Go Back   The RadioReference.com Forums > U.S. Regional Radio Discussion Forums > Minnesota Radio Discussion Forum
Minnesota Radio Discussion Forum Forum for discussing Radio Information in the State of Minnesota.
Old 08-30-2007, 10:56 AM
Default Visiting MSP Area
I will be visiting the Minneapolis area this weekend and wondering if anyone can help out with some information. I am looking to listen to mainly Fire and the Airport. I have a BC246T and can I listen to the ARMER system or do you need a digital scanner? Any other help is appreciated.
Old 08-30-2007, 7:56 PM
Raven95150's Avatar
The ARMER system is digital, but there is also quite a bit of non-digital stuff you can pick up. The north/west areas of the metro area are mostly on the ARMER system, but the south/east areas are still mostly on conventional VHF/UHF. Where exactly are you going to be in the area?
Here is a link to some good info about the area: www.geocities.com/mn_metroscan
Also just so you are aware, mobile scanning is illegal in MN unless you have a ham license. If you plan on having it in the car with you, keep it out of sight and don't get pulled over.
KD0AXS
Metro Skywarn #7344
Uniden BCD396T, BC250D, BC350A
RS PRO-84
Yaesu FT-2800M, VX-170
Old 08-30-2007, 10:20 PM
Do you know of any good websites that have info about the conventional ones? Thanks!
Old 08-30-2007, 10:56 PM
Thanks for the link and your help. I will be in the St. Paul and Bloomington area. Thanks for the heads up about having it in the car!
Old 08-31-2007, 8:32 PM
Raven95150's Avatar
The link I posted above has conventional info as well...look under the "Non-digital public safety" section. Most of it is probably also available in the database here on RR.
KD0AXS
Metro Skywarn #7344
RS PRO-84
