Go Back   The RadioReference.com Forums > U.S. Regional Radio Discussion Forums > Minnesota Radio Discussion Forum
Minnesota Radio Discussion Forum - Forum for discussing Radio Information in the State of Minnesota.
  #41 (permalink)
Old 06-09-2013, 2:34 PM
Default Reception
Originally Posted by westgateblvd View Post
Should I buy the software, or just use the free download??
Also a unrelated question.. My Wife and I are going to attend Back to the 50's at the State Fairgrounds in two weeks. If I brought the scanner it has a 800 Mhz antenna. Would I be able to hear any calls from Duluth on it??
Man, I wish that was possible, but its not....
Ryan S. Olsen
  #42 (permalink)
Old 06-09-2013, 2:41 PM
Oh well.. Doesn't hurt to ask..
  #43 (permalink)
Old 06-09-2013, 3:48 PM
It sure does not! Back to the 50's is in the Cities correct? Are you planning on putting in the Cities for Monitoring?
Ryan S. Olsen
  #44 (permalink)
Old 06-09-2013, 3:59 PM
No. We will only be there on that Thursday - Sunday morning..
Yes.. Back to the 50's is at the Fairgrounds in St. Paul. Those will be the days where you will see well over 11,000 pre 1964 cars and trucks. ( Street Rods )
  #45 (permalink)
Old 06-09-2013, 4:45 PM
Cool - You will be there 3 or so days? Did you get the Scanner programmed up for your current area?
Ryan S. Olsen
  #46 (permalink)
Old 06-09-2013, 5:12 PM
I am hoping to get the scanner tomorrow.. Last time I checked tracking.. It was in St. Paul.
  #47 (permalink)
Old 06-09-2013, 7:44 PM
Smile
Awesome! You will like it, did you get the programming figured out?
Ryan S. Olsen
  #48 (permalink)
Old 06-09-2013, 9:02 PM
Havn't downloaded it yet. Wanted to wait for the scanner to come first.
  #49 (permalink)
Old 06-10-2013, 8:12 AM
I would pay for it. You will always want to go back in and make adjustments. Other departments will add talkgroups/switch over to Armer down the road.
It also allows you to put in talkgoups/control channels in the Twin Cities and such when you travel.
  #50 (permalink)
Old 06-10-2013, 11:22 AM
Smile Software
Like I said before, I have had mine for over a year and a half, and have not had to pay a cent.... Still running the trial version.
Ryan S. Olsen
  #51 (permalink)
Old 06-10-2013, 5:14 PM
Well it came today. Have to charge the batteries first. I see that that driver CD goes up to windows XP. I have windows 7, so it won't work on my computer.. Is it really needed??
  #52 (permalink)
Old 06-10-2013, 7:48 PM
Default drivers fo cables with FTDI chips here
Virtual COM Port Drivers
  #53 (permalink)
Old 06-10-2013, 9:28 PM
Ok. Which one do I download??
  #54 (permalink)
Old 06-11-2013, 6:20 PM
Ok. I have the batteries charged up. Should I clear the it back to it's factory default settings??
  #55 (permalink)
Old 06-11-2013, 8:49 PM
Exclamation
Yes, I would, unless it came from Minnesota and you want to keep some of the data. Otherwise yes, clear away!
Ryan S. Olsen
  #56 (permalink)
Old 06-11-2013, 8:55 PM
Done.. Now what??
  #57 (permalink)
Old 06-11-2013, 8:57 PM
Ok. I did that. I also put on the first download so I can attach the cable to the scanner. Now what??
  #58 (permalink)
Old 06-11-2013, 9:03 PM
Well, make sure you have the software downloaded. Then try putting some data in the program. And try downloading it to the scanner, just making sure everything works oak! Then if it does, go to town programming!
Ryan S. Olsen
  #59 (permalink)
Old 06-11-2013, 9:23 PM
Well I hooked it all up. Says that I have the 20-047 cable not to use the mono/stereo cable.. Then it says com3 or com 4.. Which one??
  #60 (permalink)
Old 06-11-2013, 9:32 PM
Just try both.. If one Com port doesn't work then try the other.
Ryan S. Olsen
