Go Back   The RadioReference.com Forums > U.S. Regional Radio Discussion Forums > Montana Radio Discussion Forum
Montana Radio Discussion Forum - Forum for discussing Radio Information in the State of Montana.
Old 06-04-2017, 2:49 PM
Junior1970's Avatar
Default Montana Road Trip
Heading up to Anaconda in August on a road trip and need to know what frequencies and sites to plug in along the route. I have both a Pro 96 and 2096
I-15 from Idaho to I-90 and the counties and population centers (Dillion, Silver Bow, Butte, Deer Lodge, etc)
Also will most likely need to know what custom tables to program for those sites because the Montana trunked system says that the custom tables for each site are in the comments section but I didn't see any. But I may have been looking in the wrong place I don't know.
Any help would be appreciated.
Thanks.
RS PRO-96, RS PRO-95 (2), RS PRO-94, RS PRO-93, RS PRO-2096, RS PRO-2067 (3), Uniden BC 60-XLT (3), Uniden BCT 7.
Old 06-04-2017, 3:46 PM
I just moved away from that area to Cut Bank, but when i left last August nothing down there is digital around those areas. Only exception would be Dillon haven't been there since I moved back here from Tooele UT in 2010.
Old 06-08-2017, 7:04 PM
Here is a table I have drawn up for the statewide system:
Code:
  Low    High   Offset    Base           Step
    0    4095       0   851.00625        6.25
 4096    8191    4096   762.00625        6.25
 8192   12287    8192   149.05000        5.00  *
12288   16383   12288   136.00000       10.00
16384   20479   16384   149.05750        5.00
20480   24575   20480   149.05000        5.00
24576   28671   24576   149.05000        5.00
28672   32767   28672   146.00500        5.00
32768   36863   32768   136.00500       10.00
36864   40959   36864   136.00000       12.50  *
40960   45055   40960   145.37500        5.00
45056   49151   45056   144.11000        5.00
49152   53247   49152   136.00500       10.00  *
53248   57343   53248   149.05000        5.00
57344   61439   57344   136.00500       10.00
61440   65535   61440   149.05000        2.50  *
Reference files found in this post:
http://forums.radioreference.com/mon...ml#post2255921
There are a few problems with trying to use the Pro96 and Pro2096 on this system.
The first is that these radios only accept a maximum of 6 lines in the table, so you must know which lines are actually used for a particular site. The lines marked with an asterisk are possibly in use.
Another reported problem is that these radios will not accept the 2.5 KHz stepping entry.
Another is that the GRE/Radio Shack scanners alter entries for the Base Frequency if they fall inside the aircraft band. These entries are altered by the radio to comply with the 8.33 kHz spacing in that band.
Sorry I couldn't assist further.
Old 06-08-2017, 11:34 PM
Junior1970's Avatar
This has been very helpful.
I'm mainly interested in the sites that cover Beaverhead, Silver Bow and Deer Lodge counties since that's where I am headed.
How do you know which lines are used for a site? I didn't see the comments area that was noted when reading up on the statewide system or was too blind to see it.
Old 06-09-2017, 6:57 AM
The table was originally in the Misc System Information section on the database page
https://www.radioreference.com/apps/db/?sid=3825
It conflicts with the table I provided, but I believe mine is more current. (2014)
The files that MtnBiker had in his dropbox are now gone, but contained a few files for the Greycliff and Lewistown sites.
Without someone providing Pro96Com or Unitrunker files for the sites you will be monitoring, it's impossible to guess which lines from the table you actually need.
Old 06-09-2017, 4:25 PM
Those counties are not on the Statewide system.
Old 06-11-2017, 11:36 PM
Junior1970's Avatar
Just trying to understand.
The RRDB shows sites in the statewide systems for those counties. By this meaning the only users on the sites in those counties are the Highway Patrol then and the rest of law is conventional?
Old 06-12-2017, 12:34 AM
Yes that is correct as of last year when I lived in that area. The highway patrol also runs on both when I was living in Granite County, they used 154.680 in those areas. Montana database is not very accurate in some areas lack of people to help get info.
Old 06-16-2017, 9:41 PM
Junior1970's Avatar
I thank everyone for the help and the info. I'll take a stab and hope for the best on all fronts and if I find anything new or different I'll pass it along. Thanks.
