Go Back   The RadioReference.com Forums > U.S. Regional Radio Discussion Forums > Missouri Radio Discussion Forum
Missouri Radio Discussion Forum Forum for discussing Radio Information in the State of Missouri.
  #541 (permalink)
Old 01-09-2013, 7:08 PM
KC0CSE's Avatar
Originally Posted by scannerowner View Post
The one on the roof should be for MOSWIN, not sure about 1/4 wave maybe their VHF channels like Car to Car? The taller one should be the "tail whip" I'd think.
why would they use a 1/4 wave for the system on the roof?
  #542 (permalink)
Old 01-09-2013, 7:13 PM
scannerowner's Avatar
Not sure, I wouldn't think they would need too much to get signal. Most sites are easily received I would think. Someone else may know more than me.
CERT Member
NWS Storm Spotter
Scanners Include: Uniden BCD996T & Uniden BCD396XT
  #543 (permalink)
Old 01-09-2013, 7:17 PM
KC0CSE's Avatar
a 1/4 does not have that much gain...but you have a point if the repeaters or what ever they call them are close..they my not need gain...
  #544 (permalink)
Old 01-09-2013, 9:03 PM
A 1/4 wave in the center of the roof will outperform a 5/8 wave on the trunk or fenders.
Judging by the picture it appears that the roof antenna is one of the wideband types with a thick whip.
Some MOSWIN sites use federal frequencies in the 162-174 band. A standard 5/8 wave mobile antenna will not cover the whole 150-174 band.
Tom
  #545 (permalink)
Old 01-10-2013, 6:18 PM
KC0CSE's Avatar
Question
[QUOTE=nd5y;1890887]A 1/4 wave in the center of the roof will outperform a 5/8 wave on the trunk or fenders.
Some MOSWIN sites use federal frequencies in the 162-174 band. A standard 5/8 wave mobile antenna will not cover the whole 150-174 band.[/QUOTE
ok....I guess i will buy that...where would one get one of those "thick whip" 1/4 wave antennas?? I guess I have not seen one before..."Thick Whip"....73's
wait ......1/4 wave has more gain than a 5/8 wave?...let me think about that...
  #546 (permalink)
Old 01-10-2013, 6:24 PM
KC0CSE's Avatar
the set up again...
  #547 (permalink)
Old 01-10-2013, 7:40 PM
They are marketed as "wideband 1/4 wave" antennas. Google it. I see them a lot on federal vehicles an others that need wide frequency coverage. They cost a lot more than the chrome nut type 1/4 wave antennas with the thin whip that doesn't require a spring like the one on the rear right fender or trunk. The picture is not good enough to see the base of the one on the roof clearly but it is proably a Maxrad MWV1365S VHF and UHF Wideband Antennas No Tune PCTEL
No. I didn't say a 1/4 wave has more gain. I said a 1/4 wave in the center of the roof will outperform a 5/8 wave on the trunk or fender.
Tom
  #548 (permalink)
Old 01-10-2013, 7:53 PM
KC0CSE's Avatar
Smile
point taken...have good one.. and thanks for site for the antenna...
  #549 (permalink)
Old 01-10-2013, 8:19 PM
It is a Motorola had4017 the antenna on the trunk is a base loaded quarter wave 40mhz antenna.
Sent from my iPad using Tapatalk HD
  #550 (permalink)
Old 01-11-2013, 8:44 AM
hkrharry's Avatar
Member - RR DB AdminMo/Ks
Thumbs up MHP Antenna layout....
the set up again... See Attached Picture....
This is from a friendly MHP radio tech....
Top center spring loaded is a 1/4 wave, 18.5" long.
Behind it on the roof is a phantom whip less for the 148.600 low-band repeater
On the chargers, passenger side trunk is either a VHF or an 800 MHz 1/4 wave for the scanner.
Center of trunk is base loaded 1/4 wave for 42 MHz, trunk drivers side is a 1/4 wave for VHF mobile radio.
On hood is a 700 MHz 1/4 wave for the 700 side of the MoSWIN radio, and back trunk deck is another 700 MHz 1/4 wave for the mobile repeater for the MoSWIN extenders.
HH
  #551 (permalink)
Old 01-11-2013, 9:09 AM
HH
Great info! Can you tell us if the 148.600 low-band repeater is used state-wide? For some reason I remember it being used in most places, but not all.
  #552 (permalink)
Old 01-11-2013, 12:58 PM
KC0CSE's Avatar
HH
Thank you for clearing this up...case closed....now we know....
  #553 (permalink)
Old 01-11-2013, 4:03 PM
Good info there.
Does anyone know if there has been activity at the Massman site or am I missing it all?
  #554 (permalink)
Old 01-11-2013, 4:49 PM
KC0CSE's Avatar
Originally Posted by kctek View Post
Good info there.
no your not missing anything...I have my 106 only on troop A& StJoe troop...and nothing but nothing
  #555 (permalink)
Old 01-11-2013, 9:42 PM
hkrharry's Avatar
I would have to say it is used statewide.
Our resident MHP Radio tech lurks here on a regular basis, maybe he will chime in.
HH
  #556 (permalink)
Old 01-12-2013, 9:21 AM
Every day Clinton Co and Cameron PD Talk on the Lawson Tower, Troop H talks from time to time on the Jackson Co and Lawson tower
  #557 (permalink)
Old 01-12-2013, 9:33 AM
KC0CSE's Avatar
I must have something programed in wrong...Im not that far from you and I here nothing...
  #558 (permalink)
Old 01-12-2013, 9:42 AM
KC0CSE's Avatar
106
  #559 (permalink)
Old 01-12-2013, 11:38 AM
It's do not think it is a repeater per se but it is a "mobile extender" which is kinda like a repeater that is located within the troopers cars.
The frequency is still used here in the St. Louis area.
At least that is how they were licensed when you could find the info on the FCC site.
  #560 (permalink)
Old 01-12-2013, 12:35 PM
KC0CSE's Avatar
Does this look like it should? For MOWIN It's also on "Roam" 95high 75low
Tags
moswin
