Go Back   The RadioReference.com Forums > Regional Radio Discussion Forums > Minnesota Radio Discussion Forum
Minnesota Radio Discussion Forum Forum for discussing Radio Information in the State of Minnesota.
Old 05-29-2009, 07:44 PM
Default Carver co no audio
Hi all i recently loaded carver co 800 digital to my 996t
For some reason there is no activity,i checked on this manually,signal strenght is good
but never hear audio.I loaded this system per this site and used arc996
The same is true for washington co good signal no audio
does it matter if i use id/search or id scan
thank you
Old 05-29-2009, 07:53 PM
n0vza's Avatar
Default Carver Co Settings
Did you enter all frequencies or just the Control Channels and how do you have the system setup? Did you enter Trunk Groups (TG)? Please provide more details and I will see if I can help.
ID Scan will scan those trunk groups you have entered for the system.
ID Search will search for any trunk group that is received on the system.
Old 05-29-2009, 11:04 PM
Default dakota co
i am not sure how it is set up,wish i could be more help
pulled up the info using arc996 basic from this data base
and uploaded to scanner.had this radio for abt 1-yr still learning
the metro area was pre-loaded when i bought radio so i didnot set up tgid groups
using 8-element yagi 30ft above ground pointing SE
Old 05-30-2009, 08:21 AM
n0vza's Avatar
Understood. Using the ARC996 software, can you try to program the analog "weather frequency" 162.550 into the scanner and see if you can hear it? This should work with the stock antenna. If so, that will kind of prove the scanner works.
Can you tell me which agency you would like to listen to and what department within the agency (police, fire, ems, etc) you want to hear? Lets start with some simple.
My "public server's hard drive" died last night and I need to rebuild it today. If you can tell me what you want to listen to; once the server is back online, I can create an ARC996 file you can download to program into the scanner. I could also create show type of document that would show you, step by step on how to use ARC996 with Radio Reference or I can grab a laptop and meet you somewhere (that has Internet access, wired or wireless) and show you "hands on", how to do it.
I doubt that I could do all of this today, Saturday, but by Sunday, can do. If you want be to do this, I'll need your email address, so I can send you a secure email on how to access the server, and you general location, so we can pick the site/tower you need to "connect to". Let me know.
Old 05-31-2009, 11:49 AM
OK the weather comes in full quieting 162.425,162.550
what i want to do is program all metro counties for( police and state patrol)
anoka,henn,ramsey,dakota,washington,carver, all of mpls,st.paul
i am located in columbia heights.If you would send me the link to the server and if you can create a file
for arc996t with the above counties,i would greatly appeciate this.
e-mail adress martye2001@yahoo.com
once that information is in the radio then i can go through and figure which tg id to keep or omit
Use a discone abt 35ft thank you for all of your help
Old 05-31-2009, 12:32 PM
n0vza's Avatar
Good sign that you can pickup the weather channels!
I doubt that you will pickup all of the agencies from a stationary location, too many sites/towers/locations in various directions using the lowest transmitting power required to cover their area. You might be able to receive different agencies (locations) by rotating your yagi in the direction of the site/tower; but if you do turn your yagi, you'll lose the sites on the "back and sides" of the direction yagi the yagi is pointing.
For starters (theory, reference, sites, control channels, coverage maps, and talk groups), check out the web site "http://www.geocities.com/mn_metroscan/". Once there, checkout the following sections:
Under General Info read System & Monitoring FAQ.
Under Frequencies, read Tower Sites & Frequencies and maybe Coverage Maps.
Under Talkgroups, read State Patrol.
I have some errands to run but will get back to you soon.
Old 05-31-2009, 01:50 PM
i went to the metroscan site,very informative,so the new digital sys. is like cell site repeaters,
i didnot realize the towers use low power,so by me wanting to recieve all metro counties may not be possible and or to many to fit into memory
Old 05-31-2009, 02:44 PM
n0vza's Avatar
From Anoka County it appears the “home” site for Anoka County is site 102 and is identified on Radio Reference as Anoka County Simulcast under the FCC License WPKG278. Here is a link to the tower locations and frequencies used in this site FCC Callsign WPKG278 Details.
According to Radio Reference (Scanner Frequencies: Allied Radio Matrix for Emergency Response (ARMER) Trunking System, Various, Minnesota) the Control Channels are listed below and are the only frequencies required for Control Channel Operation:
102 66 Anoka Co Simulcast
851.13750 851.31250 851.38750 851.68750 851.93750a 852.06250 852.21250 852.38750a
852.81250 852.88750a 853.08750 853.13750 853.38750c 853.68750 853.91250
853.3875 (primary), 851.9375 (alternate), 852.3875 (alternate), and 852.8875 (alternate).
On the same page are the various Trunk Groups (TG). Take a look at “Anoka County” groups. I’m not sure how Columbia Heights law enforcement is dispatched, but I am guessing that these TGs are used:
Anoka County - Law Enforcement Talkgroups
DEC HEX Mode Alpha Tag Description Tag
802 322 D ANKA S DISP South Main Dispatch Law Dispatch
804 324 D ANKA PD ADM Police Administration Law Talk
806 326 D ANKA PD INFO Police Information "CH 3" Law Talk
808 328 D ANKA 3 DISP Police 3rd Main Law Dispatch
810 32a D ANKA N DISP North Main Dispatch Law Dispatch
820 334 D ANKA DRG TSK North Metro Drug Task Force / Encrypted Law Tac
822 336 D ANKA LAW MLT Law Enforcement Multigroup Law Talk
896 380 E ANKA SO ENC Law Enforcement Encrypted Data
904 388 D ANKA SO ROAM Law Enforcement Roaming Talkgroup Law Talk
For the city law enforcement, I am guessing the following TGs are used:
Anoka County - Columbia Heights Talkgroups
836 344 D CHTS PD C2C Police Car to Car Law Talk
838 346 D CHTS PD ADM Police Administrative Law Talk
922 39a D CHTS FIR TAC Fire Tactical Fire-Tac
954 3ba D CHTS FIR ADM Fire Administrative 1 Fire-Talk
984 3d8 D CHTS FIR ADM Fire Administrative 2 Fire-Talk
1036 40c D CHTS WORKS Public Works Public Works
There are other TGs listed, take a look, but I am trying to start, with something easy. More to follow later.
Old 05-31-2009, 04:05 PM
n0vza's Avatar
Two files have been emailed, they are Anoka Police.m96 and Anoka FIre.m96. I don't know if they will make it through your email system. Let me know and happy monitoring
Old 05-31-2009, 04:07 PM
n0vza's Avatar
This is the content of Anoka Police.m96
ARC996 MEM V1.00B - IMPORTANT: ARC file format is proprietary information of BuTel Software The Netherlands (c) 2008
SYSDATA#,"Anoka Police","2","0","2","2","0","0","0","0","3","2","h ttp://www.radioreference.com/modules.php?name=TRSDB&sid=3508","10","1111111111" ,"0","0","8","LATLONZLV0","","0","0","2","-1","",""
TRSDATA#,"0","0","1","0","0","1","","","","","","" ,"","","","","","0","0","","","","","",""
GROUPDATA#,"AnokaColHgts","10","1","0","1"
GROUPDATA#,"AnokaCommon","10","2","0","1"
GROUPDATA#,"AnokaPolice","10","3","0","1"
GROUPDATA#,"AnokaServices","10","4","0","1"
GROUPDATA#,"AnokaShared","10","5","0","1"
GROUPDATA#,"AnokaSheriff","10","6","0","1"
GROUPDATA#,"","0","","0","0"
T,"250","250","250","250","250","250","250","250", "250","250","250","250","250","250","250","250","2 50","250","250","250"
T,"6","1","9","10","7","9","0","0","0","0","0","0" ,"0","0","0","0","0","0","0","0"
CHN,"836","CHTS PD C2C","Off","Off","Auto","Off","Off","All","Police Car to Car"
CHN,"838","CHTS PD ADM","Off","Off","Auto","Off","Off","All","Police Administrative"
CHN,"922","CHTS FIR TAC","Off","Off","Auto","Off","Off","All","Fire Tactical"
CHN,"954","CHTS FIR ADM","Off","Off","Auto","Off","Off","All","Fire Administrative 1"
CHN,"984","CHTS FIR ADM","Off","Off","Auto","Off","Off","All","Fire Administrative 2"
CHN,"1036","CHTS WORKS","Off","Off","Auto","Off","Off","All","Publi c Works"
CHN,"872","CHTS COMM","Off","Off","Auto","Off","Off","All","Common "
CHN,"802","ANKA S DISP","Off","Off","Auto","Off","Off","All","South Main Dispatch"
CHN,"804","ANKA PD ADM","Off","Off","Auto","Off","Off","All","Police Administration"
CHN,"806","ANKA PD INFO","Off","Off","Auto","Off","Off","All","Police Information CH 3 "
CHN,"808","ANKA 3 DISP","Off","Off","Auto","Off","Off","All","Police 3rd Main"
CHN,"810","ANKA N DISP","Off","Off","Auto","Off","Off","All","North Main Dispatch"
CHN,"820","ANKA DRG TSK","Off","Off","Auto","Off","Off","All","North Metro Drug Task Force En"
CHN,"822","ANKA LAW MLT","Off","Off","Auto","Off","Off","All","Law Enforcement Multigroup"
CHN,"896","ANKA SO ENC","Off","Off","Auto","Off","Off","All","Law Enforcement Encrypted"
CHN,"904","ANKA SO ROAM","Off","Off","Auto","Off","Off","All","Law Enforcement Roaming Talkgrou"
CHN,"800","ANKA SYSTECH","Off","Off","Auto","Off","Off","All","Rad io Technicians"
CHN,"902","ANKA SO EM","Off","Off","Auto","Off","Off","All","Emergenc y Management"
CHN,"1010","ANKA CO WKS","Off","Off","Auto","Off","Off","All","Public Works Common"
CHN,"1012","ANKA CO HWAY","Off","Off","Auto","Off","Off","All","Highwa y Department Main"
CHN,"1014","ANKA CO SURV","Off","Off","Auto","Off","Off","All","Highwa y Department Surveyors"
CHN,"1016","ANKA CO HADM","Off","Off","Auto","Off","Off","All","Highwa y Department Administratio"
CHN,"1018","ANKA CO PRKS","Off","Off","Auto","Off","Off","All","Parks Department Main"
CHN,"1020","ANKA CO PRPD","Off","Off","Auto","Off","Off","All","Parks Department Police"
CHN,"1066","ANKA PW ROAM","Off","Off","Auto","Off","Off","All","Public Works Roaming Talkgroup"
CHN,"1072","ANKA PROP MG","Off","Off","Auto","Off","Off","All","Proper ty Management"
CHN,"812","ANKA COM","Off","Off","Auto","Off","Off","All","Common "
CHN,"814","ANKA TAC 1","Off","Off","Auto","Off","Off","All","Tactic al"
CHN,"816","ANKA TAC 2","Off","Off","Auto","Off","Off","All","Tactic al"
CHN,"818","ANKA TAC 3","Off","Off","Auto","Off","Off","All","Tactic al"
CHN,"898","ANKA SO EVT1","Off","Off","Auto","Off","Off","All","Specia l Events 1"
CHN,"900","ANKA SO EVT2","Off","Off","Auto","Off","Off","All","Specia l Events 2"
CHN,"1084","ANKA DYN RGP","Off","Off","Auto","Off","Off","All","Dynami c Regroup"
CHN,"864","ANKA SO C2C","Off","Off","Auto","Off","Off","All","Police Car to Car"
CHN,"866","ANKA SO ADM","Off","Off","Auto","Off","Off","All","Police Administration"
CHN,"884","ANKA SO COMM","Off","Off","Auto","Off","Off","All","Area Common"
CHN,"890","ANKA SO SWAT","Off","Off","Auto","Off","Off","All","SWAT Team"
CHN,"892","ANKA SO DIVE","Off","Off","Auto","Off","Off","All","Dive Team"
CHN,"894","ANKA SO RESV","Off","Off","Auto","Off","Off","All","Reserv es"
CHN,"1068","ANKA CRT SEC","Off","Off","Auto","Off","Off","All","Court Security"
CHN,"1070","ANKA SO CID","Off","Off","Auto","Off","Off","All","CID"
CHN,"1082","ANKA CRT SEC","Off","Off","Auto","Off","Off","All","Court Security Administration"
TRKFR#1,"","","","",""
TRKFR#2,"","","","",""
TRKFR#3,"","","","",""
TRKFR#4,"","","","",""
TRKFR#5,"","","","",""
TRKFR#6,"","","","",""
TRKFR#7,"","","","",""
TRKFR#8,"","","","",""
TRKFR#9,"","","","",""
TRKFR#10,"","","","",""
TRKFR#11,"","","","",""
TRKFR#12,"","","","",""
TRKFR#13,"","","","",""
TRKFR#14,"","","","",""
TRKFR#15,"","","","",""
TRKFR#16,"","","","",""
TRKFR#17,"","","","",""
TRKFR#18,"","","","",""
TRKFR#19,"","","","",""
TRKFR#20,"","","","",""
TRKFR#21,"","","","",""
TRKFR#22,"","","","",""
TRKFR#23,"","","","",""
TRKFR#24,"","","","",""
TRKFR#25,"","","","",""
TRKFR#26,"","","","",""
TRKFR#27,"","","","",""
TRKFR#28,"","","","",""
TRKFR#29,"","","","",""
TRKFR#30,"","","","",""
TRKFR#31,"","","","",""
TRKFR#32,"","","","",""
TRKFR#33,"","","","",""
TRKFR#34,"","","","",""
TRKFR#35,"","","","",""
TRKFR#36,"","","","",""
TRKFR#37,"","","","",""
TRKFR#38,"","","","",""
TRKFR#39,"","","","",""
TRKFR#40,"","","","",""
TRKFR#41,"","","","",""
TRKFR#42,"","","","",""
TRKFR#43,"","","","",""
TRKFR#44,"","","","",""
TRKFR#45,"","","","",""
TRKFR#46,"","","","",""
TRKFR#47,"","","","",""
TRKFR#48,"","","","",""
TRKFR#49,"","","","",""
TRKFR#50,"","","","",""
TRKFR#51,"","","","",""
TRKFR#52,"","","","",""
TRKFR#53,"","","","",""
TRKFR#54,"","","","",""
TRKFR#55,"","","","",""
TRKFR#56,"","","","",""
TRKFR#57,"","","","",""
TRKFR#58,"","","","",""
TRKFR#59,"","","","",""
TRKFR#60,"","","","",""
TRKFR#61,"","","","",""
TRKFR#62,"","","","",""
TRKFR#63,"","","","",""
TRKFR#64,"","","","",""
TRKFR#65,"","","","",""
TRKFR#66,"","","","",""
TRKFR#67,"","","","",""
TRKFR#68,"","","","",""
TRKFR#69,"","","","",""
TRKFR#70,"","","","",""
TRKFR#71,"","","","",""
TRKFR#72,"","","","",""
TRKFR#73,"","","","",""
TRKFR#74,"","","","",""
TRKFR#75,"","","","",""
TRKFR#76,"","","","",""
TRKFR#77,"","","","",""
TRKFR#78,"","","","",""
TRKFR#79,"","","","",""
TRKFR#80,"","","","",""
TRKFR#81,"","","","",""
TRKFR#82,"","","","",""
TRKFR#83,"","","","",""
TRKFR#84,"","","","",""
TRKFR#85,"","","","",""
TRKFR#86,"","","","",""
TRKFR#87,"","","","",""
TRKFR#88,"","","","",""
TRKFR#89,"","","","",""
TRKFR#90,"","","","",""
TRKFR#91,"","","","",""
TRKFR#92,"","","","",""
TRKFR#93,"","","","",""
TRKFR#94,"","","","",""
TRKFR#95,"","","","",""
TRKFR#96,"","","","",""
TRKFR#97,"","","","",""
TRKFR#98,"","","","",""
TRKFR#99,"","","","",""
TRKFR#100,"","","","",""
TRKFR#101,"","","","",""
TRKFR#102,"","","","",""
TRKFR#103,"","","","",""
TRKFR#104,"","","","",""
TRKFR#105,"","","","",""
TRKFR#106,"","","","",""
TRKFR#107,"","","","",""
TRKFR#108,"","","","",""
TRKFR#109,"","","","",""
TRKFR#110,"","","","",""
TRKFR#111,"","","","",""
TRKFR#112,"","","","",""
TRKFR#113,"","","","",""
TRKFR#114,"","","","",""
TRKFR#115,"","","","",""
TRKFR#116,"","","","",""
TRKFR#117,"","","","",""
TRKFR#118,"","","","",""
TRKFR#119,"","","","",""
TRKFR#120,"","","","",""
TRKFR#121,"","","","",""
TRKFR#122,"","","","",""
TRKFR#123,"","","","",""
TRKFR#124,"","","","",""
TRKFR#125,"","","","",""
TRKFR#126,"","","","",""
TRKFR#127,"","","","",""
TRKFR#128,"","","","",""
TRKFR#129,"","","","",""
TRKFR#130,"","","","",""
TRKFR#131,"","","","",""
TRKFR#132,"","","","",""
TRKFR#133,"","","","",""
TRKFR#134,"","","","",""
TRKFR#135,"","","","",""
TRKFR#136,"","","","",""
TRKFR#137,"","","","",""
TRKFR#138,"","","","",""
TRKFR#139,"","","","",""
TRKFR#140,"","","","",""
TRKFR#141,"","","","",""
TRKFR#142,"","","","",""
TRKFR#143,"","","","",""
TRKFR#144,"","","","",""
TRKFR#145,"","","","",""
TRKFR#146,"","","","",""
TRKFR#147,"","","","",""
TRKFR#148,"","","","",""
TRKFR#149,"","","","",""
TRKFR#150,"","","","",""
TRKFR#151,"","","","",""
TRKFR#152,"","","","",""
TRKFR#153,"","","","",""
TRKFR#154,"","","","",""
TRKFR#155,"","","","",""
TRKFR#156,"","","","",""
TRKFR#157,"","","","",""
TRKFR#158,"","","","",""
TRKFR#159,"","","","",""
TRKFR#160,"","","","",""
TRKFR#161,"","","","",""
TRKFR#162,"","","","",""
TRKFR#163,"","","","",""
TRKFR#164,"","","","",""
TRKFR#165,"","","","",""
TRKFR#166,"","","","",""
TRKFR#167,"","","","",""
TRKFR#168,"","","","",""
TRKFR#169,"","","","",""
TRKFR#170,"","","","",""
TRKFR#171,"","","","",""
TRKFR#172,"","","","",""
TRKFR#173,"","","","",""
TRKFR#174,"","","","",""
TRKFR#175,"","","","",""
TRKFR#176,"","","","",""
TRKFR#177,"","","","",""
TRKFR#178,"","","","",""
TRKFR#179,"","","","",""
TRKFR#180,"","","","",""
TRKFR#181,"","","","",""
TRKFR#182,"","","","",""
TRKFR#183,"","","","",""
TRKFR#184,"","","","",""
TRKFR#185,"","","","",""
TRKFR#186,"","","","",""
TRKFR#187,"","","","",""
TRKFR#188,"","","","",""
TRKFR#189,"","","","",""
TRKFR#190,"","","","",""
TRKFR#191,"","","","",""
TRKFR#192,"","","","",""
TRKFR#193,"","","","",""
TRKFR#194,"","","","",""
TRKFR#195,"","","","",""
TRKFR#196,"","","","",""
TRKFR#197,"","","","",""
TRKFR#198,"","","","",""
TRKFR#199,"","","","",""
TRKFR#200,"","","","",""
SITESET#1,"Anoka Co Simulca","2","0","0","0","0","1","0","8","13","0", "","","0","0","","","","",""
SBP#,MBP,,,,,,,,,
SITEFR#,08519375,000,0,0,001001001*0851937500000#
SITEFR#,08523875,000,0,0,001001002*0852387500000#
SITEFR#,08528875,000,0,0,001001003*0852887500000#
SITEFR#,08533875,000,0,0,001001004*0853387500000#
Old 05-31-2009, 04:08 PM
n0vza's Avatar
This is the content of Anoka Fire.m96
SYSDATA#,"Anoka Fire","3","0","2","2","0","0","0","0","13","2","ht tp://www.radioreference.com/modules.php?name=TRSDB&sid=3508","10","1111111111" ,"0","0","8","LATLONZLV0","","0","0","0","-1","",""
GROUPDATA#,"AnokaFire","10","1","0","1"
T,"7","0","0","0","0","0","0","0","0","0","0","0", "0","0","0","0","0","0","0","0"
CHN,"906","ANKA FIRE DI","Off","Off","Auto","Off","Off","All","Fire Main VHF patch "
CHN,"908","ANKA FIRE A","Off","Off","Auto","Off","Off","All","Fire Tactical A"
CHN,"910","ANKA FIRE B","Off","Off","Auto","Off","Off","All","Fire Tactical B"
CHN,"912","ANKA FIRE C","Off","Off","Auto","Off","Off","All","Fire Tactical C"
CHN,"944","ANKA FIRE MG","Off","Off","Auto","Off","Off","All","Fire Service Multigroup"
CHN,"1006","ANKA FIRSPOP","Off","Off","Auto","Off","Off","All","Fir e Special Operations"
CHN,"1008","ANKA FIRROAM","Off","Off","Auto","Off","Off","All","Fir e Roaming Talkgroup"
SITESET#1,"Anoka Co Simulca","3","","","","","1","","8","13","","","", "","0","","","","",""
SBP#,MBP,,,,,,,,,
SITEFR#,08519375,000,0,0,002001001*0851937500000#
SITEFR#,08523875,000,0,0,002001002*0852387500000#
SITEFR#,08528875,000,0,0,002001003*0852887500000#
SITEFR#,08533875,000,0,0,002001004*0853387500000#
Old 05-31-2009, 07:14 PM
for some reason didnt get the e-mail
if you want to try again i have alt e-mail fotoguy45@gmail.com
haven't had chance to go to those links.might have to tackle that tomorow
still recovering from bad cold, thanks again 73s
Old 05-31-2009, 08:35 PM
n0vza's Avatar
Attached is a file (data.zip) which contains the two files I mentioned. If you have any problems, let me know.
Old 06-01-2009, 12:22 AM
ok that went well i opened 2 files anoka police and fire
also loaded some aditional cities for anoka co a bunch of smaller cities but i dont think its necesary might hear the same info. on main
i have learned alot in the past 5-days about this radio thanks to you
have a good day
Old 06-01-2009, 08:23 AM
n0vza's Avatar
I'm happy that all is working. When I was much younger, education interrupted my play time. Now that I am older, education is part of my play time and I love it! Have fun and if there is anything else I can help you with, let me know.
Similar Threads
Official Starrsoft WIN500 Software Thread scan-pa Scanner Programming Software 1671 06-23-2009 07:36 PM
BCD396T: Warbley audio on P16 systems TimMatthews Uniden Scanners 6 10-27-2007 08:26 AM
Scanners With HD Radio Reception and ATSC TV Audio JASII General Scanning Forum 7 07-26-2007 02:16 PM
IC-F521 Audio Problems MB ICOM Receivers 5 05-28-2007 05:14 PM
Direct/Rpeated??! lol ksjdklhsjkfdhsjkdfh General Scanning Forum 13 06-29-2005 12:02 AM
