Originally Posted by joshuadenny
do you think these will be heard from polson? i dont remember exactly where that refuel track is.
i did manage faint border patrol the other night from elmo... not quite clear enough to be considered readable, but there nonetheless.
joshua
Hi joshuadenny
You should have no problem hearing the tankers fly by as long as you have an outside antenna, that is of course if your scanner covers the milair band (225.0000 - 399.9750 AM mode), (240.0000 - 280.0000 FM mode for Military satellites); my scanner does not have fm mode for satellites.
There are 2 AR tracks they use; AR 9 & AR 9A. AR 9 is south of AR9A. AR 9 track should be right over polson or just south of it, from the looks of the map I have. Track AR 9A is north of polson but you might here it.
They generally fly over around between 1100 hrs - 1300 hrs and 1600 hrs - 1800 hrs. Check around 1200 hrs & 1700 hrs. You never know when they will fly over but usually in that time frame. You also can here them at night sometimes. What milair frequencies do you have as I several in my scanner I listen to. 311.0000, 321.0000, 303.0000 & 319.4000 are good ones besides the tanker freq's. Also 300.1250 is good
as you never know what you might here on that. That one might be coming out of Idaho/Washington border area as the roosevelt MOA is in that area, so you might not here it. Oh, in the lakeside area is the RCAG site. Freq's are 251.1500 & 285.4000. Hope this helps. Oh, also listen to 256.4000 as I get comms on that too once in a while. Also, listen to 122.7500 if there is a squadron of planes refueling. And listen to 293.7000 as this is an fairchild AFB frequency and I've heard pilots using it then switch over to another freq., sometimes 335.5000.
Regards,
cjrjr507
