Go Back   The RadioReference.com Forums > Regional Radio Discussion Forums > Minnesota Radio Discussion Forum
Minnesota Radio Discussion Forum Forum for discussing Radio Information in the State of Minnesota.
Old 10-31-2009, 08:59 PM
thunderbuntu's Avatar
Default Carlton Sheriff Dispatch
Does anybody know which is the correct dispatch freq for Carlton Sheriff? RRef db has 151.2500 (151.4) and 154.860 (073).
I suppose I could just go up there, but I'm in Anoka at the moment.
Old 11-02-2009, 06:53 AM
mmtstc's Avatar
Send a message via AIM to mmtstc
those were correct last time i was up there (about 5 weeks ago) great strong signal throughout the area.
EMT-P EMD
Minneapolis Area
And yes, I do think encryption is an excellent tool.
Old 11-02-2009, 11:41 PM
They both are correct, however, if I remember right I found the 151.25 frequency to be easier to hear. It appears 154.86 is a simulcast of some sort of the audio on 151.25 so I only listen to 151.25 and it works fine.
Old 11-02-2009, 11:58 PM
Simplex/repeated Duplex
Old 11-03-2009, 12:21 AM
NDRADIONUT's Avatar
Quite a few nights i can hear 154.860 073 in fargo.....
Old 11-03-2009, 07:40 AM
Default Carlton County SO
What about 154.8000 (151.4 hZ)?
Old 11-03-2009, 09:56 PM
Could you clarify which one is which, please?
Also, I just remembered, this summer when the Hell's Angels were in town, I heard Carlton dispatch on 154.98. I can't remember if it was simplex or repeated. I heard someone new on the frequency and looked it up to find it was licensed to Carlton. As I listened more, it sounded like it was being used as an alternate dispatch frequency since it was so busy.
Old 11-04-2009, 12:08 AM
I only have a basic understanding, so my explanation is not even close to what a truly knowledgeable person could give you. That being said, here goes:
Simplex is only one side of a two way conversation, is usually low powered, and may (or may not) be repeated from an "in vehicle" repeater, which is a very low powered transmission. It is designed to work like the old VHF systems without bleeding into other "close" communities that have a frequency in use that may be close to the one being used.
Repeated duplex (du = dual) is both sides of the conversation, and is usually repeated for one tower to the next within a larger coverage area using more power.
Therefore, if you hear a signal that is quiet or just one side of a conversation, it is likely a "simplex" channel.
I'm sure I will get lambasted by a knowledgeable person for my very basic explanation that is probably full of incorrect or variable facts, but thats the best I can do.
MM
Old 11-04-2009, 10:19 PM
MM
Oh, sorry. I thought you meant one was just a simplex broadcast of the other which was a repeater. Something along the lines of an analog simplex simulcast of a digital trunked talkgroup.
From the FCC's site both frequencies are repeated. So I'm now thinking that they are two different repeaters that are simulcast.
Old 11-05-2009, 05:06 PM
NDRADIONUT's Avatar
Maybe it would be wise to put all of the freqs in the scanner and listen when you are there....
Old 03-15-2010, 12:19 AM
Interestingly. I'm literally right on the NE edge of Carlton County and I hear 151.250 a lot better than 154.860 or 154.800. They also have / had a UHF 450 MHz frequency ... 458.350 I believe it is?
On a somewhat OT note, I regularly pick up 88.7, 91.9, and 104.5 from Fargo on FM here outside Duluth with an APS-9B. I also often saw KVRR (channel 15) when it was on analog.
