Go Back   The RadioReference.com Forums > U.S. Regional Radio Discussion Forums > Missouri Radio Discussion Forum
Missouri Radio Discussion Forum Forum for discussing Radio Information in the State of Missouri.
Old 08-18-2011, 12:52 PM
Default Jackson County Sheriff
I've been hearing Jackson county running totally simplex with their dispatcher on 155.79 lately, instead of the 155.79/155.97 duplex operation.
Does anyone know what that's about?
Old 08-18-2011, 8:35 PM
KC0CSE's Avatar
Default jackson co
ya I get them on 155.7900 too but no car to dispatch.....so I guess it would be simplex...i think it's called similcast or something....they are digital now...Mike
Old 08-18-2011, 9:54 PM
scannerowner's Avatar
I confirm it too, was getting ready to post here.... Mike you say they're digital now?? Like on the Independence system or what?! What talk group are they??
CERT Member
NWS Storm Spotter
Scanners Include: Uniden BCD996T & Uniden BCD396XT
Old 08-21-2011, 2:12 AM
hkrharry's Avatar
Member - RR DB AdminMo/Ks
From a friendly at the Jax Co SO.
Sent: Wednesday, July 13, 2011
Subject: IMPORTANT RADIO INFORMATION
Due to some recent interference we have moved the date up for radio reprogramming to Aug xx
Below is a list of the actual radio frequencies and the tone squelch that needs to be placed in each radio.
The tone squelch must be on transmit and I would recommend that you put it on the receiver as well.
Since this change will effect so many, here is how its going to happen.
On Aug xx , we will reprogram our base radios to the new channels,
we will leave one base radio on the “old system”, to handle calls for those of you
that do have the radios changed on the xx.
Once you have the radios changed over please let dispatch know, as soon as everyone has made the change over we will reprogram the remaining base station to the new channels.
This change will do away with the semi-duplex system that we have had for ever.
This change will give us two dispatch channels, channel 1 and channel 2, and a car to car.
This will enable all users to hear all the radio traffic, and should reduce the double transmissions that we have,
Everyone will be able to hear the other one if close enough.
This will not change the range of the radios.
Also if we are holding the air on channel 1, we can continue business
as usual on channel 2, something that we currently are not able to do.
We also will be narrow banding the radios so that we are 2013 compliant.
The transmitter power will remain the same, there is special circuitry in the newer radios to make up for the lower width of the signal. (25 to 12.5)
So make sure you have the radio programmed as narrow band.
CHANNEL 1 155.790 N SIMPLEX TONE OF 156.7
CHANNEL 2 154.100 N SIMPLEX TONE OF 156.7
CHANNEL 3 155.970 N SIMPLEX TONE OF 156.7 (CAR TO CAR ONLY)
xxxxxxx
Jackson County Sheriffs Office
Communications unit
So now you have the rest of the story......
HH
