10. May I set my MURS radios up as a repeater station?
The FCC prohibits using any MURS frequency as the input or the output of a conventional repeater (a station that retransmits a signal nearly simultaneously on a different frequency), unless that station was specifically licensed for such operation under Part 90. The FCC also prohibits "store-and-forward" packet stations (which retransmits the digital signal after a time delay, often [but not necessarily] on the same frequency). [95.1311]
Not surprising. I used to be able to hear a distant police department on 151.880, and it wasn't an image signal, it was on freq. I think it's gone now, but from what I found at the time, I think someone had setup something to repeat UHF or Conv 800 on that freq....not sure if it was the department or just some nut.
