a terrible time trying to track anything current down. Just want to make sure you know your efforts are appreciated. Last year's as well
Old 12-14-2017, 9:23 AM
Default AP-1/B and Military Training Routes (Low Speed & VFR)
Mil Air Teams:
Working on posting several High-Res maps that depict Low-Level / VFR training routes. Hope to have a few of these up in a few days...stay tuned.
Also, will see if any new updates of significance from the Aug 2017 Air Refuel Maps as I posted a couple months ago as well...
Bill
Old 12-14-2017, 1:40 PM
Talking my new favorite person you are
Originally Posted by Alliance01TX View Post
Mil Air Teams:
Bill
Dude, I am thinking about adding you to my Christmas card list. ever since that seeandavod.org site went away i have been at a total loss. i had made some up for my area (NC and bordering states) and did screen shots and thankfully printed them, but that was a seriously less than perfect setup, and i cant find the saved files, so my printed sheets are all i have got.
if you post the east coast, central, areas first, i might even consider adding you to the birthday card list as well
