Go Back   The RadioReference.com Forums > U.S. Regional Radio Discussion Forums > Missouri Radio Discussion Forum
Missouri Radio Discussion Forum Forum for discussing Radio Information in the State of Missouri.
  #701 (permalink)
Old 03-05-2013, 9:29 PM
I heard a lot of Troop E dispatch to troop E troopers today but on the Weldon Spring tower which is Troop C. Did not log any Troop C activity.
The conversations were not simulcast from Low band as there were no low band call signs heard at all on any of the MOSWIN transmissions. If it were a simulcast of low band, you would hear the familiar KAAxxx call signs they have used for years.
I can also pickup Troop E on low band but did not once hear them calling the trooper they were talking with on MOSWIN. They seem to be testing MOSWIN with select troopers radios only.
And in this case, someone with a radio on Troop E's talkgroup happened to be affiliated with the Weldon Spring site. I usually hear Troop E traffic on the Imperial tower way more than the Weldon Spring tower.
  #702 (permalink)
Old 03-05-2013, 9:38 PM
scannerowner's Avatar
I've been seeing more and more Chargers with MOSWIN antenna's on them, so I figure they're getting closer. I wonder when they're going to get everyone testing it. It seems like select troops.
Anyone know why they have Dispatch 1, 2, and 3? Are they for different geographical locations, and depending where they're at they would have to be on Dispatch 1 or 2 or 3?? Guess this will match up with the car channels, guessing it's car to car.
CERT Member
NWS Storm Spotter
Scanners Include: Uniden BCD996T & Uniden BCD396XT
  #703 (permalink)
Old 03-06-2013, 3:54 PM
That can be a big unkown as well. Dispatchers who have that embeded into their brain might still say it just out of habit for a while. Good to know though that there is quite a bit of system wide testing going on.
  #704 (permalink)
Old 03-07-2013, 12:01 AM
Got home today from work to see a lot of logs and recordings on MOSWIN finally.
Heard quite a bit out of Troop F today(3/6) on the High Point site(ID 20155). Some testing on the lake of the ozarks(only one specific location heard; hurricane deck bridge) and heard regular operations dealing with a vehicle crash northwest of Columbia.
Also heard unit 669 on ID 5202 hailing Laclede calling it "travel channel". Was giving a fuel report on the van and said he was in Miller county at Hwy 54 and Hwy 52
  #705 (permalink)
Old 03-07-2013, 3:50 PM
That's some encouraging words, wish they'd start using it in the other troops. I hate waiting... I've just heard tid bits here and there, but atleast it was something!
CERT Member
NWS Storm Spotter
  #706 (permalink)
Old 03-07-2013, 10:46 PM
Default MOSWIN reception
Today I also heard traffic on ID 55 (troop E) in the St Louis area. I also believe that it was coming from the Weldon Spring (site 316) site. So there must have been a radio in the area that was "affiliated" and tuned to troop E. Very cool hearing cars in Poplar Bluff in the St Louis area, and even on car that had gone to Arkansas for training!
This is my first attempt at receiving MOSWIN. I hope it doesn't take as long to learn as StarCom 21 did. And I am assuming that like everyone else this is still a learning experience. So I want to add a question.
I have only about 8 "sites" programmed in my 396xt for MOSWIN. But I think I am having a conflict with two of them. They are site 309 (madison co) and site 327 (jefferson co). I hope I can explain. I am in St Louis so I really should not be able to pick up site 309 but it's alternate cc is 152.6100 and I am receiving data on that channel (actual data noise but no traffic) It shows up on my screen as site 327 not 309. Jeff co site 327 which I can hear well is using cc 152.6000 and it shows up correctly as site 327.
My question is, "are 152.6000 and 152.6100 close enough to be heard as the same channel on the 396xt, or any scanner?" I didn't think so. But I think I am probably wrong. Anyone with any ideas?
  #707 (permalink)
Old 03-07-2013, 11:34 PM
Yes, you will pickup Imperial's CC on 152.610 even though it's true frequency is 152.6000. Scanners in general do not have very tight front ends even when in the so called NFM mode.
What I'd do is remove 152.610 from site 309 in your programming. That way it should still get all of 309 when you are in that area providing they are using the primary control channel which I think they are for that site.
You would lose site 309 if they did switch to the alternate. I've not seen many of the sites switch to the alternate CC's after zone testing was completed. And when I did see a switch to the alternate, it was only for a matter of minutes.
Or maybe a better idea would be to just lockout the entire site 309 when not in range and unlock it when you travel down that way. I've only been able to copy 309 a few times from my location when conditions were very good. And they were using the primary control channel when I was able to copy that site.
That is also a trick if you are getting interference on say 152.600, try programming the sites control channel 5 or 10 kHz above or below the true frequency and you can sometimes get far enough away from an interfereing signal to allow reception. That trick sometimes worked very well for good ole analog signals but not sure how well it works on a P25 signal. The fact that you are decoding Imperial when the scanner is tuned to 152.610 does tell me the trick does still work though.
Then you should have the IF shift feature that you could also play with and see if you can get 152.610 even further away from 152.600 so it would still allow proper reception of 309. Or you could try programming 152.610 as 152.615 and see if it then stops showing site 327. Of course you would need to wait until they used the alternate CC to see if it still decoded correctly.
I'm not postitive the 396XT has the IF Exchange feature like the 996XT does but I think it does. I've never needed to use that feature so I have no idea how far you can tweak the displayed frequency from the true frequency but it may be just enough to stop decoding site 327.
I think for simplicity, I'd just lockout site 309 when not in that area.
I sometimes let my 996 scan ALL MOSWIN sites just to see if conditions are good and I'm getting any distant sites. Sometimes I do pickup sites in Troop I and F's region's from here in St. Louis. I generally lock all out other than the few sites I can get every day with good signals though. A lot of frequencies are duplicated across the state as can be seen if you try and scan all sites.
I find MOSWIN much easier than Starcom but maybe because there is not a lot of MOSWIN use yet. I also lost reception here on almost all Starcom sites other than the Madison County Starcom site. I monitor that site a lot and am always amazed at how many talkgroups do appear on that site.
When you are searching the Weldong Spring and Imperial sites, keep your ears open for Sikeston. I see Sikeston in the clear talkgroups pop up on both those sites pretty often. Much like you are seeing Troop E comms appear on Weldon Spring or Imperial! It's hit and miss but some days I've been blessed and heard most of Sikeston's traffic for an entire day.
I suspect they will tighten that up at some point as that is what the travel talkgroups are really for. You don't really want an officer or dispatcher in Sikeston keying up repeaters across the entire state all day long. I'd think they will start denying access to certain radios or talkgroups so they can only affiliate with the sites they really need.
The other day there was a talkgroup out of Lincoln county that was also being heard all around the KC area. And it appeared to be tactical ops at that.
It's really neat hearing the far away talkgroups but that will bring the system to its knees if a lot of users can key up repeaters across the state. I guess that is all part of the testing phase but it is neat hearing!
  #708 (permalink)
Old 03-08-2013, 3:36 PM
AC0RV's Avatar
Send a message via Yahoo to AC0RV Send a message via Skype™ to AC0RV
Smile
I have recorded the following talk groups and Radio IDs with the PRO96Com program and need help iding them. So far I have not heard any radio traffic on them. Of the Lawrenceton Tower.
155 MO HP Troop I Disp 1
3511 Reg C IO 1 i49010
3515 Reg C IO Call i1004999
3515 Reg C IO Call i71029
3515 Reg C IO Call
3525 Reg E IO Call i49020
5001 Iron County ? i89
5101 Jefferson County
10313 MO HP IO Call i1009600
68 Poplar Bluff PD Dispatch ?
3525 Region E - Interop Calling Unit # i49012
3525 Region E - Interop Calling Unit # i49020
3525 Region E - Interop Calling Unit # i50353
7002 St Francois County ? (I have not heard anything yet about St Francois County coming online )
7001 St Francois County ? (I have not heard anything yet about St Francois County coming online )
7202 St Louis City i49004
54 i1000051
63 i1000051
69 i1000051
4902 i109002
69 i4559
6101 i49004
6102 i49008
5401 i49020
5001 i49033
5001 i89
This as of today at 1550 (3:50 PM)
Please help and a big thanks.
May the LORD watch over you and your Family.
David F AC0RV
Skywarn # M187201
Last edited by AC0RV; 03-08-2013 at 3:49 PM.. Reason: To better align the numbers.
  #709 (permalink)
Old 03-09-2013, 3:17 PM
Default Food for thought
For the Missouri State Fair the Highway Patrol for years used 154.665 which they refer to as Tac 4. Last year they used the SERT Tac Repeater on 154.695. I do not know if that repeater is still online considering 154.695 is now a CC on the Booneville MOSWIN site. They will use MOSWIN for the Fair eventually. Maybe not this year or next year, but the use of it for MO State Fair ops is inevitable. The nearest MOSWIN site to the fairgrounds would be a toss up between Pipertown and Cole Camp (DB says Odessa for some reason) Each are about 15-20 miles away as the crow fly. A majority of the operations are done on handhelds. Now will handhelds be able to affiliate with either of those sites from that great of distance? Also with the amount of traffic, considering other MSF Public Safety Ops will be using MOSWIN, will there be enough space on the sites? I am wondering if they will put up a temporary site during the fair. I definetley think something will have to be done.
Just another one of the Unknowns with this system that we have yet to see and we'll figure out some day!
SO EXCITING!
  #710 (permalink)
Old 03-09-2013, 4:28 PM
I would think they would use MOSWIN once they officially move over to it. They may use the old channels, but with their channels close to MOSWIN frequencies it may cause interference...time will tell!
CERT Member
NWS Storm Spotter
  #711 (permalink)
Old 03-10-2013, 11:11 AM
They have a 'site on wheels' that for a longer duration, significant event they could choose to bring in.
  #712 (permalink)
Old 03-10-2013, 11:50 AM
Have you actually seen this site on wheels?
I know many states do have them and I figured MO will get one or more but I've not seen any license data indicating they have a "site on wheels" yet.
  #713 (permalink)
Old 03-10-2013, 12:03 PM
Default Re: 2012-MOSWIN-Missouri Statewide Interop Network-Sites/Talkgroups
They do have a site on wheels which I have seen. They used the sow when demonstrating the system at regional informational meetings prior to the first round of MoSCAP grants.
Sent from my ADR6425LVW using Tapatalk 2
  #714 (permalink)
Old 03-10-2013, 12:43 PM
Any idea if it is setup on 700/800 or VHF?
I wonder if one of the sites listed in the database is really the SOW.
Or perhaps it's simply not licensed yet.
Is the 700 system in Jeff City a fixed system or are those possibly the frequencies used by the SOW?
I've been waiting for one to show up in the database but no SOW's yet.
Then it could be using state licenses which are very hard to search for plus those are generally low power (2 to 3 watts or so) but that would work for a temp SOW figuring the use of a SOW would likely be limited to a small area (like the state fair for example).
No need for a full power setup unless they move one in as a temporary replacement for say a site that lost its antenna structure to a tornado or something bad. In that case, I wonder if they would duplicate the downed sites frequencies in the SOW? I guess it depends on how the SOW would be licensed.
Now if they need it to cover a wide area, I'd think one will be licensed showing a decent power level.
I'd think they would use the 700 band figuring that band would be easy to find a set of frequencies they could set the SOW on that would not be used by others across the state.
So, did they build (or purchase) this thing new or just convert one of the existing mobile command trailers into a MOSWIN SOW?
We need to watch or search for a license for this thing so it can get added into the database.
  #715 (permalink)
Old 03-10-2013, 6:28 PM
I have seen it. It's self-contained on a trailer. Inclusive of equipment storage, power generation, and sectioned uni-pole tower (80' I think). It was new construction, not a retro-fit of any existing equipment. The Jefferson City 700/800 site is a permanent site.
  #716 (permalink)
Old 03-10-2013, 6:56 PM
Now that I think about it, I think there was a picture of one on one of the state websites related to MOSWIN. Don't recall if it was an actual pic of their unit but I think it had the state logos on it.
Thanks for the info on Jefferson City being a fixed site. That means there should be a license of some type for the SOW(s) out there or maybe something still in the application stage.
I wonder if they have plans for more than one for quicker deployment.
I think Illinois shows three for their Starcom system. I guess one for each of their three zones.
  #717 (permalink)
Old 03-13-2013, 1:43 PM
Miller county is doing some testing today(only Eldon Dispatch and unit 806 so far, not sure if PD or not). ID's used:
28901 - No voice, audio sounded faint and like the control channel
28902 - Same as above
28903 - Being called dispatch ch., unit 806 called it ch. 1
28906 - Called "all" channel
Also more Troop F water patrol radio testing on the lake of the ozarks(ID 20155).
  #718 (permalink)
Old 03-13-2013, 6:22 PM
KC0CSE's Avatar
Question
How do we know it was for the "Water Patrol"?....I thought Troop A was dispatch for them...thanks!!
  #719 (permalink)
Old 03-13-2013, 6:38 PM
Don't know for sure, I just know they were on the water testing handhelds and the radios in the boat and contacting "Jefferson City" and Jefferson City replied as Troop F. I have recordings i can share. I was assuming they would continue to be dispatched by Troop F as they were in the past. Is that supposed to change under the new system? I'm not an expert nor care to be, but was under the impression each Troop area handled their own "water patrol" officers.
  #720 (permalink)
Old 03-13-2013, 6:57 PM
KC0CSE's Avatar
Well as far as Warsaw Mo. area Benton County...I have had both Troop F and Troop A come across the scanner in the summer months...Troop A is my guess just for the Warsaw area troopers on the lake...and the other part of the lake would be Troop F's area...(around the dam )... thanks for the heads up!!! I want to follow this and see where it goes..was not sure they would go MOSWIN this soon!!
Tags
moswin
