Go Back   The RadioReference.com Forums > U.S. Regional Radio Discussion Forums > Mississippi Radio Discussion Forum
Mississippi Radio Discussion Forum - Forum for discussing Radio Information in the State of Mississippi.
Old 10-17-2018, 5:22 PM
Default Amite County
OK, I think I'm getting enough info on some new talkgroups that I can put this out for people to check.
30401 S.O.
30412 Liberty PD
30416 Unknown fire (possibly Liberty)
Old 10-17-2018, 7:02 PM
milf's Avatar
Careful, I CAN hear you!
30401 S.O.
30412 Liberty PD
Most likely County EOC dispatch for all VFDs... Most of the rural counties do it this way. One dispatch for all EMA/EMS/VFD and then Tac/FGs for each FD.
Radio Shack: PRO-92, PRO-92B, PRO-96
Uniden: BCD396XT, BCD436HP+DMR & NXDN
Motorola: APX6000XE
Baofeng: RD-5R
Old 10-20-2018, 4:00 PM
Probably correct. More monitoring will tell. Could also be a common PD dispatch channel like Pike has. Will keep posted with findings. Also, think I'm getting T.G.'s for Marion figured out.
Old 10-30-2018, 3:25 AM
milf's Avatar
Hint: If that Fire/EMA dispatch IDs as Liberty Base,... Its the EOC.
Sheriff IDs as SO Liberty. Or at least that is how they used to do it.
Motorola: APX6000XE
Baofeng: RD-5R
