Go Back   The RadioReference.com Forums > Regional Radio Discussion Forums > Missouri Radio Discussion Forum
Missouri Radio Discussion Forum Forum for discussing Radio Information in the State of Missouri.
Old 04-18-2009, 03:20 AM
Talking Question on Trunking Scanners
I am in law enforcement in st louis and i live about 12 miles from where i work. My gf is wanting to be able to hear me talking on my radio from my car. Anyone have any suggestions on a good scanner to buy or what to do I am new to the scanner scene. Thanks
Old 04-24-2009, 08:44 PM
bill44's Avatar
Default what dept
what kind of system does your dept use,uhf ,800 ,700 ?
bill
Old 04-25-2009, 02:12 AM
I'm thinking we are 800
Old 04-25-2009, 03:24 AM
BaLa's Avatar
Send a message via ICQ to BaLa Send a message via Yahoo to BaLa
what city/department do you work for?
VFB Stuttgart Deutscher Meister 2006/2007
Uniden BCD396T
RS Pro 92(b), 95, 96
Kenwood TK-280 (146-174MHz)
Old 04-25-2009, 03:34 AM
n5ims's Avatar
From the data in the database, you'll need to have a digital scanner to receive the St. Louis PD system since it's P25 digital system Scanner Frequencies: St. Louis Metropolitan Police Department (P25) Trunking System, St. Louis, Missouri
I don't see where they do any encryption so you should be OK with a digital scanner such as the GRE PSR 500 or PSR 600, the Radio Shack Pro 106 or Pro 197, or the Uniden BCD 996 or BCD396. See here for more info on the digital trunking scanners Categoryigital Scanners - The RadioReference Wiki
Please note that if any transmissions are encrypted, these will not legally be received by the scanners.
Please note that the smily face in the URL is just because it contains the codes that cause it to be displayed that way ( : followed by D ). The link appears to work anyway. It does look wierd though, I'll admit.
Last edited by n5ims; 04-25-2009 at 03:37 AM.. Reason: adding note about smiley face
Old 04-25-2009, 01:19 PM
Default Thanks
Thanks for all the great info I will look into all of them, and to answer the question of what dept, Pagedale (North County), it uses M.R.S. (municipal radio service) Communications
Old 04-26-2009, 10:53 AM
btritch's Avatar
Send a message via MSN to btritch Send a message via Yahoo to btritch
From What I'm Seeing On What You're Describing And From This Link On Where You Said It Was: > St. Louis County, Missouri (MO) Scanner Frequencies and Radio Frequency Reference, < It appears you are right, They are on MURS Channels, Otherwise it will be full VHF High channels if not, Either way, All of these can be monitored from a regular old scanner from radio shack etc. But as n5ims said, if it's encrypted, Legally you will not be able to monitor it due to Law. Hope This Helps.
Brian
Paragould/Greene County Arkansas 72450
Online Area Scanner Feed: http://greene.ar.scanamerica.us/
Old 04-26-2009, 11:12 AM
fmon's Avatar
Brian,
I spend the night in a motel in or near St Louis every year in late May going to and from a reunion. They will need one of the scanners listed in post by n5ims, though the Pros 96/2096 will work also. My last trip through was with GRE 500 & 600. Getting ready to return in 3 1/2 weeks with same scanners and they do the job perfectly. She can follow his traffic at will.
Frank
RR Wiki Programming Shortcuts
Old 04-26-2009, 11:41 AM
btritch's Avatar
Ok, I was just going by the area description that he gave on what was listed. No matter what he needs, Always good to have more than needed just in case :-) Whereas if it IS only an analog needed, Good to have digital just incase. They only thing I saw that was digital was St. Louis City, He was describing MURS channels which matched up and were VHF. That's why I was suggesting that, If that's what he needs then that's what he needs to get, lol
Thanks For The Correction..
Brian
Old 04-27-2009, 02:45 AM
shaft's Avatar
They dont use M.U.R.S, they have a centralized dispatch center that handles several departments. The freqs that are used are VHF-Hi. 155.975 is the one used for Pagedale.
Similar Threads
New to trunking and scanners JWTL Trunking Forum 1 05-16-2007 05:18 PM
Question on Iowa Trunking daren77 Iowa Radio Discussion Forum 6 03-24-2007 01:31 AM
A basic Trunking Question - newbie daren77 Trunking Forum 3 02-25-2007 10:39 AM
new trunking antenna for the 785d and 796d scanners jpm Antennas and Coax Forum 10 03-14-2005 09:09 AM
Trunking Protocols MaxTracker System Administration and Maintenance 3 01-25-2005 04:31 PM
