If you look at the frequency line, you'll see a column under word Type, B=Base, M=Mobile, so you can program accordingly. The Point to Point, 155.370, would be a channel all law agencies use to talk between dispatch centers, no standard dispatch to officer here, but you will pick up a lot of MVA, Bank robberies etc. on this channel. Best to program them in and listen, it will make more sense, and you can decide which ones are of no use to you.
