Go Back   The RadioReference.com Forums > U.S. Regional Radio Discussion Forums > Missouri Radio Discussion Forum
Missouri Radio Discussion Forum - Forum for discussing Radio Information in the State of Missouri.
Old 04-17-2017, 1:44 AM
drkatzjr's Avatar
Default Hollister / Taney CO Reception Problems
I travel to Branson frequently, and have recently purchased a home in Hollister.
I have a BCD325P2 - And have all the P25 Trunked frequencies inputed to my scanner relevant to Taney CO's P25 Public Safety trunked system, part of the state-wide system
Currently I am staying at the Chateau On the River Hotel (Located in Hollister) - far western Taney CO
I have a Radio Shack 800MHZ antenna, as well as a Wilson All Band antenna, and --several others- I have tried....
When I program Taney County (As part of Missouri's P25 Statewide Public Safety Trunked system
(With 161.8750 as the control channel) I am having extensive difficulty with receiving this P25 system
(i.e. Taney CO Sherrif, Hollister Dispatch, and Troop D (All for Taney CO)
When I program Taney CO with my 325P2, I first select the system (P25) then I select "Standard Trunk". - the two options are "Standard Trunk"
and "One-Freq Trunk"
I then input the frequencies for Taney CO's P25 System (Part of the Missouri Statewide Public Safety P25 Trunked System) and after using several antennas, I am continually having extensive difficulty monitoring this system (once again -- in the west part of Taney CO and can't monitor anything.
For example, tonight, as previously mentioned, I am staying at the Chateau On the Lake Hotel in Hollister, and although the scanner is displaying up to four bars, I am unable to monitor --anything--
(i.e. The TG might be displayed, but no voice reception is heard.
Is this usual for this specific area Taney CO, or am I failing to program the system correctly...I have never had any problems monitoring P25 systems with my BCD325P2 before...
If anyone is familiar with Taney's P25 system, and would be kind enough to help me, I would sincerely appreciate feedback as to what I might be doing incorrectly......
Old 04-17-2017, 8:12 PM
iamhere300's Avatar
It is not Taney Countys system. It is MOSWIN, Taney County is merely a user.
Have you programmed in surrounding sites also?
Have they gone to all Moswin?
Old 04-18-2017, 3:00 PM
drkatzjr's Avatar
Yes. My main reception issue is with Taney on the MOSWIN
It could be simply the hotel that I'm staying at which is the Château on the Lake,
If you are for familiar with where that is located
When I am mobile, closer to the city, I have no problems
But I certainly do where I am right now…
Old 04-19-2017, 10:50 AM
When you say you have trouble with reception do you get anything? Double check the control channel(s) too. And as I believe someone else suggested program the surrounding counties for MOSWIN, that should help.
I remember some issues receiving MOSWIN signals in the Branson area last year when my wife and I were down there. I am sure the big hills and valleys don't help.
Good luck.
Old 04-19-2017, 1:07 PM
pinballwiz86's Avatar
Request a room move to a higher floor.
Uniden 536HP/436HP / Uniden 396XT / Uniden 125AT / Uniden 15X / GRE 310 / GRE 120 // Ham Radio: Icom 718 / Yaesu 2900 / Yaesu 7900 / Yaesu FTM-400XDR / Yaesu FT-270 / Baofeng UV-5R+ / Icom ID-51A+
Old 04-21-2017, 3:34 AM
drkatzjr's Avatar
LOL. Wise advice.
But seriously, has anyone else experienced reception issues in Taney CO (especially the more -rural- areas)
on MOSWIN
I have programmed nearby counties as well. I have a BCD325P2
I have tried --multiple-- mobile antennas for my 325
In my home, should I try a discone antenna when at home? I will be living in Hollister
Any help / feedback would be appreciated.
Old 04-23-2017, 10:48 PM
I've never had any reception issues when using my XTS5000 other than in obvious spots. Can't say about a scanner though, never tried.
Branson does have a lot of RFI in the city and then all the hills make for some interesting propagation.
-------> Repeaterbook.com <--------
Main radios: Motorola XTS5000R VHF, Kenwood TK2170, Motorola MTS2000, Motorola XTS3000 800MHz, VXD720 DMR
Stop scanner streaming before it kills the hobby!
Old 04-24-2017, 8:01 AM
As I stated before I have had reception problems in Taney Co and areas nearby but I can not say there was a specific reason for the problems. Most monitoring was done in and near Branson. Keep trying, you might find a way to get better reception.
Old 04-25-2017, 8:34 PM
I am in Branson monthly, we are not having any problems with receiving TCSO and Branson PD/Fire, and TCA (also Troop D south repeater), but I am using the BCD436HP with a satellite GPS hooked up and it auto enables Taney once we get in Christian County. I had the model radio you had before this one and had trouble not hearing Taney County SO as well, for what its worth.
Old 04-27-2017, 11:21 AM
drkatzjr's Avatar
Yes, my experience has been commensurate. What I am discussing is the more rurual smaller towns in Taney CO - LIke Hollister. For example
I have a Lake front property in Hollister
Would using a discone antenna possibly remedy my reception, Currently I have a BCD325P2
and use the "tried and true" old radio shack 800MHZ antenna.
Old 04-27-2017, 12:33 PM
Since the repeaters for Taney County transmit on VHF Hi band (with the exception of some 700 Mhz towers in select locations of the state, including Springfield, I would suggest a broad spectrum antenna. In testing a 900 Mhz antenna results were poor on MOSWIN we found. We use a Tram brand magnetic broad spectrum antenna in the car and with both the 325P2 and the 436HP I could receive OK State patrol from Marionville, MO in some Dx trials. Not bad for a cheaper antenna. Most of the time my problem with the 325P2 was a programming glitch causing me not to receive all the departments in a given area.
Old 04-27-2017, 7:43 PM
Try a vhf high band antenna or one that receives more than just 700/800/900 freqs. I bet you you will get better reception if you use the stock antenna for the scanner. Give it a try.
Old 04-28-2017, 2:22 PM
drkatzjr's Avatar
Exclamation
Could you, or someone else, give me a specific brand of antenna or model number?
You mention tram, but can you give me a model number?
