Go Back   The RadioReference.com Forums > U.S. Regional Radio Discussion Forums > Mississippi Radio Discussion Forum
Mississippi Radio Discussion Forum - Forum for discussing Radio Information in the State of Mississippi.
Old 12-09-2016, 1:43 AM
Smile Harrison county digital scanner online
Looks like all of Harrison co is up and running. Sounds real good too.
Harrison County Public Safety
Old 12-09-2016, 10:57 AM
Wonderful. Thanks to whoever put the feed up, maybe the volume can be turned up a bit, I have to turn my volume almost full blast to hear it.
Bill (KH6SZ)
BCD436HP, TRX-1, Pro-668, Pro-528, Pro-51, Pro-38. 4 RTL-SDR USB Dongles.
HTX-202, MD-380, 3 Baufeng UV-5R
Old 12-09-2016, 9:51 PM
I hear you. I will make some adjustments later on tonite. I use a sound booster app.on android for my headphones.
Old 12-10-2016, 1:14 PM
The volume level is much better now! Thanks so much for providing the feed. I have the 436 with the provoice upgrade, but it's nice to have the feed when in my car and not have to worry about bringing the scanner along. Do you have all the talkgroups active that are in the RRDB? I've found many more talkgroups, but haven't verified them yet. I will submit them as soon as I do.
Bill (KH6SZ)
Old 12-10-2016, 2:27 PM
The psr800 stops on all talk groups. Even wild cards. I had to make a scanlist with only what we hear. I don't want any top secret conversations being leaked.
Old 12-10-2016, 3:42 PM
MississippiPI's Avatar
So are they are Provoice or what? I have a HP-2.
Be safe
MississippiPi
All over The Great State of Mississippi
Old 12-10-2016, 5:47 PM
milf's Avatar
Careful, I CAN hear you!
They are EDACS ProVOICE for now. With the EDACS being disconned though, and no longer supported, they will be upgrading to P-25 soon.
PRO-92, PRO-92B, PRO-96, BCD396XT, BCD436HP+DMR
APX6000XE
Old 12-12-2016, 12:41 PM
I USE DSD DECODER RUNIING ON A UBUNTU COMPUTER, THE OUTPUT IS CONNECTED TO A IBM COMPATIBLE PC RUNNING XP PRO, THE PSR 800 IS CONNECTED TO THE WINXP FOR TXT TAGS WITH THE SCANNING SOFT WARE. WHATS COOL ABOUT THE PSR 800 IS THAT THE DISCRIMATOR PORT IS BUILT IN THE AUDIO PORT, WHICH SAVES TIME LOCATING IT . ANOTHER GOOD THINS ABOUT THE PSR800 IS THAT IT FOLLOWS EDACS TAlkGROUPS JUST LIKE THE EARLIER VERSIONS OF THE GRECOM PSR500, BUT I HAD TO PUT THE DISC TAP ON THE CASE FOR THE EXTRA PLUG PORT. I BEEN WORKING ON DSD DECODER SINCE 2006 AND I BEEN WITH THE DEVELOPMENT STAGES SINCE ITS CONCEPTION. ITS JUST A HOBBY OF MINE FINDING DIGITAL SIGNALS AND DECODING IT INTO VOCALS OUR EARS CAN HEAR. THE PSR 800 IS TDMA X2 READY FOR IN THE FUTURE THEY CONVERT. THANKS FOR LISTENING AND ENJOY THE AUDIO. TELL YOUR FRIENDS ABOUT THIS.
Old 12-15-2016, 2:05 AM
Updating the CPU and dsp firmware tonight to the latest versions on the psr800
Old 12-15-2016, 12:40 PM
Since did this. Everything sounds good
Old 12-17-2016, 5:21 PM
Default Setup
In case you were wondering
Old 12-28-2016, 3:19 AM
scanphreak's Avatar
What happen to the feed?
Sent from my SCH-R970X using Tapatalk
Old 12-29-2016, 8:54 AM
Will be back sasp
Will be back asap
Old 02-24-2017, 11:29 PM
scanphreak's Avatar
Audio is really low now.
Old 02-25-2017, 10:53 AM
Right now its off line. I tried my WOLprogram to reboot it remotely. I do everything with static IP and VLC 99% of the time. I am no where near the psycal computers or radio. Its all remote controled
Old 02-25-2017, 10:54 AM
It will be restarted today and back to normal.
Old 02-26-2017, 2:12 PM
It's still down....
Be safe
MississippiPi
Old 03-27-2017, 10:09 PM
scanphreak's Avatar
What happened to the feed?
Old 04-18-2017, 10:17 AM
Did you give up on getting the feed back up or is it a work in progress. I miss it. Just wondering.
Bill (KH6SZ)
Tags
digital, edacs, gulfport, provoice, scanner
