| Minnesota Radio Discussion Forum Forum for discussing Radio Information in the State of Minnesota. |
01-30-2013, 3:38 PM
Best indoor 800mhz antenna
Whats the Best indoor 800mhz antenna for the sw metro? im using a pro 96
i live in carver county and id like to pick up anoka county.
any ideas would be appreciated
also if i got a yagi antenna would i need to power it some how?
01-30-2013, 5:29 PM
Best Indoor 800 Mhz Antenna
How far do you live from the tower that you want to monitor? Also, do you want to monitor ALL traffic on the Anoka County sub-system or are there just certain talkgroups you want to hear? You could check one of the other sites to see if any Anoka County traffic is carried on it. For example, possibly some Anoka County traffic is carried on an adjacent sub-system.
As far as straight up yagi, inside from Carver County to Anoka County, I think that is a long shot. A regular yagi requires no power, but an amplifier would require electrical power.
01-30-2013, 6:28 PM
id i need a yagi antenna with an amplifier right? aiming at a hennapin tower?
01-30-2013, 7:22 PM
I like the R.S. 800 antenna i just wished it was produced with a SMA finding a Good SMA that brings in the 800 really well can be a little daunting at times to find i did however find two at Scanner Master that i wouldn't Mind getting but for the Past few weeks they have been out of stock.!
The models numbers are as followed: 15-541014 & 14-541098
01-30-2013, 7:35 PM
Before you buy another antenna, can you get the Hennepin sub-system now with what you already have?
01-30-2013, 7:45 PM
the highest the signal percentage has been is 43% so id say yes but not well
01-30-2013, 7:58 PM
Before you buy another antenna, can you get the Hennepin sub-system now with what you already have? Try Hennepin West and Hennepin East and then report back here with your results. That will help shape some further suggestions.
Update: Is that East or West?
Reason: Details
01-30-2013, 8:39 PM
Re: Best indoor 800mhz antenna
You should be able to hear Anoka County's main dispatch TGs on Hennepin East and West most of the time. Car to car/Tac TGs probably not so much. I think your chances of getting any kind of decent signal in from Anoka in Carver County are pretty slim, even with a good antenna. Maybe if you get one way up on a tower, but even then it would probably be iffy at best.
Where exactly in Carver County are you? Carver County covers a large area, if we can get a better idea of your location it would certainly help.
Sent from my SPH-D710 using Tapatalk 2
KD0AXS
Metro Skywarn #7344
Uniden BCD396T, BC250D, BC350A
RS PRO-84
Yaesu FT-2800M, VX-170
01-30-2013, 9:12 PM
I concur with Raven95150. Since it sounds like you are mainly interested in ARMER and want an indoor antenna, you could even consider a commercial single band 800 mHz gain antenna and a magnetic mount. That way you can put the mount on a metal filing cabinet and it will serve as a ground plain for the antenna. A 5 db gain antenna that is tuned for 800 mHz can improve your reception quite a bit. Probably enough to get Hennepin East and/or Hennepin West and at least get the main talkgroungs from Anoka County Central Communications.
Laird B8065 Antenna, 806-866 MHz, 5db Gain
01-30-2013, 9:29 PM
east is a bit better a 56%
01-30-2013, 9:31 PM
im in chanhassen
01-31-2013, 7:54 AM
If youre going to pull in anoka county off the actual anoka count towers, which you'll need to do if you want to hear more than the main dispatch talk groups, youre likely going to need a yagi fairly high up outside. Thats a pretty far distance for that signal to go.
Matt / KC0VRV
01-31-2013, 8:20 AM
Best Indoor 800mhz Antenna
Are you using the Radio Shack PRO-96 for ARMER monitoring? If so, what is the firmware that is loaded on the device? The PRO-96 has (or at least had) some serious challenges decoding the Minnesota ARMER System.
Here is a quote: ".....reception of a Simulcast Project25 CQPSK multisite system is horrible, and nearly unusable....." That is what the Minnesota ARMER System is, so if you can post what firmware you are using we can go from there.
Pro-96 CQPSK - unsatisfactory
PRO-96 FAQ - The RadioReference Wiki
Radio Shack PRO-96 Digital Trunking Scanner Product Reviews
01-31-2013, 12:33 PM
yes i am monitoring ARMER and
DSP version U1.4 issued 02-20-2007
01-31-2013, 2:11 PM
By any chance do you know any other hobbyists in your area that have either a newer Radio Shack/GRE or a Uniden scanner? It would be nice if you could have them try listening at your location to see how it compares to your unit. I would hate to think that you get soured on the hobby because of the problems with the PRO96.
01-31-2013, 2:52 PM
i know someone with a pro 106 is that one any better?
01-31-2013, 6:32 PM
I do seem to recall that PRO106 users have reported better results on ARMER, but don't go by what I think, have them stop by your house and do a side by side comparison. Have them both listening on the same talkgroups at the same time and then decide. I think there might even be a YouTube video or two that covers some of these.
