Go Back   The RadioReference.com Forums > U.S. Regional Radio Discussion Forums > Missouri Radio Discussion Forum
Missouri Radio Discussion Forum Forum for discussing Radio Information in the State of Missouri.
Old 11-17-2012, 12:13 AM
zzdiesel's Avatar
Question MOSWIN Slowdown
Anyone noticing that the state system use is slowing down? I haven't heard Poplar Bluff HP or their mobiles in a few days.
GRE PSR-600, BCD996XT - Mobile
Win500, Freescan, ID Tracker III
Old 11-17-2012, 6:51 AM
KC0CSE's Avatar
Cool no nothing!!
No testing........ no...... nothing on the scanner....I have the PRO 197 that is only on this system...dead all day..troop A ....and St.Joe.....the tech's..might on vacation??
Old 11-17-2012, 11:56 AM
Same here, nothing from Jackson County or Clay County site's.
Old 11-17-2012, 2:25 PM
scannerowner's Avatar
I believe they are done testing up here in Troop H, but the Winston Site may need to be improved some, not sure if that's the case or not?!
CERT Member
NWS Storm Spotter
Scanners Include: Uniden BCD996T & Uniden BCD396XT
Old 11-17-2012, 2:28 PM
zzdiesel's Avatar
Thanks. I was worried my PSR-800 and my Pro-197 were screwing up.
Old 11-17-2012, 2:36 PM
KC0CSE's Avatar
Question compare
how does your PSR-800 compare to your PRO 197 with the P25 system? does the 800 decode better?...thanks Mike kcnorth
Old 11-17-2012, 6:43 PM
What type of antenna's is everyone using? I'm thinking about getting a Watson Super Gainer Antenna, I'm hoping that works. The site that is 10 miles away from me is barely audible...
CERT Member
NWS Storm Spotter
Old 11-17-2012, 6:50 PM
KC0CSE's Avatar
800meg RS sometimes a paper clip.... 106th & north oak
PRO106
PRO 197
Old 11-17-2012, 6:53 PM
zzdiesel's Avatar
I can't really a whole difference in them. I usually have them on the same antenna.
Old 11-17-2012, 6:57 PM
zzdiesel's Avatar
I use an ST2 which is about 15 ft or so.
Old 11-17-2012, 7:03 PM
PRO106
PRO 197
How well does that work on MOSWIN Sites farther away from you?
CERT Member
NWS Storm Spotter
Old 11-17-2012, 7:17 PM
KC0CSE's Avatar
i can pick up troop A with a clip........800meg stjoe troop
Old 11-17-2012, 7:22 PM
That's good, I'm sure anything is better than a stock. My problem is a lot of paging towers near me, which doesn't help. I'm sure if I get something better, my reception will be better for MOSWIN.
CERT Member
NWS Storm Spotter
Old 11-17-2012, 8:11 PM
I must use PAR filters for the two VHF paging ranges (152 and 158 MHz) otherwise all my GRE radios desense and receive nothing.
The filters work wonders. The only problem I think I'll see is that some of the frequencies used for MOSWIN sites fall within the paging bands that the notch filters notch.
So I'll be screwed for distant site reception but should be ok for any near sites I think. The PAR filters reduce the signal from the paging transmitters by about -30dB or so but you can still hear strong signals within the paging ranges. They just remove enough of the paging transmitters signal to allow the AGC circuit in the GRE's front end to work and cope with the paging crud.
Many GRE owners would also benefit from an FM Broadcast band filter as they also cause the GRE's front ends to desense.
Paging band notch filters would help many in urban areas with local VHF paging towers and FM Broadcast band filters could help those in rural and urban ares if you have any FM transmitters within a few miles or so of your location.
Old 11-17-2012, 8:22 PM
I'm not sure exactly if it's hurting me too bad, but I don't know why the transmitter only 10 miles away is barely getting anything. I know people in the Ozarks probably have worse reception if this is the case. If I go a few miles East then the reception gets better. If I go West and South then I get nothing. I'm not sure if paging towers are interfering too much or not?! Has anyone heard any new TGs from the counties that may have gone live this week?
CERT Member
NWS Storm Spotter
Old 11-17-2012, 9:28 PM
EDIT: I now realize you are using Unidens so most of the below should not apply. I missed the info in your signature tag!
The info below would apply if you are using GRE so I'll leave it as it may help some of the other users with GRE's that may have problems.
It's actually very possible that a nearby paging transmitter is shutting down the front end.
Try testing with the NOAA WX channels and see if you can receive distant WX stations. If so, you are probably ok.
My GRE's are almost useless for anything VHF due to all the paging sites near me. I'm situated between several hospitals and each one has a paging transmitter atop their roofs.
My PSR 600 will usually show full bars on many VHF frequencies even though there is no signal on the frequency. That can also be a sign that you are experiencing overload. Paging systems do go off the air for a minute or so though so you should see a signal strength increase on the control channel I would think when the paging site goes quiet. Of course you could have multiple paging sites on different frequencies. You would need to monitor them all at the same time to try and catch a time period where they are all off the air.
My problem is from three frequencies, two in the 152 band and one in the 158 band.
The one in the 158 band is seldom used so I don't usually need that filter inline.
Your problem could also be FM broadcast stations if your vhf signal levels are always low on that tower. FM stations are almost always broadcasting so you can't really test easily. You could build a stub filter cut for 98 MHz and see if your MOSWIN signal improves. Coax stub filters are pretty wide banded though so if not cut right, you could be attenuating the desired signal. An easier way is to purchase the FM Trap from radioshack along with any needed adapters and put that inline in your coax.
You may be very surprised at how much your VHF reception improves.
Many here do that and it does work well very often.
Of course radioshack is very good about taking things back so you can always return everything if it does not help any. If it does help, I'd still take it all back and then invest in a high quality FM Trap such as the one PAR Electronics sells. They are costlier but are worth every penny. There are other makers as well but I'm not familiar with any others.
Plus a high quality trap will have the proper connectors on it already so you don't add any extra loss by using adapters like will happen if you try the FM Trap from RS.
I also have overload on my GRE's and Unidens from paging sites in the 929 and 931 MHz bands. Dale at PAR built me a custom notch filter that notches from 929 to 932 MHz. It works very well when I monitor 900 MHz systems.
The other option you may have is borrow a Uniden 396 or 996 if you know someone that has one. Then put the Winston site in that and see how it comes in. I find the Unidens are not affected by overload or desense from paging or FM Broadcast like the GRE's are. The GRE's are more sensitive though which can be a good thing or a bad thing. Bad if you already have overload or desense!
Do you have an outdoor antenna?
That may be all you need if not but it will also pull in more paging and FM broadcast crud along with a stronger intended signal.
An outdoor antenna also gets you away from devices inside your home that may be getting into your radios. Use good quality coax like LMR-400 even if the run is short.
At a minimum, I'd try the FM Trap from radioshack as you can get that locally and it's easy to stick inline as long as you get the needed adapters. The RS trap has female F fittings so you need to convert from female F to a male and a female BNC. Take it all back if it does not help at all!
EDIT: I was thinking you had GRE radios! Wrong person.
It seems you have Uniden's so pretty much forget all the above. The Uniden's are not usually affected by desense issues like the GRE's. Unless you live with a paging site in your back yard, the paging sites should not be the cause of the problem.
I think you did tell me the WInston site is an omni pattern also so I'd think you should get decent reception being only 10 miles out.
Does the CC's site or tower ID match what is listed in the database for the Winston site?
You can see that info if you use Unitrunker or Pro96com.
I think you can also do a manual add of the CC frequency and the Uniden's will display some of the info including the site ID.
I only ask that just in case the CC you are receiving is not really the Winston site.
Old 11-17-2012, 9:48 PM
I verified the info because it shows the same system ID and site ID as the Winston Site. A medical helicopter on 160.185 is about 40 miles to the West of me and I get it at 2 bars. I guess our area MSHP Radio Tech noticed his APX Radio with a lower RSSI than usual. I'm wondering if they'll fix it, or if it's some other problem. I get a little bit of interference, but it doesn't affect it all that bad.
CERT Member
NWS Storm Spotter
Old 11-18-2012, 12:06 AM
Well at least you have a live site near you. I still only get a site two counties away! None of the sites near here have went on the air yet.
We do have the 700 and 800 sites used by St. Louis City and St. Charles county that are slated to be used by MOSWIN but I've not seen any new talkgroups show up on either of them yet.
The STL City site is so darn busy with city traffic that it may be a chore watching for new TG's unless I log the site traffic. I do that once in a while using ProScan but have not found anything new yet.
I did hear a Troop E or F mobile unit calling the other day. I heard him on the New Hope site which is two counties north of me. He was at Lambert Airport here in St. Louis.
Otherwise I've not heard any testing or anything for some time now.
I keep waiting for the Weldon Spring site to come online. That is where Troop C headquarters is located but so far, nothing. At least nothing on the frequencies listed for that site in the database. I know they applied for some waivers to allow them to use some unused paging frequencies in the Troop C areas around here but I don't know if the frequencies they are wanting are listed in the DB yet. Those could very well be used at Weldon Spring in place of what the DB says now.
I also don't see a site listed for Franklin County. Maybe that county will be covered well enough from the other planned sites around that county. Or that is the county they are asking for the paging band waivers for. Time shall tell I guess!
Old 11-19-2012, 7:58 PM
zzdiesel's Avatar
It just like they have turned it off here for now.
Old 11-20-2012, 3:30 PM
zzdiesel's Avatar
I just sat down here at my desk and it seems they have turned the switch back on today.
