Go Back   The RadioReference.com Forums > U.S. Regional Radio Discussion Forums > Missouri Radio Discussion Forum
Missouri Radio Discussion Forum Forum for discussing Radio Information in the State of Missouri.
Old 11-11-2013, 3:03 PM
Starcom21's Avatar
IL/MO/MI Database Admin
Default 2013/14 - MOSWIN-Missouri Statewide Interop Network-Sites/Talkgroups
Please post any related questions and information here.
Please be sure to see the 2012 and 2011 threads for additional information.
Terry Weatherford, WX9SAR
IL / MO / MI - RR Database Admin
Old 11-12-2013, 10:51 AM
AC0RV's Avatar
Default FOIA Request Follow up
Ok, Just to let all you. the MOSWIN System Admin denied my request do to it being a senstive name according to the Missouri Statutes. I am I do not have the exact stautes to site.
But Hey at least I tried right,.
May the LORD watch over you and your Family.
David F AC0RV
Skywarn # M187201
Old 11-13-2013, 8:08 AM
Default Testing
TG 3511 heard testing in the StL area about 5 days ago. Sorry for the late post. Believe this is Region C interop. Will this TG be used the same as Pt to Pt? 155.370?
Old 11-14-2013, 7:47 AM
AB5ID's Avatar
Question Help for a last minute trip
I am planning a trip from Kansas City to Branson. Is there a map of towers with the control channels for MOSWIN?
Should I load the tower control channels and run ID search or should I load the tower control channels with talkgroups and run ID scan for the best scanning?
Many Thanks,
Steve
Old 11-14-2013, 9:56 AM
Here is a good map of the sites:
Moswin Sites
You can click on the push-pins to get the site names.
Unfortunately, the frequencies listed on the pop-up are the mobile inputs and not the control channels.
Jot down the site names along your route, then look up the control channels on the Moswin database page.
Old 11-14-2013, 12:25 PM
AB5ID's Avatar
Thanks! For the route Iím taking, I plan to load:
Massman 170.51250c
Dayton/Aaron 154.90500c
Deepwater 169.77500c
Wheatland / Hermitage 161.92500c
Fair Grove 161.88750c
Hurley 169.88750c
Branson 161.87500c
Would leaving the scanner on ID search be fine or would there be an advantage to loading talk groups?
Hopefully I can get some towers on an external 2 meter 1/4 antenna.
Old 11-14-2013, 1:40 PM
Myself......I think I would leave it on search.
This sounds like the equivalent to the GRE's Wildcard talk group.
Even with my home setup, I listen to everything on the system and only create a talk group when I want to lock it out.
Instead of creating a white-list, I created a black-list.
Because the number of agencies on Moswin is low, scanning this way works great. In addition, you may discover some talk groups along the way that aren't listed in the database.
The disadvantage to this style of scanning is that the talk group numbers won't be tagged with a name when they are active. I don't see this being a big problem because the majority of users are very good about speaking their agency/department name as well as the talk group name.
Old 11-15-2013, 8:28 AM
I have done some traveling myself across the state and I have used the SEARCH mode to pick up any and all currently used TG's. You can keep a pad of paper handy to write them down as you hear them. Safely of course. Please do it safely. When you reach your destination you can ID them from RR.
I have noticed some of the site locations can be a bit tricky to find. Some towns are so small you can not find them on a state map or even Google maps. And one or two sites I was looking for some time ago were listed in the wrong county. Just a heads up.
And if you can, use an outside antenna. On my 396xt the difference in fringe areas is very apparent. Much better reception with the outside antenna.
Have a safe trip.
Old 11-15-2013, 8:35 AM
You may also want to try adding a few fringe area sites along the way. Some sites are more powerful and may be heard better then a closer one. Just take an MO map and track your route and add as many as you can. Just a thought.
Old 11-20-2013, 5:27 PM
Starcom21's Avatar
Default !!!!!! MOSWIN Mapbook !!!!!
Currently, 638 agencies in Missouri are using MOSWIN. One hundred forty two of those agencies are level one users.
LOTS of information here...
http://dps.mo.gov/dir/programs/inter...in-mapbook.pdf
IF anyone has time to review this, please do and submit any related information to the database for me to update.
STARCOM21 Statewide Illinois P25 Trunking System, Statewide, Illinois - Scanner Frequencies
Thanks!
Terry
Old 11-20-2013, 5:49 PM
Someone was using TG 24604 Earlier this afternoon..
I have a hard time picking up MOSWIN (Bates County Tower) inside the House...but going to setup my scanner and see if I can figure out who is using it.
VFB Stuttgart Deutscher Meister 2006/2007
RS Pro 92(b), 95, 96
Kenwood TK-280 (146-174MHz)
Old 11-20-2013, 10:21 PM
Thumbs up !!!MOSWIN Map!!!
Wow! How coooooool! I may just have to go "old school" and make sure I have full cartridges on my printer and make my own copy. Thanks Terry for a great job.
Old 11-24-2013, 6:31 PM
Having trouble isolating talk group for MSHP air to car in MOSWYN. Am I forgetting something ?
Old 12-09-2013, 4:02 PM
Unhappy No messages
It has been almost a month since someone posted a message here for MOSWIN. Is there really that little going on around the state? I will be the first to admit that in the StL area it is pretty boring listening to TG's 5 and 7 nearly 98% of the time. It is great listening, but getting boring. As a statewide system I thought we would hear more. Anyone know of any agencies going online with MOSWIN soon? Or any news in the works. With the bad weather we have had the last week or so I was thinking it would be nice to hear MODOT snowplows on MOSWIN at some time soon. Guess agencies like that are not moving over.
Old 12-09-2013, 4:29 PM
nick1427d's Avatar
You're probably not going to get much new info until new users go online with it. Also they typically won't do a lot of testing in the winter.
Nick
Old 12-09-2013, 10:32 PM
iamhere300's Avatar
Although MODOT and Conservation have MOSWIN capability for a lot of their vehicles, they are retaining their legacy systems for now until funding and operational issues are worked out. The conservation agents should all have their radios by now.
Remember, MODOT and Conservation are their own entities with only minimal intervention by the state.
Old 12-10-2013, 2:09 AM
dispatch235's Avatar
Default MOSWIN Usage
In south central part of the state there is quite a bit of usage...I live about 20 miles west of Rolla and have Troops D, F, and I are mostly all on MOSWIN, Rolla PD, Phelps Co. Sheriff, Maries Co. Sheriff, Laclede Co Sheriff and Lebanon PD seem to be full time... Rolla City Fire is listed on MOSWIN website as full time user but haven't yet found what their talkgroup id is... not listed on RR and so far haven't found it with the "wildcard" setting on my scanners either.
Troop I dispatch talks to conservation agents all the time also... so apparently some agents have MOSWIN along with their legacy radio system.
During the floods in Pulaski County back in august MOSWIN was really busy with all the troopers and water patrol coming in to assist... it was amazing to be able to hear all the traffic from both sides (dispatch and in the field) when most of the time all you could hear on low band is the dispatch (unless the officers were close by, even with outdoor antennas)
Old 12-10-2013, 7:44 AM
Update on my MOSWIN experiences.
1. I have upgraded, yes, upgraded to a Uniden 996XT. In my opinion much better to use on MOSWIN than the GRE or RS P25 receivers.
2. I have found that the Pipertown site is weak. I now stay on Aullville full time and all of my county TG's have automatic access to the site regardless of affiliation so that is a HUGE ++++++!
3. I have heard conversations about a Troop A "Travel" Talkgroup. I'm curious to know if anyone else has heard anything like that in your Troops that you folks monitor.
4. Still no update on the 700Mhz site in Sedalia. Seems to be a funding issue as the site and full migration would be extremely expensive. A site has been unanimously chosen just waiting on the funding if it ever comes!
5. Any word on a X2 TDMA upgrade anytime soon?
6. The system map is awesome. To whomever created that, HUGE KUDOS TO YOU!
Old 12-10-2013, 9:22 PM
The St Louis area basically only has TG's 5 & 7 with occasional c to c traffic. Sometimes there is skip from Sikeston PD (or someone close by using that TG). Sometimes testing goes on but not much.
I agree the central part of the state is busier. My dad has a place near Bennett Spring (Laclede County) and as you stated pretty busy out that way.
Thanks for your report.
Old 12-13-2013, 10:04 PM
Just for everyones info Talk Group 7 is MSHP (Jefferson County) all other counties in Troop C use TG 5
