| Missouri Radio Discussion Forum Forum for discussing Radio Information in the State of Missouri. |
02-08-2012, 8:52 PM
The infra-structure of the system is Motorola but many of the radios that need rebanding were replaced by Nextel under the rebanding agreement. They were replaced by the original manufacturer with upgrades to P25 in anticipation of the switch to P25. Radios that didn't need rebanding were replaced with Motorola P25 radios. For the most part P25 radios can be purchased from any manufacturer and work on any P25 system. The original system was simulcast and was just changed to P25 digital. The system has been completed for some time but there are still a lot of radios to install.
02-16-2012, 10:42 PM
Ok sounds good, does this mean they will continue to simulcast until all radios are installed? What other radios need to be installed?! I'm waiting til South Platte FD gets online and all whomever else will join...
On a side note, I thought I saw ID:33115 pop up, anyone have any ideas what it may be? I don't remember the conversation that was going on to decide what was going on.
CERT Member
NWS Storm Spotter
Scanners Include: Uniden BCD996T & Uniden BCD396XT
02-16-2012, 11:15 PM
Yes, they will continue simulcast. It's how they achieve the required coverage.
02-17-2012, 8:16 AM
Currently they are running the old EDACS and the new P25 systems side by side. They are switching each user group of EDACS radios over to the P25 system. Once they have completed switching all the old radios over and finished installing all the new radios they will switch the old EDACS channels over to P25 operation. Both the old EDACS and the New P25 systems are simulcast as mancow indicated. Each site will have the same number of channels and will transmit the same information on each channel at the same time.
BB
02-17-2012, 9:06 AM
so....is the p25 system going to get any better in the future? .....sunny day's are bad.....cloudy day's are good....garble garble garble....
PRO 106
PRO 197
02-17-2012, 9:10 AM
Probably not.
02-17-2012, 9:27 AM
The simulcast distortion occurs because of RF overlap from the locations of the existing sites. There are no plans to change the locations of any of the existing sites. Therefore the coverage is what it has been and what it will continue to be. Analog radios (and our ears) can tolerate this distortion more readily. Commercial digital radios are designed to compensate but many of today's digital scanners have a very difficult time with it. Hopefully the next generation of digital scanners will do better.
BB
02-18-2012, 12:26 AM
Sounds good guys... thanks for clarifying... now my next question, anyone know who is in the 33300 range? It sounds like maybe city, but I'm not sure?!
CERT Member
NWS Storm Spotter
02-18-2012, 12:09 PM
I've not really had any issues receiving MARRS mobile, or via portable just south of Lees Summit West HS.
Scanners will have trouble decoding pretty much any P25 simulcast system... if you're not having much luck, try using a paper clip in place of a proper antenna.
02-18-2012, 6:35 PM
Paper Clip antenna
Yes the paper clip work's....when it's clear and sunny out side that's when the reception is at it's worst!! that's when I take off the 800mhz antenna, and use the paper clip......yes it work's!....a $300.00 scanner and a penny paper clip....wow where are we going wrong?????
PRO 106
PRO 197
02-19-2012, 8:51 PM
PRO 106
PRO 197
And if all that fails, try standing on your head facing the sun with one of your legs bent at a 90-degree angle, and lay your hand on a metal surface, you might actually get reception!
02-20-2012, 7:04 PM
rabbit ear's
This brings back memory's of my dad having me hold the "Rabbit Ears" for the black & white tv trying to get better reception...oh all so he put aluminum foil on the ear's too...never did get that one....till now....Look what were doing with digital scanner...history repeat's it's self......are we going forward? or backward?...and so I submit the question......
PRO 106
PRO 197
02-24-2012, 5:10 PM
Anyone else hearing activity on 4005332 ?
I've been running my new Digital Scanner for a couple weeks now and have never seen such an odd TG show up...
HP
btw,it was quite brief so I couldn't tell exactly what was being discused
02-24-2012, 7:52 PM
That is a radio Id number, you were hearing an ICall. 5332 is one of the radio shop guys.
03-01-2012, 2:37 PM
Thanks a lot.
I wasn't aware that the Pro-197 picked up I-Calls.
I suppose the "Private" setting in the menu should have been a tip-off !!
Is there an easy way to know which Zone or radio number it is based on the displayed ID ??
HP
03-03-2012, 4:30 PM
Mokanscan kansas city
MOKANSCAN has talkgroups listed for Med channels for all the Hospitals in the area....LifeFlight is the only one I am getting....they must not be on board yet....any word on this yet? or when they might go live?...
PRO 106
PRO 197
03-03-2012, 4:43 PM
PRO 106
PRO 197
Last I heard MARCER hospital channels were supposed to go digital March 1st. That date has came and went, so who knows for sure. Everyone remains on analog Moto for the time being...
03-03-2012, 5:24 PM
Mokanscan med talkgroups
Well I went ahead and put in all the talkgroups that MOKANSCAN had in there data base for all the med groups....this site should soon be posting them also I would think....
03-04-2012, 2:03 AM
They are the same, been some testing on them last week, and heard some EMS crews trying to call a few hospitals.
