Oh, and Jeff I know where the tower is the Natchez Trace uses in the Mynot area. As I cruise around that area with the signal stalker on, and it finds a signal, it comes as a buzzing, and-or, white noise sound. As best as I can remember(almost positive) the frquencey was 166.235-and or-166.240. I can consistantly (sp) get this signal using signal stalker in that area. If I program these frequencies into the scanner I get this noice from several miles away(30 to 40) Approx. If it is going through the repeater it would be all along the Trace. It was annoying so I took them out of the scanner. Anyway if I purchased a apco scanner would I be able to hear the trace?
