kc0rzw;2485540The 436 is much better than the 396 on simulcast. Not perfect said:
So, does anyone make a trunking scanner that -is- ready for prime time use?
I moved to Oakdale about a year ago and started the hunt for successful P25 decoding using a USB SDR dongle, Unitrunker, and DSD+ on Washington county 853.73750mHz and Talk Groups as found here. I tried all the suggested of tweakings and could never get reliable audio. Then I moved on to a Uniden BCD396XT with pretty much the same results. I did find one sweet spot on a East facing window sill with the 396 standing vertical and a 90 degree adapter allowing the RD antenna to positioned horizontally I would get about 90% decoding and it was actually listenable. In the spring the leaves came out on the trees and the decoding went back down the dumper so the BCD396Xt went back in the box. Then I found a older RadioShack PRO-96, programmed it up for 853.73750 and again very little solid audio. During the past year I have read just about all I could find on this subject, and tried a variety of antennas, the most recent is a 850mHz "Cantena" wave guide which I've only had time to try on the PRO-96. I have taken BCD396XT and the PRO-96 out in the mobile and found spots where I got 100% solid audio and other spots where I got 100% garbled audio, so I know that (at least in the 100% good spots) both radios do work.
As a point of reference, I'm located about a mile N.W. of the 694/494/94 intersection on the East side of the metro area. I am due West across 694 of one of the Oakdale water towers, about 3 miles South of the Washington/Dakota East #276 sight, and I am on the 3rd floor of a aluminum sided co-op. Also, I do not have any better luck getting good audio on the Ramsey/Hennepin/Dakota/Statewide (or any others that I have tried) ARMER systems. Simulcast/Multipath?, probably, but I've run out of things to try. At this point I'm selling the BCD396XT, keeping the PRO-96 as a general coverage scanner, and going back to the SDR radio to wait for a version of DSD (or such) that is closer to the software the big boys are using, and probably pick up a store bought when they get more reliable for me.
Still having fun tho!
George
WD0AKZ
