Go Back   The RadioReference.com Forums > U.S. Regional Radio Discussion Forums > Missouri Radio Discussion Forum
Missouri Radio Discussion Forum - Forum for discussing Radio Information in the State of Missouri.
Old 04-09-2014, 10:02 PM
pinballwiz86's Avatar
Default Mystery 800 MHz Trunked System
Hey gang,
I had a nice afternoon on the deck drinking coffee and scanning.
I figured out you can find control channels on the 396XT by playing around with the settings.
I set a custom search on the 800 MHz band just to see what I'd find.
I got a hit on 855.7875 MHz and the display read :
What am I seeing here? There isn't a county named Kitsap in Missouri..I'm located in Pulaski County and it's a very strong signal on the rubber duck.
Uniden 536HP/436HP / Uniden 396XT / Uniden 125AT / Uniden 15X / GRE 310 / GRE 120 // Ham Radio: Icom 718 / Yaesu 2900 / Yaesu 7900 / Yaesu FTM-400XDR / Yaesu FT-270 / Baofeng UV-5R+ / Icom ID-51A+
Old 04-09-2014, 10:59 PM
Ameren site in Phelps Co?
AmerenMissouri (P25) Trunking System, St Louis Metro Area/E MO, Multi-State - Scanner Frequencies
Old 04-09-2014, 11:51 PM
Same frequency. Yep, could be. But what's with "Kitsap County"?
Maybe it's an anagram...hmm..
Ask Pit 800 MHz
Spa Kit 800 MHz
lol...
Old 04-10-2014, 7:10 AM
nick1427d's Avatar
Did you reset your scanner after you got it? I remember my BCD396 having preprogrammed state trunking systems in it. So even though you were searching, it is associating that CC with a preprogrammed ID.
Nick
Old 04-10-2014, 2:19 PM
dpm3's Avatar
Kitsap County is located out here in Western Washington. I'd go with the suggestion that perhaps the scanner has automatically associated the frequency with a system programmed in it's firmware.
Old 04-10-2014, 3:45 PM
wtp wtp is online now
Default just one question (now)
so when my 396xt searches 851-854 and hits my county it should say CHARLOTTE COUNTY and not the 582Ah that my 396t and 396xt does?
it could be that the programmer for the system was having fun or he might be from washington and thought no one would see it.
Old 04-10-2014, 4:30 PM
No, I did not reset it. You might be on the right track though. It's hitting on some system stored on memory.
The first thing I did was look up Kitsap County and found it was only located in Washington state.
I searched through the scanner's memory and did not find any system located in Washington state.
The scanner has the ability to read system names on C-Ch only I believe. That's why I'm still thrown for a loop with "Kitsap County". lol..
UPMan is Kitsap County programmed at the factory for that frequency?
Old 04-14-2014, 1:30 PM
Try searching/scanning Washington State and see if the scanner stops on that same trunked system.
Sorry if anyone else already suggested that.
Old 04-16-2014, 4:21 AM
There's no stored system from Washington state. But good thinking.
Oh well...guess it'll stay a mystery. lol.
Old 04-16-2014, 9:30 AM
The control channel does not send out system "names". System names are "associated" with System ID's by the users and are not part of the control channel information.
Old 04-16-2014, 11:28 AM
Default so
so the fact that i have seen polk county ,lee county, sarasota county,pinellas county,de soto county and others as i have driven around with none of them being in the 396xt means what ??
to me that means that it is in the data being sent out. and my own county says 582Ah and not charlotte like is in the radio.
hey, if you want to test it then name it "unknown" as a system and see if that pops up.
i still say someone was having fun on the system name.
Old 04-16-2014, 11:41 AM
Your scanner has been programmed with those names. It does not come across the control channel. A good example is when you put your scanner in the ID Search mode and it finds a new talk group it will display a number, not an alpha tag. Same goes with system names. Until you program in an alpha tag it will display a number. If it shows names they either came from the pre-programmed systems/talk groups already in the radio or were added manually.
Old 04-16-2014, 4:56 PM
Default the point
i had driven up 75 and the radio said polk county without it being programmed in the radio.
and what about my county just having a number and not the name i put in???
after having the radio (396t) i wiped out all the systems except my own and was traveling around the country.
in custom search with cc on almost all the county systems gave their name. it was easier to search at the time 866-869 and let the radio do its thing then to program where i would be going.
Old 04-16-2014, 5:05 PM
nick1427d's Avatar
to me that means that it is in the data being sent out. and my own county says 582Ah.
Is this the system you are referring to?:
Charlotte County Public Services Trunking System, Charlotte County, Florida - Scanner Frequencies
Note the system ID...
Nick
Old 04-16-2014, 5:45 PM
Default yes
but i do not see how the radio would check your systems to give a name to a search system. and what would happen if two control channels were the same (overlap) but not in the same area?
Old 04-19-2014, 11:19 PM
Default a re-read
now i see what some of them thought ...
they thought that it was a programmed system.
they had not noticed the search as in custom search.
so i stand by my posts.
Old 04-19-2014, 11:29 PM
I didn't run any pre-programmed systems. I did a control channel search.
Old 04-19-2014, 11:40 PM
Default yes
but everybody else read it wrong. they thought it was a programmed system. and yes if it was that would happen.
but did you find out where it is?
Old 04-20-2014, 9:59 PM
nick1427d's Avatar
No that's not what we said. We stated that it was one of the pre-programmed systems placed there by Uniden when they ship out.
The control channel is not sending any type of data that the scanner could decode and then form a site or system name without SOMEBODY creating the name on the scanner/radio end.
Even the actual radios used on the system see the system and associated sites as numbers and letters as they are usually stated in the database.
Factory reset your scanner
Nick
