Greene County Missouri
rdnck41
As of October 2013 Police and Fire in Greene county are now dispatched through Greene County dispatch. The Fire dispatch frequencies have stayed the same with the exception of the Springfield Ops channels are now being used for all of Greene county instead of 9 channels there are 12. I cannot find the Talk group IDs for Ops 10 thru 12. I also cannot find the new Greene County PD dispatch talk group ID either. If anybody know what they are or can help I would appreciate it.
Respectfully,
Daniel
pinballwiz86
Missouri
I have looked at the website but I do not know my way around it to find what I am looking for. Any advise?
Sure, I'll try to help.
Go here first, as you alredy know. Make sure everything is in the scanner correctly.
Greene County, Missouri (MO) Scanner Frequencies and Radio Frequency Reference
Then here for MOSWIN:
Missouri Statewide Wireless Interoperable Network (MOSWIN) Trunking System, Statewide, Missouri - Scanner Frequencies
Search for the word "greene".
rdnck41
Ok so after some further research I found that the local police departments are being dispatched on a talkgroup called GCWIDE. I have done lots of searching online and I have not found the scanner talkgroup for GCWIDE. This specific talkgroup ghost has only been in use for about a month by the local municipalities. If anybody knows what it is our knows where to find it. I will be eternally greatfull.
pinballwiz86
Missouri
Well, how did you find out about the talk group GCWIDE?
W8RMH
Feed Provider Since 2012
Grove City, OH (A Bearcat not a Buckeye)
Scan in open or search mode to locate new TGs. Since it is all LE it should be busy.
PVPD730
Talkgroup 16656 is what you're after. That's what the municipal departments were using the last time I was down there (which was about 6 months ago).
