Go Back   The RadioReference.com Forums > Regional Radio Discussion Forums > Mississippi Radio Discussion Forum
Mississippi Radio Discussion Forum Forum for discussing Radio Information in the State of Mississippi.
Old 06-05-2008, 10:14 PM
Default Gulf Coast
Looking at the database, I see 800/Jackson Co and VHF freq's for Ocean Springs. Which is the best set of freq's for Ocean Springs PD, and surrounding agencies (Fire, Jackson Co EMS, Sheriff, etc). Thx for any help....
If you can't stand the waves, learn to surf.
Old 06-05-2008, 10:39 PM
matthewtomek's Avatar
Send a message via Yahoo to matthewtomek
"Nexus" should be along soon to help you out with the specifics of who uses what, but my suggestion is to program everything listed in the database and see what you get more activity from.
Matthew Tomek
Dispatcher, Memphis Fire Dept
Memphis Fire Scanner
Old 06-08-2008, 08:22 PM
w8dm's Avatar
Default Jackson Co
Hello...
Use the 800mhz trunk freqs. Just about everyone is on the system now. Gulf Islands still uses vhf and I think OS school district may still be on UHF.
Don
W8DM
Ocean Springs, MS
SKYWARN
Jackson County and Harrison County EMA
Old 06-09-2008, 11:55 AM
bassmkenk2508's Avatar
Send a message via MSN to bassmkenk2508
OS Police Dept uses the Jackson County TRS, but they use the digital voice mode on (most of) their talkgroups, not analog. OS Fire Dept. uses analog on the county radio system though.
Their VHF no longer serves the city law/fire anymore, but public works, rather.
In regards to Gulf Islands, the rangers (??) use the VHF freq listed on the main county page, though not heard often.
I have not monitored OS schools much, but I submitted those when was able to confirm them. (Just program that one frequency and you will be fine. Ignore the tone, unless curious about differences.)
In regards to things non-Ocean Springs, the notations under the county 800 TRS as to digital and analog are up-to-date.
-Bryan
Old 06-09-2008, 12:01 PM
Oh and out of curiosity, what kind of scanner are you using?
Old 06-09-2008, 12:22 PM
My old PRO-97 handheld. Frankly, I have been out of scanning anything other than UHF, VHF for a year or so, so I don't even know if I have compatibilty with what's out there now.
What say you wisened ones?
Old 06-10-2008, 07:14 PM
w8dm's Avatar
Default Jackson County
Well, your PRO 97 should work for the analog stations on the trunking system. But as Bryan said, most of the stations are on digital now. Just look at the Jackson county info and you will see who you can hear.
Don
W8DM
Ocean Springs, MS
SKYWARN
Old 06-15-2008, 07:27 PM
Others beat me too it. DON'T program any of the VHF or conventional stuff in for any agency in Jackson County, which includes Ocean Springs. It's all very out-dated.
Several months ago 155.580 was being used by public works but I haven't heard anything on it. They probably went to the 800mhz system. All public Safety in Jackson County is using the Jackson County TRS. Every police department except for Gautier, and Moss Point are using DIGITAL, so you'll need a DIGITAL SCANNER like the PRO-96, Uniden BCD-96 or BCD-396T or the new GRE PRO600 in order to hear them.
Old 06-15-2008, 09:54 PM
Went back to Ocean Springs today with my newly loaded freq's. Scanner would often (though not continually) stop at the TG with the alpha designation OS Police and it sounded like a control channel. Huh? I realize Sunday radio traffic would probably be light, so there wasn't much other traffic while I was there. Moss Point dispatch came in fine. Some Gautier FD stuff. Arcadian Ambulance popped up several times.
Have I got something set wrong? I'm just guessing here, but I have the type set to MOT. Should it be something else- Conventional, etc? Why the 'control channel' sounds occasionally?
Thanks for ALL YOUR HELP AND PATIENCE with me.
Old 06-16-2008, 03:21 AM
You're not going to hear Ocean Springs police on your PRO-97. Its not a digital scanner. The only police departments on the Jackson County system you'll hear are GAUTIER and MOSS POINT. As I and others have said you'll need a digital scanner to hear all of the other police departments. A PRO 96, or Uniden BCD96 or BCD396T or the GRE PSR-500/600.
When you had Ocean Springs PD programmed in, and they talk, all "YOU" will hear is the digital sounds. Its not a control channel you're hearing, its them actually talking, but since you don't have a "digital scanner" you won't hear their voices, just the digital sounds. If you were able to hear Acadian Ambulance or Moss Point, or Gautier Fire, then your scanner is programmed right. IT SHOULD BE MOT not Conventional or ED.
Any TG that has 5 digits in it is a DIGITAL TALKGROUP. So you're only going to be able to listen to TG's that are 4 or less numbers in them. LIke say Gautier PD Dispatch is 1072
But if you program in 25616 for OS PD Dispatch, all you'll hear is digital sounds when they talk until you get yourself a digital scanner. So any talkgroup on the Jackson County system with 5 digits DIGITAL ONLY. Just use that as a guide.
My suggestion would be these for the most activity.
Moss Point PD Dispatch: 5616
Gautier PD Dispatch: 1072
Gautier FD Main channel: 1104
Jackson County County Wide: 80
(this one is used by inter-agency narcotic stings)
Acadian Ambulance: 1744
(patched from their freq 155.235 mhz)
Ocean Springs Fire: 4016
Old 06-16-2008, 06:51 AM
Thanks Nexus, I guess I'm "old school" and stopped paying attention to the technology a few years back when things started going digital. Looks like I'm in for a trip to ScannerMaster or something if I want to listen in.
Old 06-18-2008, 10:27 PM
There are cheaper places to buy from, but yeah a new scanner is required. My advice, DON'T buy a PRO-96. Its out of date, won't handle the new 700mhz trunking systems that are going up. Either a Uniden BCD396T or the new GRE PSR500 (which technically is who makes Realistic PRO scanners) to handle the new systems.
Old 06-20-2008, 09:24 AM
Thanks again. I'm gonna start poking around for some equipment.
Old 06-22-2008, 12:52 AM
Yea, I have a a Pro-96. I don't even use it. I say the only reason to have one (esp. in an area with 700 trunking) would be a secondary scanner to hear 800 trunking systems along with a primary system (main scanner) simultaneously. Yet, that is probably worthy of another thread; apologies, hehe.
Last edited by bassmkenk2508; 06-22-2008 at 01:05 AM.. Reason: Minor detail. No change in info.
Similar Threads
Gulf Coast area Kegan30317 Mississippi Radio Discussion Forum 0 05-27-2008 04:17 PM
Santa Rosa County (Gulf Coast) Stream UP Nightly ki4moc Streaming / Broadcasting / Audio Recording 3 02-26-2008 11:12 PM
Ham freqs to monitor Louisiana Dank Maryland Radio Discussion Forum 22 09-04-2005 06:29 PM
Active Hurricane Katrina Frequencies - HF blantonl HF/MW/LW General Discussion 18 09-04-2005 02:11 PM
Gulf coast ARES net Knobee HF/MW/LW General Discussion 0 09-01-2005 09:04 PM
