Go Back   The RadioReference.com Forums > U.S. Regional Radio Discussion Forums > Missouri Radio Discussion Forum
Missouri Radio Discussion Forum - Forum for discussing Radio Information in the State of Missouri.
Old 12-03-2012, 2:25 PM
Default ARCH Air Medical
Is the dispatch frequency for ARCH Air Comm STL base 461.52500? What other frequencies does ARCH use and how do they work? Does the dispatch frequency dispatch ARCH like dispatchers do for public safety, or is it just helicopter operations? Thanks!
Old 06-11-2013, 1:20 PM
461.525 is the High Ridge tower. Others in MO: Cape Girardeau 462.95, Columbia 154.965, Joplin 460.375, Walker/Nevada 158.040, Sedalia 152.33, St. Joe 160.185, STL Aviation 123.025. All used for helicopter dispatch & operations. Controlled out of AirCom in Omaha NE.
AirCom - Only Center Of Its Size And Scope In The Nation
Old 06-11-2013, 9:30 PM
Default ARCH air
Also try 462.075 for the Litchfield tower. They use it a lot for comms near Springfield. The basic method is to call the base for the specific copter by phone and as they go airborne the call information is given to them. Also for IL, ARCH sometimes uses IREACH 155.055 for ground contact.
Old 06-12-2013, 1:53 AM
Starcom21's Avatar
IL / MO Database Admin
Default ARCH info / Wiki page
Don't forget to look at the information contained in the RR Wiki. Some of it is old and needs some updating.
http://wiki.radioreference.com/index...pter_(US-MO/IL)
Also, if you are on the fringe area of St Louis or Litchfield actual repeaters, you can also listen to the input frequency to hear the helo often much farther out transmitting, than the repeater output (467.xxx opposed to 462.xxx).
If you are interested in such things, also look at AirEvac on the statewide EMS pages (IL/MO) and on the wiki page links from each page.
http://wiki.radioreference.com/index...Area_Wide)_(MO)
http://wiki.radioreference.com/index...ers_/_IDPH_(IL)
http://wiki.radioreference.com/index...(US_Nationwide)
Terry Weatherford, WX9SAR
IL / MO / MI - RR Database Admin
Old 08-11-2017, 7:19 PM
shortbus91's Avatar
Default links above do not work
the links do not work...
josh
Tags
aircom, arch, ems, helicopter, medevac
