Go Back   The RadioReference.com Forums > U.S. Regional Radio Discussion Forums > Mississippi Radio Discussion Forum
Mississippi Radio Discussion Forum Forum for discussing Radio Information in the State of Mississippi.
  #741 (permalink)
Old 02-17-2011, 8:34 PM
KE5TLF's Avatar
Ok, that's both interesting and wierd. Maybe the solar flare glitched the tower? hehe Mobile extender maybe? Keep an eye on it for sure.
Might try backing up, or deleting, that tower text file and running it again with a clean slate. Could be a Pro96com glitch of some sort.
  #742 (permalink)
Old 02-18-2011, 6:41 AM
fryan's Avatar
Yeah, I agree with you... After looking at it a little closer, it was on the Jackson site as well, I looked at all the other sites around Jackson and it wasn't on any of those, so you got me... I'll keep watching it the next couple days..
  #743 (permalink)
Old 02-22-2011, 9:04 PM
KE5TLF's Avatar
Well we have our first site registration cancellation for Phase 2. Site 20613 Martin. Wonder if this one is going to end being Phase 2's version of Jeanette.
ASR Registration 1274525
13 new draft EA's submitted for Febuary 2011.
FEMA: Environmental Documents and Public Notices in Region IV
  #744 (permalink)
Old 02-26-2011, 4:46 PM
KE5TLF,
Do you pick up the George County SO dispatch and officers very well?
  #745 (permalink)
Old 02-26-2011, 5:17 PM
KE5TLF's Avatar
Yeah, I can get them pretty well if I want too. I have a 800 yagi on a rotator so when I aim it that way I can pretty much always get them on the Benndale tower. The Lucedale tower is a little less reliable unless I aim directly at it.
Sometimes they have a unit affiliated on the Vancleave tower too which I always scan.
Here lately though I've been locked in on the Mobile County TRS with that antenna trying to figure out the City of Mobile's new talkgroups there.
  #746 (permalink)
Old 02-27-2011, 1:20 PM
I broadcast the George County Fire, EMS and VHF SO feeds. I've been considering getting a scanner that I can send out their 700Mh. We generally are having problems in our dispatch center with the recorder, radios, etc. In fact, the only recording of the radio traffic in chase that ended in Sheriff Welford's murder, was my feed archives off RR. So I know if I get a scanner for their MSWIN freq, it could be very beneficial. Is there a scanner that you recommend for the 700Mh scanning? Just looking to do the Lucedale and Benndale towers.
  #747 (permalink)
Old 02-27-2011, 2:23 PM
KE5TLF's Avatar
Well there's a couple things to consider off the top of my head. The Uniden base/mobile models make it easy to listen and send feed audio simultaneously with their built in line out jack. I'm not sure but I think you can only send alpha tags with Uniden's too.
Those models would be the 996T, 996XT, and HP-1 from oldest to newest. Out of those three I'd choose a 996 XT. It would be my overall top choice amongst all scanners for audio feed purposes.
Other than that any of the others should work just fine too. Just depends on exactly what's most important to you personally.
The RS PRO-106/197's have been going on sale for some pretty tempting prices and have a bit better recieve sensitivity. Which is generally a plus on 700/800, but in turn it can make them a bit problematic for the VHF stuff.
  #748 (permalink)
Old 02-27-2011, 2:44 PM
Ok. Thanks for the info. I'm just looking to do the 700Mh with this scanner.
  #749 (permalink)
Old 02-28-2011, 7:28 PM
You can also send the alpha tags while streaming with the Pro-106 and the Pro-197.
Pro-197 & PSREdit500 - Uniden BCT15X & FreeSCAN - Vertex FTL-2011 - Yaesu FT50R
  #750 (permalink)
Old 02-28-2011, 11:11 PM
KE5TLF's Avatar
Ah ok. Thanks for that.
  #751 (permalink)
Old 03-02-2011, 6:19 PM
Smile Covington sheriff's department gets $25,000 grant
Covington sheriff's department gets $25,000 grant | Hattiesburg American | hattiesburgamerican.com
COLLINS – A $25,000 grant has been awarded to the Covington County Sheriff’s Office for the purchase of 700 MHz radios that will allow critical interoperable communications with other first responders.
  #752 (permalink)
Old 03-02-2011, 8:11 PM
thanks KE5TLF and Bama9999.
  #753 (permalink)
Old 03-17-2011, 8:58 AM
Default Dumb question time.
Why isn't Hinds using TDMA?
  #754 (permalink)
Old 03-17-2011, 7:21 PM
fryan's Avatar
Smile Hinds Co.
Because there using there old whore out 800 Mhz smartzone system that hasn't been rebanded yet. I would venture to say it will be along time before you see Hinds Co on it for primary use purposes.
  #755 (permalink)
Old 03-17-2011, 9:16 PM
KE5TLF's Avatar
Big time ducting underway on 700 right now.
Have a good lock on 102, 103, 104, 105, 106, 107, 110, 111, 114, 123, 231 here, along with my usual 118, 119, 120, 144
15 sites, not too shabby.
  #756 (permalink)
Old 03-19-2011, 6:50 AM
Smile Big band Opening
LWIN Delhi
FileVersion:6
-TowerInfo
#This section is here for information only. With the exception
#of the Call Sign(s), This data is not Read back into the program at all.
System ID : 1BD
System Name :
WACN : BEE00
Tower Number (Decimal): 304
Tower Number (Hex) : T0304
Tower Description : (null)
Control Capabilities : Data,Voice,Registration
Call Sign(s) :
Timestamp : Sat Mar 19 05:39:33 2011
-Tables
#Format: Table ID,Base Freq,Spacing,Input Offset,Assumed/Confirmed,BandWidth,Slots
00,851.00625,0.00625,-45.00000,"Confirmed",0.00625,1
01,762.00625,0.00625,30.00000,"Confirmed",0.00625, 1
-Frequencies
#Format: Channel,Usage,Frequency(/Slot),Input Frequency(/Slot),Hit Count
"01-1328","v",770.30625,800.30625,4
"01-1452","v",771.08125,801.08125,4
"01-1520","v",771.50625,801.50625,4
"01-1572","v",771.83125,801.83125,4
"01-1770","c",773.06875,803.06875,0
"01-1810","a",773.31875,803.31875,0
-Neighbors
#Format: TowerID,TowerIDHex,System ID,Channel,Frequency,Tower Name
302,"T0302",1bd,"01-2052",774.83125,""
312,"T030C",1bd,"01-1344",770.40625,""
318,"T0312",1bd,"01-1894",773.84375,""
320,"T0314",1bd,"01-1814",773.34375,""
325,"T0319",1bd,"01-1150",769.19375,""
326,"T031A",1bd,"01-1226",769.66875,""
334,"T0322",1bd,"01-1152",769.20625,""
339,"T0327",1bd,"01-1314",770.21875,""
342,"T032A",1bd,"01-1184",769.40625,""
343,"T032B",1bd,"01-2048",774.80625,""
  #757 (permalink)
Old 03-21-2011, 8:46 PM
Default Bad information
I don't know where your getting your information but DPS/MHP has decided not to join the MSWIN system. The new commissioner has agreed with the State Troopers association not to move to the MSWIN system due to the huge amount of network dependence in it. There is no mandate for MHP to use the MSWIN system and there are current plans to upgrade the VHF low band system such as CHP is doing with the CHIPEERS plan. That upgrade will include rolling code encryption.
You really don't need to discuss this in a public form as its a matter of officer safety.
  #758 (permalink)
Old 03-21-2011, 10:26 PM
Um, the only time it would be for officer safety is if it was a MBI agent. I find it odd they try to align their name with other states but its the Mississippi Highway Safety Patrol. The only people I would call Troopers are those that work for MBI or MBN. Additionally if it was a matter of officer safety they would have upgraded their system long ago.
Take for example , NY State Troopers are Peace officers and respond to residential calls as well as calls on every surface street in their district as well as the state. The regular Highway Patrol is limited to the state and federal highways.
Oh, where can I read this official announcement as its the first I have heard of it. I will go back to listening to Troop J now.
  #759 (permalink)
Old 03-22-2011, 12:08 PM
bee bee is offline
What is. rolling code encryption?
  #760 (permalink)
Old 03-22-2011, 6:56 PM
KE5TLF's Avatar
Just noticed another ownership change for all the Phase 1 leased towers. SpectraSite Communications, Inc. through American Tower, Inc. is now the listed owner of all P1 sites not owned by the MWCC. Updated the MSWIN wiki article with the new info. I had also added a couple of new maps a few days ago that you guys might like to see too.
MSWIN
oh and MHP is already outfitted with MSWIN gear so please feel free to keep your "hog"wash confined to your stupid little blog.
