| Missouri Radio Discussion Forum Forum for discussing Radio Information in the State of Missouri. |
03-08-2012, 1:50 AM
The Theodosia site in Ozark County has its application filed.
FCC Application Theodosia
03-12-2012, 5:49 PM
St Francois County
What's the timeframe look like for the St Francois County area for getting the system setup started for the area.
May the LORD watch over you and your Family.
David F AC0RV
Skywarn # M187201
03-13-2012, 4:05 PM
MOSWIN is still in phase 1 for troop E. (And has been since mid to late 2011) The pilot phase took nearly all of 2011. There is still no HP usage at all on MOSWIN at this time. (except maybe testing).
Phase II covers troop D in the Springfield area next. Then comes Phase III and the Troop C and surrounding St. Louis areas.
I would figure things will speed up once frequency pairs and licenses are worked out. However, if I had to guess based on the speed of things today, I would not count on having MOSWIN in St Francois County this year.
03-14-2012, 7:56 PM
I noticed the Nwin thread (for the Nebraska network) began around the first of 2009 and still appears to be incomplete.
I also noticed some Nebraska Highway Patrol entries in the low band logs.....so the low band is still alive there.
Given the amount of time it takes to put these things on the air makes me wonder what kind of maintenance nightmare they might become down the road.
In the meantime, I invested in some aluminum today......gonna beef up my low band antenna setup and enjoy it while it's still around.
04-06-2012, 1:56 AM
Is anyone hearing any testing upstate? I've not heard any in the last few weeks. I do hear Sikeston PD on the Bloomfield tower now.
BCD996XT
Proscan, Freescan
04-06-2012, 9:25 AM
Upstate is last to go online. Currently sites are going on the air and are being tested in south central MO in Troop G. MOSWIN now goes as far west as the Troop D-G line.
04-06-2012, 2:12 PM
Ok. Thanks imperial.
BCD996XT
Proscan, Freescan
04-12-2012, 8:59 PM
Does anyone know what the latest application letter means? Will they start expanding MOSWIN now?!
CERT Member
NWS Storm Spotter
Scanners Include: Uniden BCD996T & Uniden BCD396XT
04-12-2012, 10:11 PM
I wonder where the freqs will be used on the today's update.
BCD996XT
Proscan, Freescan
04-17-2012, 7:50 PM
I noticed in the database they updated a lot of the site info, where is this coming from? I don't see the site that would be closest to me, and know there are a few others missing. Can anyone tell me how this is happening??
CERT Member
NWS Storm Spotter
04-17-2012, 7:55 PM
The updates come from the FCC site.
BCD996XT
Proscan, Freescan
04-17-2012, 8:00 PM
I usually check the FCC site weekly on any new licences specifically for this, and none of these sites have shown up?!
CERT Member
NWS Storm Spotter
04-17-2012, 8:11 PM
They will not show up as licenses as they are usually just applications for licenses.
There is a way to search the FCC site for new applications and that is where most of that data is coming from.
04-17-2012, 8:26 PM
That is what I usually do, I didn't see the Branson site...there are a few sites that are on there, but not all.
CERT Member
NWS Storm Spotter
04-17-2012, 8:45 PM
I wonder if someone involved in the site construction may be supplying some of this info as I saw (or should I say I didn't see) what you saw also where some of the info is not showing up at the FCC site.
It was neat seeing all the new sites listed today though. Some are getting close to my area so I'm getting all excited!
04-17-2012, 8:46 PM
I have one or two close, so I'll keep an ear out, but it's exciting me too!!
CERT Member
NWS Storm Spotter
04-17-2012, 9:40 PM
That was a neat report listed by city like it is.
It also amazes me the wide range of frequencies they are gathering up to make this all work. Pretty much from the bottom to the top of the standard VHF High band range is being used somewhere in the state.
And then they are asking for exceptions to allow them use of frequencies that are unused in the marine and radiotelephone or paging allocations as well as some of the stuff that is normally reserved for federal use only.
It kinda makes you wonder just how many vacant frequency slots there really are in the VHF band from say 150 to 174 when you get out in the more rural areas.
I think I'll miss the old days where you could get an idea of the user just by the assigned frequency going back to when they adhered to the old type of service allocations. Now you can find local government or fire department use about anywhere in the VHF high band.
Has any law enforcement been allowed to use unused channels in the rail allocation or is that one still protected for just rail use?
04-19-2012, 1:51 PM
Originally Posted by talkpair
I have a couple questions about the system itself.
1) Lets suppose an agency, such as Ripley county is thinking about joining MOSWIN, which could involve more than one site depending where a particular user is located. Is this agency required to offer-up a frequency (or pair) per tower for the area they want coverage?
2) In this example, let's assume Ripley county and the US Forest service are on MOSWIN, along with the Highway patrol, and maybe a city or two.......Are the frequencies then pooled to act like a single agency trunked system for the use of any agency requiring them on that tower, or are the frequencies chosen by the system determined by the agency requesting air-use, and subsequently assigned a frequency that agency contributed ?
1. An agency that goes on MOSWIN - will be configured as to the best coverage, ie, in Howell county in the normal course of operation they could be using the Caulfield Tower, the Willow Springs tower, the Alton tower - of course transparent to the end user.
Let me be clear - it is NOT required that an agency turn in any frequencies in order to go "all in" onto the state system. It is certainly possible that an agency may not even have frequencies to turn in that can be used.
2. See above. No restrictions as to only their frequency or tower.
As always, Steve Devine is the "man with the plan" but this is what I have been advised, and what we have been passing on to our agencies. It is the only way the plan makes sense anyways.
04-20-2012, 12:24 AM
West Plains site in Howell County is licensed.
West Plains WQPE354
