Go Back   The RadioReference.com Forums > U.S. Regional Radio Discussion Forums > Minnesota Radio Discussion Forum
Minnesota Radio Discussion Forum - Forum for discussing Radio Information in the State of Minnesota.
Old 11-14-2017, 12:35 AM
Default Minneapolis Fire
I'm having trouble receiving MPLS FIRE on my pro 106 . I live in New Brighton and use a radio shack 800 Mhz antenna.any help would be greatly appreciated.
Scott
Old 11-14-2017, 5:52 AM
What site are you trying to pick them up on.
Old 11-14-2017, 11:14 AM
I have tried both city center and N-S no luck.
Old 11-14-2017, 1:15 PM
They probably wouldn't be heard on city center (that's state and EMS "stuff"). N-S is MFD's "home" sub-system. Do you hear anything else "Minneapolis" on the N-S? If so, I'd suspect MFD might be locked out inadvertently.
You could also try Hennepin East just for the heck of it.
Old 11-14-2017, 3:35 PM
Only have fire nothing else from Minneapolis programmed into the scanner.I checked nothing is locked out.could I be to far away to hear them?
Old 11-14-2017, 3:37 PM
I have nothing but fire in my scanner for Mpls.I check it's not locked out.could I be to far away to hear them.
Old 11-14-2017, 9:37 PM
Do you have a programming cable??
Old 11-14-2017, 11:10 PM
See: ARMER Coverage Maps and go to the T109 site. This will display a theoretical signal strength coverage map. You can spot your location and get some idea of the signal strength.
Old 11-14-2017, 11:33 PM
I'm using win500 for programming.I have a Pro 106 with a 800 KHz antenna.
Old 11-15-2017, 11:21 AM
Sqaud1b i sent you a pm
Old 11-15-2017, 2:22 PM
Minneapolis Fire is essentially only on site 1-9 (almost all structure fires are patched with an ME-Tac; you will be able to hear them elsewhere). Trying anywhere else is not going to work.
Moving your antenna (inches or to the other side of the house) can make a huge difference. I* am in the white or yellow on that map linked above and am currently decoding ~100% of control channel messages and have a BER < 0.1%. I could move my antenna a few feet and have it be completely unusable. You should select only site 1-9 on your scanner (listen to everything on the site) and see where you are able to get it clearly and where you can't.
* I am using a somewhat directional antenna, the antenna is in front of a window and I am not using a typical scanner, but I think the basic point still applies.
