Missouri Radio Discussion Forum -
Forum for discussing Radio Information in the State of Missouri.
03-31-2014, 3:18 AM
There's encryption for dispatch calls In Jackson county? Boo..hiss.
Uniden 536HP/436HP / Uniden 396XT / Uniden 125AT / Uniden 15X / GRE 310 / GRE 120 // Ham Radio: Icom 718 / Yaesu 2900 / Yaesu 7900 / Yaesu FTM-400XDR / Yaesu FT-270 / Baofeng UV-5R+ / Icom ID-51A+
03-31-2014, 9:13 PM
Member - RR DB AdminMo/Ks
Biggest issue is the ADP encryption being used by all the agencies currently using full time encryption.
ADP is not "inter-operable" with open P-25 encryption used by other manufacturers radios.
All those that are using full time ADP encryption are essentially orphaned to those that are using open P-25 encryption.
Plus key management can be a hassle as well.
ADP encryption is a Motorola proprietary item.
All those agencies that chose the ADP encryption ignored the requirements that its radios fully interact with other brands.
Might be worth an investigation if federal $$ were used to buy them as they were required to fully interact with other brands in order to level the playing field.
JMHO....
04-01-2014, 1:31 AM
Originally Posted by scannerowner
I think it's funny they want to be "interoperable", but Jackson County and IPD are encryped on dispatch channels, which means more money to be spent on encryption keys. I really forsee them reversing the encryption if the agencies can't hear what's going on in a neighboring community due to encryption.
You could be right about them reversing the encryption so that other agencies can monitor, but I wouldn't get my hopes up. I do know that most of the municipal police departments (Lotawana, Grain Valley, Oak Grove, Greenwood) can't monitor the county guys right now because their radios aren't loaded with the appropriate software and/or keys. Frustrates the hell out of them!
The next thing I'd do is keep all dispatch channels in the clear so you're not wasting money on encryption keys, but then to keep tactical stuff 100% encrypted. If there's a bad enough circumstance, switch to another channel. There should be tactical channels that can be used within multiple jurisdictions and kept encrypted for safety reasons. Dispatch channels remain in the clear so other agencies can monitor without worrying about who does what. I think MOSWIN is doing great with interoperabilty, but there are still gaps that need covered.
Johnson County, KS law enforcement agencies got this one right. All of the police departments over there keep their dispatch talkgroups open. I don't think this was done so much for the public benefit, but enables surrounding agencies to monitor without having to worry about jacking around with the swapping of encryption keys. All of the "secondary" and tac stuff is locked down as it should be. It doesn't take but 2 seconds to switch over to a secure channel when one is needed.
04-01-2014, 1:33 AM
JMHO....
Excellent point!
04-01-2014, 6:56 AM
It'll just take one time of no shared communication, or someone saying something and they'll change their minds!! PVPD730, we'll just wait and see what happens! If dispatch remains in the clear it makes everyone's life a little easier...
CERT Member
Scanners: Uniden BCD996T & Uniden BCD396XT
Radios: Baofeng UV5R, Yaesu FT2DR, Anytone 5888UV
04-25-2014, 12:16 PM
Might as well add Cass County to the list of ADP users:
http://www.casscountyesb.com/CCESB%2...1-22-2014.docx
Under section 4: " All PSAP related police agencies have encrypted their talk groups. There is a minimal cost to upgrade the dispatch consoles, back up radios, and suitcase repeaters."
I've also heard that KCKPD will do the same. Moto $alesmen must really be pushing this...
04-25-2014, 7:09 PM
Originally Posted by talkpair
Yes, very interesting indeed. If the feds find out these agencies are using non P25 compliant encryption gear (and they care enough to actually enforce it), that could definitely be a problem. Bet that's something Motorola conveniently "forgot" to tell people when those contracts were signed.
05-02-2014, 10:51 AM
Interoperability was put in place for mass casualty/emergency management scenarios. There are probably over one hundred TGs set aside in MARRS alone, just for this purpose. From PD/Fire/EMS all the way to Public Works divisions, each facet has multiple TGs available to which they would be assigned during any such incident. The TGs are layered by geographics and service, with numerous TGs under each section.
Regional Comm TGs will be utilized (theoretically) from cross-border pursuits and mutual aid fire responses all the way to 9/11 and Hurricane Katrina type events.
Using proprietary encryption which limits Agency X from being able to switch over and tell Agency Y directly that a pursuit is headed their way on their primary TG is more time consuming and frustrating for the end-user because of the delayed relay of information, but interoperability wasn't designed around that type of immediate cross talk. It is in place to establish a common platform for multi-agency responses to large scale and disaster type incidents. The availability of those Regional Common TGs ensures that interoperability is in place, just as it is required. Nobody operates encrypted on the Regional TGs.
I'm not here to discuss whether or not agencies using ADP are following Federal guidelines to receive grant money. I'm simply pointing out the fact that every radio on MARRS will cross-talk on the appropriate TGs when needed, and that's all that matters when SHTF.
05-13-2014, 9:40 PM
Cass County Radio IDs are now showing up on the Cass County part of the MARRS system
cc is 851.1000
Talkgroups IDs logged so far:
34559 - Encrypted radio traffic heard - this one is fairly active not sure of the agency.
34615 - Encrypted radio traffic heard
34623 - South Metro Fire Dispatch (Added to RR DB today)
34634 - Encrypted radio traffic heard
05-13-2014, 10:18 PM
cc is 851.1000
Some how I can decode Cass Co with Pro96com up here by Liberty, talkgroups are 34550 - 34699, almost all of them 100% ENC, some fire and city works are in the clear.
05-13-2014, 10:22 PM
What ones have your heard?
The only one I have heard in the clear is South Metro Fire.
and how do you know the range of Ids?
Care to share?
hh
05-14-2014, 12:17 PM
Cass County
Here are 3 talk groups I have heard.
34564- Belton Fire
34623- South Metro Fire (Raymore)
34672- Emergency Managment/Public works Belton I think or Raymore
05-14-2014, 12:48 PM
Care to share?
hh
I will do my best here,
All Id's 34550-34699 are new, they all are only allowed to affiliate with Cass county towers and denied affiliation with KC or Jackson towers, All the new radio Id's go along with the new talkgroups.
MARRS has been good keeping radio id's in blocks for each agency, same thing with talkgroups.
Right now I have 1,020 talkgroups and over 14,000 radio Id's in Proc96com, I have most of the Id blocks identified to at least the agency and many of them are unit specific, it is easy to see the patterns and or groups with this many Id's
I will add the clear talkgroups here in a few (crazy children premiting)
Edit
Here is some of the active talkgroups today that are in the clear
34564
34573
34577
34683
34594
34596
34615
34618
34619
34620
34621
34623
34649
34665
34672
34684
05-21-2014, 10:42 PM
Is Belton PD or Belton Fire encrypted?
Sent from my HTC One X using Tapatalk
05-21-2014, 11:47 PM
Belton PD and all other Cass County LE agencies are encrypted. Belton Fire is in the clear. From what I understand, everyone cutover to the new system today.
05-22-2014, 11:00 AM
I'm at MARC downtown for a training class (MARC is who controls all the PSAPS and radios in the region) and I'm hearing a rep talking about a serious lack of coverage with their new radio system between Harrisonville and Belton. Doesn't sound like a good thing to have spent 14 million dollars on new radios to not have them work.
05-22-2014, 6:57 PM
Not to get off topic, but i too have heard what sounded like Belton FD; from where i was It dd not rx very well, then heading south from Springfield they were asking area units to switch to low band to check ? tower (i forgot which one ) several units were called and switch over - could not hear anything on the 42 megs; did not have a good low band antenna for it.....
What radios do they use ? not many manufactures of low band equipment out there
05-27-2014, 9:56 PM
There are 2 KC MARRS threads
Not sure where to post this?
I'm in Olathe off of 159th St.,
Picking up Tower 303, not listed in DB.
It's not sending a CWID
Well just as I typed this..Broadcasting Changeme CWID (LOL)
Happy Hunting guys, lol.
Code:
System ID : 2B0
System Name : Kansas City Metro - Metropolitan Area Regional Radio System (MARRS)
WACN : BEE00
Tower Number (Decimal): 3-3
Tower Number (Hex) : T0303
Tower Description :
Control Capabilities : Data,Voice,Registration
Call Sign(s) : CHANGEME
Timestamp : Tue May 27 21:55:32 2014
-Tables
#Format: Table ID,Base Freq,Spacing,Input Offset,Assumed/Confirmed,BandWidth,Slots
00,851.00625,0.00625,-45.00000,"Confirmed",0.00625,1
01,762.00625,0.00625,30.00000,"Confirmed",0.00625,1
-Frequencies
#Format: Channel,Usage,Frequency(/Slot),Input Channel,Input Frequency(/Slot),Input Explicit(1/0),Hit Count
"00-0705","c",855.41250,"00-0705",810.41250,0,0
"00-0861","a",856.38750,"00-0861",811.38750,0,0
"00-1021","a",857.38750,"00-1021",812.38750,0,0
"00-1181","a",858.38750,"00-1181",813.38750,0,0
"00-1333","i",859.33750,"00-1333",814.33750,0,5
VFB Stuttgart Deutscher Meister 2006/2007
Uniden BCD436HP
RS Pro 92(b), 95, 96
05-27-2014, 10:10 PM
Code:
System ID : 2B0
WACN : BEE00
Tower Description :
-Tables
-Frequencies
WQTA969 (JOHNSON, COUNTY OF) FCC Callsign Details
Looks like Olathe has there own tower or something.
Thread Tools |
Display Modes |
